I contact them but so far no answer from their side.
@giorgoskok on turbo mode do you notice some timer ?
@X3 you mean M3XS-UT Javelot ?
@vidramon there is a runtime graph on the 1st post . No timed stepdown , it drops as the cell’s boltage drops.
Yes, Olight M3XS-UT Javelot. The reflector is wider and if I fed the LED through a FET it should blast some Cd !
I hav to make a little correction on what I said, on mine the double click does Turbo and triple click does Strobe.
Can’t wait to have my TA driver with Narsil to truely enjoy it :sunglasses:
’’Dear friend,Sorry for the confusion.
JM70 is our new product in 2017, had gone through two improvements. Because friends buy at a different time, there may be some differences with different tailcaps, with different mcpcb boards, with different modes etc.
About the sign on the box, Galuxia is also the trademark of our company. it’s brand Galuxia that makes on the flashlight, so Galuxia been written on the box.
The current sale of JM70 light is the same as the store described, low-mid-high-brightest(quick double)cycle -strobe(quick three click).
If have any other questions, Please let the friends in the forum contact me. ’’
can someone let me know if the driver retaining ring and side witch removable?
Thanks for your comment vidramon , i will add some of these info on my review , so future buyers will know .
This is not a driver retaining ring, in fact it is soldered to the driver which is then glued in the light.
The switch is soldered on the driver
No problem today I don’t have time for reply just copy paste a message from seller. So correct it, it is not from BG it is from manufacturer directly.
So it turn out that all is ok, just someone get older and someone newer version of this light, so I get older.
Don’t know I was skeptical when I was ordering it before 25 days, but now when I compare it with nitecore p30 at least it can get more distance for sure, it is not excelent, probably for this big reflector size must be monster, but compared to p30 which is better thrower from any stock C8 it is ok.
I read in review about modes at new model, but I’m not sure that I understand good. Question is can turbo mode be memorised ? So just tap rear switch turbo is on, turn it off, tap again on rear and turbo is there ?
What driver exactly is about ?
What kind of driver does it have?
Linear? FET?
I consider doing one with shaved SST-40…
Wat? TN42 with 490Kcd only?
Mine is CW and does 659Kcd…
Amutorch with spring bypass only 220Kcd is nice tho.
Just a bit more then my (unmodded) Acebeam T20.
Cheers
Nico
Did you mean XP-L HI V3 3C instead of X*HP*35 HI V3 3C?
I don’t know of any color binning for XHP35 HI “V3 3C”.
280Kcd is great output tho, nice!
Cheers
Nico
According to Aliexpress there is already a new version of this light, wiht USB charging port.
Note that the design has changed as well: bezel now is black, knurling on the part of the head where the switch is located is gone and we now see a few radial cooling finds.
Also the cooling fins on the head are different: more and thinner fins = better heat dissipation.
The switch has also been changed, I think it looks a lot better then the old version.
See here (scroll down to see picture): New Amutorch
Quote text line in red: “de oudere JM70 zaklamp niet hebben een USB magnetische opladen functie, een speciale korting van 25%.”.
Translation: “older model JM70 flashlight does not have USB magnetic charging port, special discount 25%” (that is on the older version of course).
Cheers,
Nico
PS….Shit, it’s already on the forum………new version already on BLF……
Got mine here look different, i dont like the fact that no off or standby mode using the e-switch.
Reflector has slight finger prints on the edge and the glass lens has flaws (circular marks).
I dont like the anodizing on this light feels cheap, maybe it is HAII?
Double click is finicky sometime it enggage to turbo sometimes it just switch to next mode, i think switch is too hard to press.
I am not into thrower so maybe i am biased, but i prefer XHP lights for more raw power to compensate for less throw.
Any chance to see the charging circuit? Is it integral part of the driver or a separate board?
Yeah
The anodize looks cheap…I would of guess HAII as well.
Lucky I didn’t pull the trigger on this light. Just too many question marks on my mine when I saw the photos on banggood.com
the anodizing reminds me of Ultrafire lights although a bit nicer and smoother. Machining is good but not sure why they include an extra front glass though.
Well………….got mine yesterday.
Pro:
Con:
Pro & Con:
Conclusion: great midsize thrower for the money, so, as already stated, good VFM.
I made some pics to compare the reflector with my Acebeam T20 (roughly same size) and I compared both lights on turbo…………The Amutorch seems to have a slightly brighter hotspot.
Hopefully this week I’ll be able to do some measurements @ Djozz so I will post that then, but sofar it’s looking good.
To compare it to the already hyped Thrunite Catapult V6: roughly the same throw at half the price, nice.
Cheers,
Nico
[pic1](<a) href=“http://abload.de/image.php?img=p1011652mediummbslf.jpg”\>
[pic2](<a) href=“http://abload.de/image.php?img=p1011651mediumh4s8g.jpg”\>
[pic3](<a) href=“http://abload.de/image.php?img=p1011650mediummls80.jpg”\>
[pic4](<a) href=“http://abload.de/image.php?img=p1011647mediumxys5c.jpg”\>
[pic5](<a) href=“http://abload.de/image.php?img=p1011646mediumnfoaq.jpg”\>
I have to make a correction on my “review” post.
The charging port on mine does *NOT *work.
If the light is on and you plug the USB cable in your PC the light turns off - so I assumed it started charging.
But it doesn’t, nothing happens. I had it plugged in for half an hour, checked the battery and nope, nothing.
Maybe I’m doing something wrong here but the manual is completely and only in Klingon so I just don’t know.
O well, I might me changing the driver anyway so…….
Cheers,
Nico
So, as promised I measured the throw (today) and guess what? It’s not bad at all.
I measured 230+ Kcd with an almost fully charged Efest IMR 26650/3500.
In other words: more then what the Thrunite Scorpion V6 does at half the price.
I don’t have the latest and best 6000mAh cells, so with those it would be a little better stil.
Also, I haven’t modded it at all yet. 230+ Kcd stock is nice, very nice.
If a little tweeking can get it to around 250Kcd I’ll be quite happy.
Next I will bridge both springs and replace the wires from the driver to the led and post the results.
Cheers,
Nico
That sounds great. I’m really impressed. Thanks…
