The NEW Sofirn C8F Triple XP-L W2 w/side e-switch
Yeah, but getting a tail switch might be a problem. Maybe sofirn could sell me one seperate? I don’t know.
Richard is out of sst40, but when he gets more in maybe I could send him my mcpcb and he could reflow them.
Yeah, that sounds like a good plan.
My Convoy C8 tail cap fit, but didnt make contact, I had to use a copper washer.
You are right. but my light did turn on. Convoy has more threads on the tubes tail length.
Swapping Convoy tube and tail make contact in the C8F head. But a not liking the Convoy name on a Sofirn… :person_facepalming:
Not a good plan…. your MCPCB is XP, SST40 is XM. You will need the TPad XM/XHP.
Digikey has the SST40 in stock.
And if you’re going to all that trouble, you may as well put three XHP-50.2’s in it and Zener modify an FET driver, use 2 Aspire 18350’s. :smiley:
(my Ti X6 with 3 50.2’s is making 10,200 lumens off two of the Aspire cells, just sayin…)
I meant I need mechanical lockout so I don’t run the battery down. I’d prefer a tail switch over having to turn the tail cap all the time. I might wear out the thread anodizing and then I’d be in trouble.
The Luckysun F3X looks nice, but I don’t think it has a side switch. You can’t have ramping without a side switch.
The SHADOW SL3 comes pretty close, but the head on it is pretty big at 64mm. I definitely prefer the smaller 45mm head on the C8.
I think I have enough info to make a good plan of attack with this C8F.
Thanks everyone.
That’s right. I’d need to see if Richard still has the XM triple boards that fit this reflector.
Even if I bought leds from digikey, I can’t reflow them. I’d need Richard to do it.
Man, it’s a lot of stuff to keep track of.
Richard shows to have 5 of the TPad’s in XM footprint at $5.45 each, better pounce!
That is why I got the PB Sofirn, I want both e-switch and tail cap to cycle thru the modes and with the LD-2 driver I’m able to use both switches not just power on/ lock out, The reflector will go into the baked Convoy C8 and shit can the optic, never liked them any ways. I’ll just have to open up the emitter holes in the reflector.
The baked Convoy C8 is running 3 SST-40’s. I get what I want for $13.00, I spent more on a driver… :person_facepalming:
IMHO, don’t flashlights and guns usually go together anyhow? Along with knives, multitools, etc. lol.
Since a triple reflector is shallower than a single reflector, shouldn’t the triple C8 be shorter overall than the regular C8?
Also, if the Convoy C8 or Thorfire C8 tubes fit, I prefer also having a tailcap switch AND knurling on the tube. No smooth tubes for me.
I especially prefer the new Thorfire C8 tailcap with the two thumb cutouts.
I finally got mine yesterday - The UI is nice, the light itself feels “right” - but the bezel was too small and another color (a bit darker) - but the Bezel that I had left over from my other non-side-switch C8F fits perfectly.
Regarding the old C8F… I modded mine with the FET+1 Driver from BG and 3 4000K 219C - this thing is brighter than the new one :open_mouth:
Why? :frowning:
Think you’re missing something Jason, the depth of fitment of the star in a normal single LED C8 is all about following the parabolic curve of the reflector in order to achieve throw. The reflector designates where the emitter sits, not the size of the MCPCB.
In a triple design, the reflector cups are by default narrower and shorter in height to fit the 3 reflectors into the C8 head, hence, a shallower depth for the MCPCB.
You could use standard C8 sized reflectors in a triple, call it a BTU Shocker, and carry on…. :wink:
Yeah, that’s a bit ‘unfair’ to sofirn, in a way…
None the less, i ordered a Sofirn C8F host and a black Convoy C8 host along with it, just for swapping the tube and tail.
I like the C8 design, and i think the matching tailcap and classic batt. tube brings the design together.
Using simplicity that is redirected makes it also misleading.
The reflector, and the reflector alone, establishes the relationship of all other components. Design the proper reflector for the targeted LED, then build a light around it… do this properly and the result is guaranteed success.
Just a guess, but maybe the significantly lower Vf of the 219C is pulling enough current to outperform the XP-L2 in the new C8F.
EDIT: Corrected mistype
My C8F has XP-L emitters. I doubt very seriously that a Nichia 219C would outperform an XP-L2, as I’ve seen the XP-L2 pull over 9A and make 2300 lumens.
You're correct. Thanks for catching that.
left New one, right 219C
The difference is not big, if there is one.
And yes, the light is in turbo-mode
BOth with 30Q@ 4.0xV
I tried the code and it did not work. Is there a way to get a new one?
Does anybody have a discount code that works for Amazon?
