[Sale] Buck drivers 20, 21, 22, 24, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
The driver for MF02 XHP35 LED is 2.5A same as the GT, same UI
for XHP50/70 can be higher current
I am discussing with DEL the needed changes
So far Buck frequency changed from 800 to 500kHz
input and output caps doubled, the design already has pads to fit 2 caps instead one
Diode 3A to 5A
inductor from 6A to 15.5A
6-8A should be no problem to get to
If I understand correctly:
In currently state this “BLF GT” driver with 12V/2,5A can run a xhp35 about 2500lumens, xhp50.2 at 3600lm, 70.2 at 4400 lumens (from Texas Ace’s charts).
The modified version of this with 12V/6-8A can run a xhp50.2 at maximum (5000 lm) , 70.2 at 8500-9500 lumens at 6-8A. Maybe kill the xhp 50 at 8A, and will it kill a xhp35 already over 3A? So is is not recommended using this high current driver with xhp35?
The drivers are build for the current you ask for, so its like you want 2A or 4A no problem to change that on every order
Just going over 5A needs better parts that add cost
Keep in mind those current numbers are for keeping a high efficiency, of course you can get more out than 5A of the original design, but the efficiency goes down and heat up
Possibly interested. Not quite sure if I’ll keep the light or not yet.
But thanks for your commitment for the community!
hmmm im tempting to get this driver too but ill wait for others mod their lights
Intrested for 1.
UI question.
Will this have the ramp stopping short of max, with double tap for turbo?
If so, roughly what would the % be when built for 8A xhp70.2?
Thinking I may have to get one of these along w/a couple more of the TA drivers.
The ramping can be short of 100% or be programmed to 100% as the Q8 as you wish
the code for GT is 201/255 for max ramping table
paid already
If no mod the battery carrier, Keep 2S2P.
Can be used in 6V for XHP50 or XHP70?
You need to use a simple fet driver , the Mf-01 driver lexel builds can be used .
2S/2P carrier and 6V LED can be used with normal parts up to 5A with lowered buck frequency
with upgraded parts about 8A
of course this might be well enough for a XHP50.2, but rather poor for a XHP70.2
Those are the currents to stay safe well within specification of the parts, of course it is possible to get out more but then no guarantee to operate without any issues over a long time,
if you want it just lower the sense resistors as usual for buck/boost drivers
Im definitely interested in a driver for the MF02, i have on on the way.
The first boards have arrived
been busy yesterday and today
12 MF02 2.5A drivers
2 MF02 6A
1 TN42 and
1 TN40 12V 8A
I think this should show the carrier modification pretty well
added Haikelite MT07S XHP35/XHP70 driver
I made a 30mm layout that could be extended in my board program to the nessesary size or grinding down the 42mm TN42
The Curoi should be 38.5mm, if the edge clearance is small the TN42 could fit
I PMed everyone that was replying in this topic if I missed you please PM me
you are on the spreadsheet in line 70
So I did further testing of the drivers
With 2.5A Output I get on my bench test LED XHP70.2 12.31V
This means 31.02W output
to get this output the driver draws 2.075A at 16.14V
33.49W
so we ge an efficiency of 92.6% for turbo
Sounds pretty good to me Lexel.
