BLF AA-Y4E Review
OMG 360L!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
However I dont like the TIR optics. And they are made of plastic. Also dont like the bad quality of some units, and moon and low modes not well spaced.
OK MrLite. When a better light?
The review gives me hope, after the rather bad comments in some of the other posts here. 160 lumens on a AA sounds very good. I ordered fife of them, but not because I thought it would be the best light in the world. I orderd them, because they are supposed to be somehow uniqe and who knows, maybe a collectors item one day.
I ordered this one based on the first one [ more evenly spaced output ] , and was hoping they had just reversed the modes ..
I dont mind the optic , but Im not sure I can justify buying more , one is enough , I just wanted to have a sample for comparison , but it turned out a little better than expected [ yeah those previous comments , which may be related to the first batch ? ] , this one is from the second batch ... And so may be a little more refined ? All I know is so far so good ..
Those figures are amazingly high. And I imagine the rather large size of the AA-Y4E will probably help to dissipate the heat more so than other smaller lights.
I wonder how many batches are out there. For example, mine has the spring in the head like Matt's, but mine has dark red colored O-rings.
It sounds like the Lightake versions were the newest and therefore the buggiest. It also sounds like some of the earlier versions from Mrlite have contact problems. But assuming that yours doesn't arrive with a showstopper bug like not turning on, this is fundamentally a very good light.
Don't you mean the oldest. it came out first?
Lightake did offer the first Mrlite J4. I believe this is the first prototype, sent by Lightake to Matt for review. Notice that it doesn't have the spring on the head. Additionally, as mentioned elsewhere, Lightake's version has the modes backwards, and is not labelled as a BLF AA-Y4E.
Very encouraging review and I'm hoping my light comes from the same batch as Old's as we both got the same not in stock message and back in stock and shipped message around the same time.
Any sense on if this light can run on a 14500 for extended periods without damaging the light? Thanks for the review.
I ran mine for 35 minutes on a 14500 without any problem (stopping for a minute every 5-10 minutes to take a reading on the battery). That's how long it took for the battery to be below 3.6V. The light didn't get as hot as some do, but was defnitely warm.
The only thing that worries me a little about the high output is that the LED may be over driven [ low vF LED ] , and how that might affect the LED when used with a 14500 on high ..
The performance with a AA is just wonderful , and comes close to my CR123A and 14500 EDC jobs , time to go to work ....
Back in about 9 hours ..
Matt
I did receive my light tonight and I must say that I am pleased. Unlike Old’s, I have orange o rings for my light but I do have the spring coil in the light head. Threads are well lubes and I actually like the feel of the metal clicky.
The output of this light is just wonderful and though this light gets the job done on a Nimh battery, it’s a star running on a 14500. As noted by all, the low modes are too close but I am able to tell the difference when cycling through in darkness. My only real complaint with this light is I hear a rattle in the tail and in the head when I shake them and there doesn’t appear to be anything I could tighten to stop the rattle.
For $17 I am very happy with this light.
I recieved mine from manafont today. I am VERY pleased with it on crappy AA batteries which is all i have until my 14500's arrive. It has a spring, better seeming o-rings, MUCH better and cleaner beam, and it is brighter than the mr.lite J4 4-mode that I ordered from lightake.
Very pleased with it, and can not wait to see the performance on 14500's!!
It is weird to me that the beam is so much nicer than the 'identical' J4.
This light also had a slight contact issue , but a bit of solder fixed it [ better contact with battery tube ] ..
And yes , the output is outstanding , it actually matches my R5 P60 lights with a 14500 .. [ The output with a 14500 in this size light is insane ]
I can only imagine I got a freaky good one [ kind of nice for a change ] , and I hope everyone else gets a good one as well ...
Where exactly did you put the extra solder? I have one that doesn't work at all and the other that works most of the time but sometimes has what I think is a contact issue. Thank you.
Let me take a picture ....
http://www.imagebam.com/image/249a08107563793
Ok what I did was to put a blob of solder on the neg part of the driver board , and then extend it towards the side of the pill , so that the battery tube makes contact with the solder ...
Mine has no solder at all. Did you have to take it apart to figure out where the negative part of the driver board is? Sorry for the dumb questions but when it comes to the inner workings of a flashlight, I am dumb. Frown I still have yet to learn how to replace my first driver board and/or emitter + circuit board. Undecided
the negative is the outer golden ring of the driver, the positive is the center part where de spring is.
Aloha and welcome to BLF!
Thanks Thoth.
Hi Thoth, thanks for joining! Enjoy your time here.
Thanks for the warm welcome!
I have been reading through the forum, and I am really liking what i´m seeing.
I going to buy one of these Mrlite, it will be my first light with a collimator lens ;)
