I’ll add that you could also rip the shrink wrap when twisting on the tube. If that exposes both the positive and negative terminal (the edge of the cell), then poof!
Joey Adams… I am confused. I thought you told us several posts ago that you had your Q8 worked on back in November? ?? Am I mistaken???
Have you used it since TomE worked on it???
Oh yea, over and over. Last contact whatsoever was on 11/13/2017. He said modifications were finished and he just wanted to run further tests. I have repeatedly sent pms and emails. I only opted to post publicly after 5 weeks of silence. I hope he is ok, I assume he is though since he is still posting on various threads here on the blf. I admit to be completely perplexed with his silence. I am sure there is a simple explanation, I just haven’t heard it.
30Q are one of the best of the high drain cells. I got 4 button top 30Q for $20 shipped from Banggood on sale. Right now they cost a bit more.
VTC6’s and VTC5’s are also top rated.
Do you know of any electronic repair shops near you. It would take them literally 15 seconds to add a blob to each one. Probably do it for free as well.
Have you considered buying cheap iron and solder and learning to do it yourself? It’s a good thing to know if you like messing with flashlights. Then you can do basic stuff like swapping emitters and drivers. Maybe do some spring bypasses as well. It just takes practice.
I understand that a nice flashlight is out there that you would like to have in your hands but…
It can be hard for a hobbyist to have obligations connected to the hobby. Me, I’m bad at it, I promise people things (usually sending flashlight parts that they even have paid for) and then sometimes it takes me weeks to get to it or I even forget it so I need to be reminded. I’m not proud of that but doing stuff like that takes more effort than simply writing posts on BLF. And because it is not a job but a hobby people who do stuff for others need to be given some slack.
Strange. Tom E has been online quite recently; minutes ago. Frustrating for you Joey. I don’t know what to suggest? Should a bunch of us send “hope you are well; Joey needs your attention”PM’s?
Sony Konion US18650VTC5A 2600mAh - 35A button top
Sony Konion US18650VTC6 3120mAh - 30A button top
LG INR18650-HG2 3000mAh - 20A button top
Samsung INR18650-30Q 3000mAh - 15A button top
Sanyo NCR18650GA 3350mAh - 10A Button Top
The Q8 is a high drain light. It can pull 15 to 16 amps total. So that is 4 amps per cell.
Those are all good. I would go for the ones with a good price.
The Sanyo GA has a chemistry that gives it longer run time and a bit less amp output, so it would probably be last on the list. If you only care about max brightness. If you don’t mind a slightly less max lumens, then the GA will give a bit longer run time.
