Vapcell INR21700 3100mAh (Purple)
Official specifications:
Model: NCR21700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3100mAh (0.2C discharge)
Min capacity: 3000mAh (0.2C discharge)
Weight: Max:68g
Internal resistance: Max:8mOhm
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 35000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
One of the new slightly larger batteries, this one with fairly low capacity, but very high current capability.
Good tracking, expect a small capacity difference. The batteries has nearly constant capacity op to 30A and the 35A rating looks very realistic.
The cells do not get too warm at 30A discharge current.
Conclusion
This is a good high current battery.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
