Mtn Electronic has some protected Evva 5200 cells, but they a bit long. You can make the longer cells work by unscrewing the battery tube from the head a couple of turns. I did this when I ran the long KeepPower cells.
Are you in Sweden? I don’t think MtnE ships overseas anymore.
but would the KP 6000 even fit l6, i asume they are the same as the 5200 dimensions? i agree its hard to even find the kp 5200, i have been checking nkon from time to time no luck, just says out of stock all the time not even a date or anything when to expect them there…
We really don’t know if the new 6000 KP is the same size as the old 5200.
Some people think the new KP 6000mah is basically a Shockli 5500mah which people have reported as fitting the L6, but I can’t remember which L6. The big tube or the little tube version. So it’s a bit of a gamble.
If you’ve got a big tube L6 it will probably fit. If you have the small tube, it’s unknown.
That one has some confusing information. In one place it says it’s protected, then in another place it says “Without protection circuit! Not for flashlights!”.
That is odd.
At 26.2mm and 68mm it should fit fine. Being a flat top, you’ll need to either use a magnet or solder blob them.
It probably doesn’t help much, but I just picked up an L2 host (2pc ring style tube) and a Shockli 5500mah from MtnE. The cell fits and will slide out, but barely. IIRC, the L2 and some of L6 tubes should be about the same size, right? Not sure if that’s the larger or smaller L6 tube though.
I just received the liitokala 26650 (black) 5000mah. I had to put a solder blob on it to make contact and it’s pulling just over 17A at the tail. The efest 4200mah (purple) pulls just over 15A. This thing is bright!
Very cool!!
I have pretty much the same parts waiting for the Black L6 SMO but with a lighted E-SW too. Think I am gonna try Yellow or Orange in the SW on the black body.
I have one of the recently purchased L6 and several Liitokala black. They fit but snug on the OD. No rattles
My recent L2 is slightly looser on these, proper fit would better describe them.
i wouldnt feel safe use the liitokalas as u have to use a blob or magnet to make connection in series, what if it shortcuts or something? since they are unprotected its better using the efest since u dont need any magnet or blob…
and is it even a difference if u get 15A or 17 will the lumens be much higher if any?
He did not say he was using a magnet. Those have risks if you don’t do it right. Solder blobs are super safe. Who told you they are a problem or unsafe?
Problem of using 2 x 26650 Unprotected in series is that the L6 low voltage protection can’t tell if only one of the cell is undervolted.
No good then for the average Jean-Pierre
But for the lightalcoolic that knows what he does and recharges the 26650s often , that should be ok …
I am still waiting for my L6 from GB and its 26650 Protected KPs from BG …. sooo long wait ….
