Welp, my AA Tool arrived last night so I did some quick comparisons to the Thrunite T10 and “new” Thorfire TG06. No hard review, just some quick observations and tailcap data.
On AA, the Tool is just that…a tool. Waste of time. Pathetic output. So I stopped right there with any AA comparisons.
14500 - AA Tool is bloody floody BUT it does so with a defined large hotspot meaning it has some throw with that flood as well. At roughly 75 feet it’s got a well defined hotspot about 12-15 foot wide and it illuminates enough to be very usable. The T10 by comparison just kind of puffs out into an unusable light vapor past 40ish feet. My TG06 (Even before dedome) has a well defined hotspot that is still tight at that 75 foot range with a not very bright spill. The TG06 can stretch out to just about 150 feet but starts to be unusable at that range as it runs out of horsepower.
So, the Tool seems to be the brightest of the bunch, but has the lowest tailcap draw…about 1.3 amp. The TG06 the highest at 1.8-1.9. I’m chalking it up to more/less efficient drivers. What they are seeing at the LED I have no idea. I think a dedomed Tool will end up being a much better light over all than the other two and it’s easily the most compact even with the clicky tail on.
The SF14 will be here soon, and I have a feeling it’s going to be a TG06 clone with maybe less throw and more usable output. Once I get the SF14, I’ll see what I can put together for a decent comparison.
I also compared the SF14 with the Tool AA (both with 14500) and…the SF14 “wins” in almost all the things regarding output and tint.
I’m not “defending” the SF14 or the brand, but I can say that so far it is a very good 3 mode budget flashlight.
I find it difficult to find a good AA light under $20, while it’s relatively easy to find a good lithium-ion light for under $20. I think the drivers are more complicated in (good) AA lights, which add to their cost.
One thing I haven’t seen on this forum is a group buy for a good, inexpensive 1xAA light. I’ve seen them for AAA lights, and for 4xAA lights, but never a 1xAA. Maybe I’ve missed them? Or maybe there’s not much interest?
Granted, good is relative, and I haven’t ever tried that UT01. Most of the “under $20” AA lights I’ve tried are the cheap sipik type lights, for a few dollars. While they’re okay for the price, they’re not very sturdy, and they have awful cool-white emitters.
For 1xAA lights, I mostly use Zebralights, which are well above the $20 mark. The cheapest “good” AA light I have is an L3 Illuminations L10 with a Nichia 219 emitter. IIRC, I think it was $19.99.
I just haven’t seen a lot of AA lights under the $20 mark, that have good quality and a neutral-white LED. Some people like cool white, but I find it looks too industrial to me.
Hum, when you mean “AA”, you mean “only” AA (alkaline/Ni-MH), not supporting14500 batteries?
Because there are some neat 2017 lights AA size, also supporting 14500’s . I bought some this year and I am happy with almost all of them!
If you are only talking about AA (alkaline/Ni-MH) lights, not 14500, yup the Zebralight seems to be the most advanced, putting 500 lumens (maybe more?) of a single Ni-MH cell!
My vote goes to the UT01. I have 2, one in each tint and haven’t had any insurmountable issues with them. Just ordered a spare NW for $9.99.
What I like (in no particular order):
reversible deep pocket clip
reversible body (allows switching clip orientation without removing clip and scratching anno)
decent low mode
400lmn high w/ AA, 800lmn w/ 14500 is very serviceable.
AA/14500 support. Paper clip mod resolves issues with protected 14500
Good modes and programmable
Very affordable
compact size
available in warmer tint
I would have considered the Klarus Mi7 a possible contender, but my had horrific parasite drain (emptied batteries in a day) and Klarus did nothing to help. Even so, I think I’d still prefer the UT01 because of the reversible clip, programmable (and more) modes, UI, better low mode and overall feel. I wish the UT01 had a better switch. In fact, UT01 with a Mi7 switch would be hard to beat, in my book. Jet-1 is also a contender, but the clip is similar to the Klarus, only 3 modes and again, low not low enough.
At $20, I think it’s pretty hard to touch the UT01. At $9.99, it’s a no-brainer.
For me AA means basically just NiMH, if i need capabilities of Li-Ion I pick 18650s.
I find 14500 kind of unnecessary and very underdeveloped cells compared to 18650’s . To me NiMH is ok for any AA. :partying_face:
I have the same approach. When I need the brightness of 14500 I’m usually hiking in the dark and also need longer run time. 14500 doesn’t provide that and the little lights run into thermal issues anyway. This is where I like the Zebralight approach of efficiency and good brightness on AA.
1. It can transform into an angle light (rotate the head 90 degrees) or use as a straight handheld.
2. It has a magnetic base
3. Uses ANY AA battery. (I use 14500 for max output) But in an emergency can use a regular AA.
4. I can make it a headlamp by rotating the head and using the Olight headband H2R Nova Headband (uses a magnet in the cradle for fast placement and has a silicon strap to secure)
But I have also been thinking of the Klarus Mi7 (glad to see it mentioned several times here)
I simply LOVE this Rofis! Best all around AA light. (IMHO)
My wife is carrying an 18650 light in her purse and notified me last night she wanted a “smaller light”….so here i am on this thread.
I would like a AA/14500 light with usb charing built in one way or another (either in the battery or on-board charging. I see many lights suggested on this thread but very few have the usb charging option. Any suggestions for me? Budget please less than $30.
I am also open to an even smaller light than 14500.
Can someone help please?
Some have in-built charge, and I guess others have rechargeable batteries!
They are sold in several places (I normally search in AliExpress) but there other places for sure!
Also, if you want a small 18650 light with in-built charger, take a look at this thread: Folomov EDC-C4
The Jetbeam E10R is an extremely nice and small light and it features regularly in deal threads for less than $20.
The big flaw in that light is that charging a NiMh battery (like AA Eneloop) via the USB-port does not go well, the charging stops at 70 or so % from full. But if you use a 14500 in it (which has better energy density anyway) charging is fine.
