Agree, that will be one bright and throwy UV-light, it should work but since there is no affordable UV-pass filter in that size you will have to live with the little visible stray light.
About the lifetime question: I obviously have no longterm data on the SST-10 at 2A, but in general 365nm leds seem sensitive to overdriving them for a prolonged period, at least the Nichia 276A is reported to dim or fail over time.
You are correct of course, and at the 1A per led that you will be able to run the triple direct drive on a single cell, the lifetime expectancy should be good.
The output should still be impressive though, at more than 3W radiation OTF.
Whoa professor Djozz. That’s a great DIY way to measure the UV. Salute! I thank you for doing this. I can imagine the joy you had doing it.
As for the 233B. Yes that’s just samples I got for PCB footprint testing. Please ignore the output.
Correct :party: , designing test methods is way more fun than continuing doing tests on new leds once the method is settled, but I will try to measure a new UV led every now and then.
I got information Simon is using a LG UV LED in next Convoy UV batches, as the SST-10 UV 365nm are more expensive at same performance
it is listed with 1360mW@0.7A
and drive current on the G1performance group is 700mA und the H1 1500mA max. he got the one that’s only 0.7A, but I think it will run fine at 1.5A
^ Cool! I have been trying to find that led for sale for 2 years now, but I can’t find it in small quantities with normal shipping costs. I even emailed lasercomponents.com because they are distributor of LG UV leds, but had no luck getting samples from them.
No need, he already lists the led for sale. But his picture is an older generation of LG UV-leds than I thought it would be. Still cool to test but not the latest and greatest.
Nice work, djozz. Would you care to update this thread by testing the LG UV-A 365 nm? I’d like to see it fare against the 365 nm UV LEDs in your test. I’m sure it will not top the Luminus SST-10, but I think it will beat the two Nichias. I’m not sure about the LiteON. I have the LG UV-A and I’m using it. The visible stray light of the LG is tolerable, maybe not as bad as the LiteON. I’m curious to see if getting the SST-10 is worth the extra price.
I have one of those LG leds in house to test but I’m waiting for the Seoel Semiconductors version from Kaidomain that is stuck in the mail somewhere, to do a test of both.
