I donât have this light, but I do have an Amutorch AM30 (review) and it is a very solid light! Nice beam and output, very well built!
When reading some things above made me go to their page on AliExpress and check the specs on modes.
Not saying that what is happening with your lights is not âtrueâ, it is strange indeed, as the âoriginalâ Amutorch JM70 has these modes:
The AM30 also has 4 regular modes, starting on 200 lumens, double click for turbo, 3 clicks for strobe, 4 clicks to (un)lock. Despite it is not a tail + e-switch light, Iâm finding very strange passing the 1-2-3 modes and them strobe!
Is it possible that you have a âdamagedâ driver or switch that reads the 1+1+1 clicks as â3 quick clicksâ for strobe?
EDIT: I also find it very âstrangeâ to receive these lights under âGaluxiaâ brand/name⌠I received the AM30 in a Amutorch branded (with sticker) box. Maybe this has to do with being BG the seller, butâŚsomething doesnât seem to be completely right here
It have 3 modes and double fast click is strobo.
I donât know what to say this is so confusing, my model canât unscrew at tailcap believe it or not.
But we get replacement switch only question is now to change it :person_facepalming:
Does anyone contact store from Ali that MascaratumB gives ?
If not I will contact them and ask what the hell is happening here, why lights are different and what kind of mistery is this. Maybe they wont answer, but I will try.
Well, all the times I tried to contact them, they answered me, but I was buying from them directly.
I guess they will answer you as well! Be sure to explain what is happening and give them the link for this thread so that they can perceive what is going on.
Same UI as mine it seems, but the tailcap is different.
Mine does unscrew, but you have to use some force and itâs plastic so you might scratch it doing so.
A TA driver is on route for mine, with a black Liitokala and that reflector it should out throw my M3XS !
Yes, Olight M3XS-UT Javelot. The reflector is wider and if I fed the LED through a FET it should blast some Cd !
I hav to make a little correction on what I said, on mine the double click does Turbo and triple click does Strobe.
Canât wait to have my TA driver with Narsil to truely enjoy it :sunglasses:
ââDear friend,Sorry for the confusion.
JM70 is our new product in 2017, had gone through two improvements. Because friends buy at a different time, there may be some differences with different tailcaps, with different mcpcb boards, with different modes etc.
About the sign on the box, Galuxia is also the trademark of our company. itâs brand Galuxia that makes on the flashlight, so Galuxia been written on the box.
The current sale of JM70 light is the same as the store described, low-mid-high-brightest(quick double)cycle -strobe(quick three click).
If have any other questions, Please let the friends in the forum contact me. ââ
No problem today I donât have time for reply just copy paste a message from seller. So correct it, it is not from BG it is from manufacturer directly.
So it turn out that all is ok, just someone get older and someone newer version of this light, so I get older.
Donât know I was skeptical when I was ordering it before 25 days, but now when I compare it with nitecore p30 at least it can get more distance for sure, it is not excelent, probably for this big reflector size must be monster, but compared to p30 which is better thrower from any stock C8 it is ok.
I read in review about modes at new model, but Iâm not sure that I understand good. Question is can turbo mode be memorised ? So just tap rear switch turbo is on, turn it off, tap again on rear and turbo is there ?
