What did you mod today?
SinkPAD lists the thermal capacity of their copper MCPCB’s as well as aluminum ones, both DTP, the copper has virtually twice the capacity. Al 210.0 W/m.K Cu 385.0 W/m.K, so while it’s not exactly half for the Al it’s not that far off. These numbers are given on a 20.5mm triple MCPCB with DTP for each metal core.
If you were to make a flashlight head in Aluminum to weigh the same as one in Copper, well obviously the Aluminum one would be very bulky. lol
5A’s ROCK! :smiley:
VTC5 is 2600mAh , up to 20A continuous discharge current “(test by mooch)”:Sony VTC5 20A 2600mAh Bench Test Results...a good 20A cell | E-Cigarette Forum
VTC5A is 2500-2600mAh , up to 25A continuous discharge current “(test by mooch)”:Sony VTC5A 2500mAh 18650 Bench Test Results...a fantastic 25A battery! | E-Cigarette Forum
VTC6 is 3000mAh , up to 15-20A continuous discharge current “(test by mooch)”:Sony VTC6 15A 3000mAh 18650 Bench Test Results...a great battery, equaling HG2/30Q | E-Cigarette Forum
VTC5A seems to be the 18650 battery with the lowest internal resistance up to date (aka it will give the most current when used in a direct drive setup , in comparison to any other 18650 cell)
Looked up my orders, yeah, VTC6.
https://www.reddit.com/r/electronic_cigarette/comments/5avri8/sony_vtc_battery_shootout_which_one_is_the_best/
I figure I’m not going to be vaping or DDing a quad or anything, so I went for capacity. 3AH sounded good. :smiley:
But yeah, lotsa people like the 5 and 5A, so am still wondering why.
That was the gist of what I was getting earlier, albeit in a roundabout way, but this about sums it up nicely. :smiley:
I modded another nitefighter C8 style light today and decided to see what the SST-40 would do if I put it on the aluminum mcpcb that comes with them. I did put down good thermal grease to give it it’s best chance of surviving the low resistance FET driver, heavier wires and spring mod. Surprisingly it did not kill the emitter even with a LGDBHE4 which is a pretty good high amp battery.
I did this because I was curious how many amps they can handle without being put on direct copper mcpcbs. Ton’s of lights like the SRK’s and other multi-emitters are a lot easier and cheaper to mod if you re-flow onto the original mcpcbs. From this I would say that there is little to worry about even when using high amp batteries.
Does anyone know how many amps these SST-40’s can handle without putting them on copper mcpcbs? I wouldn’t think they could handle this much and now I’m curious what the max is.
^ DTP boards perform pretty close to each other (a few years ago relic38 and I tested a number of types that all came pretty close to each other), but I have the impression that in non-DTP boards there is a huge variation in performance. The best I have seen is a cheap (copper core) 20mm XM-L board that easily allowed to run an XM-L2 led at 5A while performing only 5% less than a Sinkpad. But on the safe side I think 4A is no problem for almost any ledboard, also with a SST-40.
Thanks for the info.
Heres djozz’s test on the SST-40.
Today I modded a LuckySun D80 with a BLF-A6 driver and a Black Flat on led4power’s new, promising, Oslon board.
Unfortunately the modding attempt took all day and turned into an investigation of this new type of board, and this is what I found:
  • to compare this new mod to, I have a driver-less (so led directly connected to battery, with only the switch in the circuitry) ‘Mitko-thrower’ with a Black Flat on a XP-DTP board, current is 4.5A and output is 700 lumen after 30 seconds, which is pretty consistent with my Black Flat emitter test.
  • But this D80 mod, very neatly performed, did just under 500 lumen (at 4.2A, close enough), so there is 200 lumen missing somehow. The light was clearly more purple on the highest setting compared to the lower levels, a bit more purple than the (higher output) Mitko thrower.
  • I thought maybe the driver is off, so I put a new BLF-A6 driver into the D80. Result: still a bit under 500 lumen.
  • I reflowed a new (my last :frowning: ) Black Flat on the board to see if it was the led that was wrong, result: still under 500 lumen.
  • I suspected that my D80 has a really bad reflector, so I took a brand new Convoy C8 host with beautiful smooth reflector and transplanted driver and board+led into it. Result: 4.2A and just under 500 lumen.
  • then I tried driver-less, connecting led-minus thoroughly to ground. Result: under 500 lumen.
  • then as a last way out, I reflowed the led on a 20mm Noctigon and soldered it into the C8 (with the BLF-A6-driver, but with the DTP-board the driver is bypassed and led is directly connected to battery). Result: clear and present 620 lumen (and a small black speck on the led from all the transplants).
In all steps above I made sure that the led was perfectly centered and in focus, they were finished mods.
Conclusion: I can still think of other explanations, but for me the most plausible one at this moment is that this new type of board (at least the one that I did the test on), when heat-shedding really counts with a severely overdriven led that has the small Oslon footprint, performs not as good as a DTP board. I hope that I will be proven wrong by others as I really want that easy to use well-performing Black Flat board.
Black flats also do not come in flux bins they put them randomly in the tapes
likely this ones were on the low end of efficiency
Yeah, but reflowing another LED yielded the same result while switching MCPCBs brought an improvement. This is a strong indication that MCPCB was the reason for low performance.
That’s indeed a disheartening result.
Yeah you definitely want DTP if you want to get the most out of this LED.
Thermal paste is a must.
If you want to do 5-6A then you need a proper heatsink, not a flashlight host, to dissipate the heat.
Thanks Steve.
I suspect heat spreading on oslon black flat is pretty bad, bottom pads are very small so power density (W/mm2) is very high at board-pad junction, over 15Watts per 1mm2 of LED die.
This board was designed for IR oslons (black flat was still not very known at the time of design) , and it should perform much better than existing insulated boards like non-dtp copper pcb for XP, and Bergquist 804087 .
I will have two oslons flat for testing soon,after test I’ll do “autopsy”, I’m very interested in how cross section of oslon flat looks inside (thermal path specifically). Plastic case of oslons always was downside for me, I assume there is no ceramic like alumina inside, just copper pad, the question is how thick.
I did some calculation, mosx have thermal resistance equivalent to <250um of solder layer, and if I remember correctly someone did the test noctigon vs. sinkpad 2 (gap on top) ,and there were no visible difference in performance for xm-l2 and similar leds, but they have ceramic substrate and pads have decent size.
that was me, and the led was a XM-L2, so a way bigger thermal pad (13.3 mm2 vs 2.7 mm2 for the Black Flat, 5 times bigger)
It was actually this test/thread:
but I see there is identical picture in your thread also. Somehow either I missed your thread or forgot about it. Subscribed
Yes, the observation is the same: with the XM-L footprint, the thickness of a solder layer under the led is not critical as long as you get rid of the thick dielectric layer. But apparently at the same powerlevel but a 5 times smaller footprint, the details of what happens under the led are more critical, makes sense :slight_smile:
I ordered some MosX oslon boards for testing too , and i already have some Oslon black flat leds (LUW HWQP) here …
Right now i tested one at a Thorfire C8S on a DTP board (without a driver) , with AR glass and i get otf 720 lumens & (only) 170kcd @ 5 amps , using sony VTC5 .
720 lumen (@30seconds?) sounds really consistent with my Supwildfire driver-less thrower (350kcd :stuck_out_tongue: :wink: ) which is 700 lumen but does not have and AR lens.
