I have the Nitecore TIP CRI 2017 edition (Nichia). It doesn’t appear to have a lockout mode.
When I arrived the package a few days ago, it was totally dead, won’t power on. I thought it was a DoA, but then I charged it and it appears to work. I notice that it seems to drain quite fast. So I did a more controlled test.
Yesterday morning, I fully charged it (took about 2 hours to full charge). Tested the battery-check mode, and it has 3 flashes. It can light up in Turbo. Didn’t use it the whole time (except did a few battery checks) About 12 hours later, in the evening, the battery check mode now comes up with 2 flashes. And another few hours later, I notice the TIP CR 2017 was flashing once by itself — doing a battery check mode indicates 1 flash. I left it at that prior to sleeping. On waking up this morning, I checked it and it’s totally dead, won’t turn on at all.
That’s some severe parasitic drain… Not sure how to go about reporting this to Gearbest. (send pictures? videos? how does one send a short meaningful video of a parasitic drain issue?)
That was the initial batch of TIP lights that had bad parasitic drain. The problem was solved long time ago, and it’s the first time I read about parasitic drain issues with the 2017 TIP (with clip).
Exactly hIKARInoob…… :+1: …. The info posted above is extremely out of date. It has nothing at all to do with the latest model of ‘Clips’.
d_t_a…. I would say yours has some kind of technical problem. I have a couple of the new ones that have been sitting around at least a couple of months and they still blink 3 times when tested.
Basically no parasitic drain…… that would be of any concern whatsoever… to me anyway.
Personally… I never had any issues with the first ones either, well over a year ago.
otoh, the above may be for the earlier Tip
you might be right that there is no lockout in the 2017 model, I can’t find it mentioned here http://flashlight.nitecore.com/ILLUMINATION/T/TIP2017/
they only mention “standby mode”… I don’t know what that is
They never were “”bad”” in the first place. That perception was just created by a few pi$$ed off people posting on the ‘interweb’…… And then others sharing it to spread the mis information.
Time has already told…. they are & have been…… “good”.
Get you some if you don’t have a couple & feel the TIP Clip Luv…….
That is correct…… TIP 2017 Does not have lockout. It does have a mode that turns it off after 30 seconds…. if accidentally turned on in a pocket or such. But can be easily overridden in use.
it says: Lockout/Unlock Hold down both switches until the main led flashes once to enter lockout mode, the product will be rendered inoperative to prevent accidental activation. To unlock, hold down both switches again. Note: The battery will last for 12 months in standby and lockout mode.
I have a TIP 2017 (XP-G2), and it doesn’t have lockout (only the clip, that avoids accidental turn ON).
And it doesn’t seem to have parasitic drain as well. If I leave it unused for some days, it still blinks the number of times it did when I left it!
More than that, the 2017 version, when clicking both buttons changes the settings from “Daily mode” to “Constant ON mode” (and vice versa), as teacher mentioned above.
This is the User Manual from the 2017 (sorry, can’t take better pictures) Click on them to enlarge the image!
Thank you MascaratumB for clarifying what I had tried to say… I could not remember the names of the two modes & was not close to my user manual. :person_facepalming: …
^ I just figured out this daily mode/constant on mode. So daily mode switches the light off after 30 seconds (in case it was an accidental activation). So basically daily mode functions sort of like a lock out mode.
Ok, lets assume there is no parasitic drain of the type this thread was originally about… related to lockout
but for whatever reason, d_t_a needs to replace a defective TIP, due to it not holding a charge…
they request a video as part of the return authorization script that they follow
it does not have to be a scientifically verified test, you can just show a video of the unit with dead batteries, and how it won’t turn on. You can speak during the video and tell them that you charged it however many days prior, and that now the light is prematurely drained. Post it on Youtube and send them the link.
it does not matter how good the video is, customer service just has to go through a checklist before giving you a refund or replacement.
I suggest you get a refund… After that buy another one as a separate transaction… this will work faster than asking them to send you a replacement…
sorry you got a defective unit, let us know that it was an isolated incident, that you got a refund, and that your new one works fine
Yep… you can do this OR… just do what I have done three times.
Take a couple of pictures, nicely tell them you have no way to take a video, tell them briefly & concisely what is wrong. Tell them your proposed solution to the problem…(make it fair… but easy on you) For instance a replacement in this case.
Be calm, clear, concise, & short in what you write. Stick to you ‘guns’ & accept nothing less.
Has worked like a charm for me…… all three times.
