Well You seem pretty savvy with machining, and you do such a great job. So I have no doubt you can do it!
Surely you mean lighted tire valve caps?
Still make these?
Still have several various vg10 kits.
subbed
Q8 boards for 2s/2p , 4s batteries order etc ?
Right.
I cant see this driver backsides with 4 independent cell contacts. I immediatly imagine big badaboom. Also, I cant understand how do Lexel and others plan to fix tube in right position - which is necessary with 2 screw holes in driver (ie you cant rotate driver to proper position to align cells).
I didnt found any simple ways to make 2s/4s mod safety. Im going to:
- reverse battery tube.
- use stock tail pcb place (now it is faced to the driver) for medium board (#1 for 4s or #2 for 2s), so you could turn tube in head without any short-circuit risk
- make custom tail. With deeper threads (stock tail wont allow to screw all down to the head side tube threads) and with place for custom tail board (#3)
- make custom tail insert that have “pins” which could fix between cells and rotate (together with tail board) inside custom tail
What if the personal wanting to know the measurement does not have a 30Q BT at hand?
The difference on mine is 1.5 mm
I suppose I listed enough information why did I had to ask this question.
I had lots of button top cells, and many lights with mechanical reverse protection. Not any combination could work.
Kiriba, do the copper pills for triple convoy S2+ come with a retaining ring?
Yes - I suppose it is mensioned clearly, no?
It says regular convoy retaining ring, so i was doubting if it comes with it.
I would like one.
Merry Christmas!
PM sent.
I will add photos with retaining rings to avoid misunderstanding.
Yokohama can buy the retaining rings separately on Kaidomain.com. But they are not named with Convoy.
Did a quick search of this thread, didn’t see any b158 pills, but have read in the past that you have offered them.
Any left for sale…?
No. It was very limited production.
Received my S2+ triple copper pill yesterday!
Quality seems to be top notch, retaining ring fits in nicely.
Now just wait for the other parts from China
Mine in somewhere between customs and local post office, over 40 days average delay for this part of the trip alone at this time of the year, hope it arrives soom
