I received mine today, and the memory on this flashlight…well, it takes me a bit “off” of it! It is not unbearable, but I just wish it didn’t have it! I wish it always started always on ML mode (which I think is a GREAT moonlight mode, lower than the 0.5 Lumens of the Olight S1R Baton). Personal preferences as always
Does anyone know if memory can be taken by removing any physical component / chip of the driver?
Sorry, I don’t know much about electronics :person_facepalming:
Also, the long click for ON…well, I have to get used to it!
It does have memory mode. It can start on ML, low, or medium. Turbo takes double click. Just chose moonlight, low, or medium and then turn off flashlight in selected mode. Then one fast click opens the chosen mode.
Yup, I know, but I wish I didn’t have to remember in which mode I used it last time. The Olight UI is great for that because you can always start on the lowest mode. The Sofirn Sf14 always starts on the lowest mode as the Manker E11 (I’m referring to lights I have).
I wish the SP10B would be like that But it’s just a preference as I mentioned
And at least on mine, it is not a fast but a long click for ON. (Maybe we have different versions of the light? Or maybe I’m just mistaken… :person_facepalming: Gotta check it tonight!)
I just ordered a blue SP10B as it looks like a very decent 14500 EDC light with side switch for the price… and a possible affordable replacement for the UT01 - have a pile of them i can’t honestly gift out considering the reported potential issues in another thread.
However, reading the above comments regarding the UI… it reminds me of the Astrolux S42 fiasco - great light with a terrible UI. I’ll see for myself when i have it in hand.
The SP10B has a nice UI (for me)!
–3 regular modes: a true Moonlight mode; a nice Low (despite there is a “high” jump from moonligh); and a Medium that on 14500 Li-Ion has a similar level as the High mode on AA Alkaline or NI-MH ;
- 2 special modes: Double click for High and 3 clicks for Strobe!
And lockout with 4 clicks (initially it was hard to enter it, but with some use you get the timing to lock/unlock).
I use it with 14500 battery and it is quite nice! Maybe UT01 / Manker E11 has higher output on the highest level, but the SP10B is quite nice, specially for the price :+1:
I’d only change it to not have memory and always start on Moonlight, but that’s me
And the LED tint is good as well, a Neutral white, no artifacts or major tint shifts! (at least on mine).
I guess it will depend on your use and your personnal preferences of the UI! But overall it is nice!
I like it. No memory was the only thing I disliked about my TG06. Always starting on high/turbo, was generally too much. The UI on this takes a little getting used to, but after carrying for a couple weeks, I’m used to it. Memory start on high, double click for turbo :+1: Reversible clip and I would buy stock.
Hum, please note that on the User Manual, the manufacturer doesn’t say it takes Ni-MH batteries (although it takes it of course). Maybe it is because of that specific aspect that it doesn’t mention use the Ni-MH!
I will avoid using Ni-MH on it. Had bad experiences with lights that drained some batteries too much, ’cause they don’t have LV warning nor protection.
Yup, it gets a bit to get used to it, specially because you always think it has 2 modes as the moonlight is so low
And I agree with you, reversible clip should make this light even better!
Sofirn could revise this, not only on the SP10A/B but also on the SF14 (all use the same tubes…).
Hate alkaleaks at this point, got a bunch of LFP cells instead which I’m using.
First thing I noticed is that LFP (3.2V) levels are equivalent to alkaleaks (1.5V), not Li-ion (3.7V+). Odd. No idea why. Thought the higher voltage would give me the higher levels per mode. Both sets levels look identical, even after a few times flipping back’n’forth. I might be wrong, though, but to me, turbo(alkaleak) = turbo(LFP).
Now, there’s nothing scientific I’m doing, no lumenometer, nothing, just white-ceiling tests for both cells.
Forgot about damned strobe. Thought it didn’t have any, but yeah, mine can get to it in 3 clicks.
Lockout/Unlock can be 4 clicks or sometimes 5 (random). Doesn’t bug me.
Yeah, would prefer not so high a jump between firefly and low, but it doesn’t bug me… yet. For looking up-close, it’s absolutely perfect, but for, say, checking a clock on the far wall, it might be too dim, and low will definitely be too bright. My SF31W and TK4A have a perfect clock-on-wall moonlight level. Nice and low without being too low. But this is true firefly mode, not even moonlight, so is quite nice for just looking down to see where your slippers are.
Yeah, nice beam, not too fried-eggy at all, just a bit of a yellow corona around the hotspot.
Still, rather nice for an AA-based light, overall! Think I’ll put this in rotation…
Amazon had a package deal the last week of December where I picked up this light, a Sofirn SF31, 18650 and USB charger for $16 but that deal has passed. Always good to look at the bottom of the main description for offers like that. I almost missed it.
