IIRC there was a suggestion that Amutorch was affiliated with Maxtoch because of some Maxtoch MCPCB seen in their light.
Lumintop Prince SS ordered .
Thanks for the deal !
Guess that was the last one. Banggood shows out of stock
I ordered one yesterday. My Prince Mini fits in the side pocket of the holster and they will make a great matched pair to carry when in polite company.
Just making a short comment.
My Astrolux S41S quad-Nichia is fairly recent (November 2017), the one I got appears to be Nichia 219B (I’ve posted the pic in another thread), despite the BG product description giving conflicting 219B and 219C descriptions. So at least for the S41S version, it’s still using 219B. Not sure about the S41 aluminum version though.
Original Xiaomi Hybrid Pro Three Drivers Graphene Earphone Headphone With Mic For iPhone Android
Use new coupon code 9c4ff9 to drop the price by -$10.80 to $16.19
SHARP EAGLE ZQ-303 445nm High Power Blue Beam Laser Pointer And Laser Sword
Use coupon code 16b823 to lower the already promotional price to only $20.39 (-$19.60)
Please take appropriate precautions as this laser is powerful enough (1300-1500mW) to cause serious harm.
Offer is valid until December 31st.
CooYoo Fermion XP-G2 Stainless Steel 130LM USB Mini LED Headlight Flashlight
Use coupon code HCYFE to lower the price from $32.99 to $16.82 !!! (-$16.17)
Yunmai Y3 T6 5Mode 1000LM OP Reflector 18650 EDC LED Flashlight
It’s now in flash sale for only $2.79 !
Offer expires in 7 days and 9 hours.
Keep in mind that the LED is probably not genuine Cree but some Latticebright or other clone. You get what you pay for.
But if you need some potentially disposable 18650 flashlight - this might be good enough. See reviews @banggood product page - there are some pictures.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
It’s now in flash sale for only $35.95
Offer expires in 6 days and 10 hours.
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65 |
$7.56 |
$7.47 |
$7.38 |
$7.20 |
CPFItalian-5ANNI A01 Copper Nichia 219B 102LM AAA Mini Waterproof Keychain EDC LED Flashlight
Use coupon code 808b65 to lower the price to only $8.51 !!! ($28.99)
This is clearance price! Once it’s gone it won’t be available again.
Astrolux M02 XP-G2/XP-G3/Nichia 219C 100LM USB Mini LED Flashlight
Use coupon code f8770f to drop the price to only $7.49 ($29.95)
Original Xiaomi MiJIA LED Smart Infrared Human Body Motion Sensor Dimmable Night Light For Home
It’s now in flash sale for only $8.99 ($25.19)
Offer is valid until January 8th.
Original Xiaomi Mijia LED Smart Bluetooth WiFi Control Bedside Light Sunrise Sunset Simulation
Use coupon code XMLED77 to lower the price to $45.64.
Lowest price to date (-US$9.35).
This is second (upgraded) version of Xiaomi bedside lamp. It now uses RGBW LEDs - White ones are Osram LEDs with CRI up to 95.
Second version has gold colored base and now it can communicate also via Wifi (first version was Bluetooth only) and can be paired with MI Home and controlled via voice commands and automatic events (for example light color can indicate room temperature etc.)
- 10W power
- adjustable CCT: 1700K - 6500K
- dimmable
- color change
- touch control
- smartphone control
- Bluetooth 4.2 BLE
- Wi-Fi IEEE 802.11 b/g/n 2.4GHz
- Lamp Input Voltage: 12V, 1A
- AC power adapter: 100-240V, 50 / 60HZ, 0.5A
- Size: 100 x 100 x 221mm ( ~4” x 4” x 8.7”)
Klarus G20L XHP70.2 P2 3000Lumens Dual Switch Brightness USB Rechargeable LED Tactical Flashlight
Coupon code is available for $39.58 discount.
» Request via PM here«
- Cree XHP70.2 P2 LED
- max 3000lm and 300m range
- USB rechargeable with 2A fast charging
- remaining battery capacity indicator (LED inside side switch)
- 2 switch design (tail click + side click)
- one touch turbo
- one touch low
- Intelligent Temperature Protection System
- included 5000mAh 26650 battery
- holster, lanyard ans USB cable included
Astrolux E02 XP-L 900lumens 8modes EDC LED Flashlight 18650
Use coupon code 9975d8 to lower the price to just $9.68
This is clearance price! Last 15 pieces in neutral 3D tint
Coupon is valid until December 31st.
VIOFO A119 V2 Version 1440P 160 Degree Wide Angle Car DVR With Gps Black
Use coupon code fa90e5 to lower the price to $67.19.
This is one of the very best car DVRs with built in GPS in value segment. It has many good reviews, video quality is comparable and sometimes better that brand DVR worth 2x the price - search youtube for sample videos to see for yourself.
It’s also very inconspicuous when mounted on windshield as it lays flat next to mirror mount.
Coupon can not be used on wholesale orders.
It works fine here.
Astrolux K1 XP-G3+365nm UV+Red LED 350LM New Driver USB Stainless Steel Mini LED Keychain
Version with XP-G3 is now in flash sale for $16.95 ($32.95) until January 2nd.
