⫹ N E W ⫺ LUMINTOP GEEK ✺ Rechargeable Multifunction Flashlight Interest List
The LUMINTOP Geek LED Keychain Flashlight born and designed for the enthusiastic pursuit of ultimate craft and superior quality, which combine the multiple technology and functions in an extremely compact size. Aluminum alloy with CNC integrated processing creates a solid and reliable body. Key shape design, compact in size allows one hand easily control. Dual lights lighting with a max 350 lumens output, provides more lighting manners options in your camping, walking, reading or EDC gears etc. Built-in lithium polymer battery and Micro USB charging design allow easy to charge the light without a charger. Battery and charging indicator on the side shows the approximately battery percentage clearly in green, blue or red. Dual switches operation, lock-out function, big key holder, IPX-6 waterproof classification, all these make Geek a masterpiece in the industry.
Features
  • Utilizes Cree XP - L HD LED for front light, and high CRI Nichia LEDs for side light with a lifespan of 50000 hours
  • 4 output levels plus Strobe, SOS and Beacon for front light, two modes set for side light to meet your luminous needs in different situations
  • Made of aircraft aluminum alloy with CNC integrated processing, 1.5m impact resistance
  • Autokey structure design, compact and multifunctional
  • Dual switch for one hand operation
  • Micro USB rechargeable with charging indicator, you don't need to buy batteries
  • Built-in 3.7V 530mAh Li-polymer battery, max runtime up to 43h
  • Battery level and low power indicator to protect your flashlight from hurts
  • Lock-out function to prevent accidentals activations
  • Waterproof IP-X6, suitable for rainy days
Specification
  • Emitters: Cree XP-L HD,Nichia
  • Emitters Quantity: 6
  • Luminous Flux: high / strobe / SOS / beacon 350LM; mid 125LM; low 25LM; moonlight 1LM
  • Luminous Intensity: 1225cd
  • Color Temperature: 7000K + 4000K
  • Feature: Compact,Lightweight,Lock-out Function,Portable,Waterproof
  • Battery Type: Lithium Polymer
  • Battery Quantity: 1
  • Battery Included or Not: Yes
  • Rechargeable: Yes
  • Waterproof Standard: IPX-6 Standard Waterproof
  • LED Lifespan: 50000h
  • Working Voltage: 3.7V
  • Beam Distance: 50-100m
  • Impact Resistance: 1.5M
  • Product weight: 0.0510 kg
  • Product size (L x W x H): 6.00 x 3.60 x 1.60 cm / 2.36 x 1.42 x 0.63 inches
  • Package Contents: 1 x LUMINTOP Geek LED Flashlight, 1 x English User Manual, 1 x Lanyard
If you are interested, notify in this thread (not in PM)
My main thread: GearBEST.com Coupon Codes&Flashsales
LUMINTOP GEEK - interest list
    1. Fin17
    2. netprince
    3. glockboy
    4. Kodachrome40
    5. FlashIight
    6. Boro
    7. Bruno28
    8. weklund
    9. ecobalans
    10. Uriah
    11. carmantl
    12. sandanbob
    13. ...
    14. suratyu
    15. leroycp
    16. ulfm1
    17. Dewalt101
    18. aremihc
    19. delete
    20. eric800
    21. SoulCraves
    22. Firelight2
    23. Muto
    24. cloggy
    25. Kozy
    26. shrike3612
    27. netgear68
    28. shimey
    29. vas
    30. Finnno
    31. Stittville Ed
    32. apt323
    33. saypat
    34. westcoastwonders
    35. pc_light
    36. lamper
    37. Sergiu
    38. lamacik
    39. XXX-Man
    40. Athlon2350
    41. uncle_muscle98
    42. derfyled
    43. Hakuo
    44. Illumenated
    45. Calaveras
    46. weklund 2pcs
    47. I_SpY
    48. cloggy
    49. M78
    50. charles lin
    51. Inegve
    52. ohbreeeezy
Interested depending on price.
This would be interesting if it had a Nichia for the main LED as well as on the side — it seems strange to put 5 Nichias on the side and then put just about the coldest XP-L you can find on the front.
don’t think u can go low enuf on this one
Interested.
I’m interested. Depending on price.
Interested depending on the price!
:white_check_mark:
interested depending on price.
Yes please.
a very nice looking light. hope the sidelights, red green blue are not constant on.
wen the price is right i want one.
The LEDs on the same side as switches? I will blind myself while turning on :slight_smile:
Also interested depending on the price
I’m interested!
Add me to the interested list, thanks.
Interested
Interested
Interested, depends on the price
thank you!
Interested
