Test/review of Vapcell INR21700 3100mAh (Purple)
Official specifications:
  • Model: NCR21700
  • Size: 21.0*70.2mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 3100mAh (0.2C discharge)
  • Min capacity: 3000mAh (0.2C discharge)
  • Weight: Max:68g
  • Internal resistance: Max:8mOhm
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 35000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
  • Storage: Temperature –5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
One of the new slightly larger batteries, this one with fairly low capacity, but very high current capability.
Good tracking, expect a small capacity difference. The batteries has nearly constant capacity op to 30A and the 35A rating looks very realistic.
The cells do not get too warm at 30A discharge current.
Conclusion
This is a good high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
Thanks. Being able to actually sustain 30A+ continuous draw might be worth the trade-off of low capacity for some people.
Looks nearly identical to 30T…Possibly a cherry-picked 30T, which would explain slightly higher capacity.
