M4D M4X deals - Astrolux WP1 and WP2 LEP
sure
please send me a mail to martin@m4dm4x.com ;)
Martin,
Need a BG code for NCR18650B 3400mAh 3.7V 18650 Protected Li-ion Battery - 4 PCS
GB will not ship to AU
Cheers mate.
subscribing, great work M4DM4X
Will there be a new discount code for the BLF Q8 again (the previous one already expired)?
Hi You got a code for Thorfire S70s ?
I second this. I just went to buy one and the sadness is real lol.
i hope asap
most codes need to be renewed...
Code for Skilhunt H03 please, existing code is expired. Thanks M4DM4X
Hi Martin, is it possible to have a code for an Olight M2R? Thanks
Olight did block us from supply - they want their prices high...
another hand for the BLF Q8 code. Thanks
Hi, can you get code for this knife?
https://www.gearbest.com/pocket-knives-and-folding-knives/pp_1525963.html
Thanks
Banggood are having a flash sale for $49.95 at the moment. No code needed.
Too bad for Olight, thanks anyway
Hello my dear friends!
to start the weekend i have some great deals for my members:
Folomov prices are too good to be posted public ;)
Folomov Tour B5M
XHP50.2 2500LM Multifunctional USB Rechargeable Tactical LED Flashlight 26650
Package included:
1 x Folomov Tour B5M XHP50.2 2500LM USB Rechargeable LED Flashlight
1 x USB charging cable
1 x Flashlight holster
1 x Lanyard
1 x O-ring
1 x Clip
Folomov Tour B4M
XP-L 1200LM Multifunctional USB Rechargeable Tactical LED Flashlight 18650
Package included:
1 x Folomov Tour B4M XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
Folomov Tour B4
XP-L 1200LM Multifunctional USB Rechargeable LED Flashlight 18650
Package included:
1 x Folomov Tour B4 XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
WUBEN TO10R only US$30.15 $45.00
3x XP-G3 with high CRI 650LM Dual Switch Magnetic Tail Rechargeable Stepless Dimming LED Flashlight
Package included:
1x WUBEN TO10R Magnetic Tail USB Rechargeable LED Flashlight
1x Built-in 16340 Battery
1x USB Charging Cable
1x Lanyard
1x Mannual
1x O ring
Astrolux K1 only US$ 16.95 $26.05
with code MAXK1
XP-G3+365nm UV+Red LED 350LM
NEW DRIVER USB Stainless Steel Mini LED Keychain
after a long time the BLF Q8 is on stock again!
A real monster flashlight and result of a flashaholics project!
BLF Q8
4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
my Code: M4DQ8 my price: US$ 46.50
(MRSP: ~$80)
Rofis MR70
XHP70.2 CW+XP-G2 NW
3500LM Dual Light Multifunction Rechargeable LED Flashlight
incl. ROFIS 26650 5500mAh
– presale only US$ 62.69 (4 members)
Features:
● Uses a 26650 5500mAh high-rate discharge lithium battery,the main light and side light dual light source design.
● The main light utilizes XHP70.2 P2 CW LED,output up to 3500Lumens.
● Side light utilizes XP-G2 R5 NW LED,maximum output to 200Lumens
● One-touch control all function,it is easy to operate.
● Body with Micro-USB charging,which supports up to 2A charge.
● Can be used as a mobile power supply,use the USB adapter provide power to other devices,the maxmum output to 2.2A;with a dischargercapacity reminder.
● Users constant current circuit, with high battery effciency,stable output,no flashes.
● Anti-reverse design to prevent incorrect battery installation causes the circuit damage.
● Battery power detection,charging instruction,low battery reminder function.
● With locking function prevent accidental illumination.
● One-pieces shell,the structure is stable and reliable.
● Made of aero grade aluminum alloy,premium Type III hard-anodized anti-abrasive finish.
● With flashlight self-location function.
Charging:
● Before charging,ensure that the battery is correctly loaded into the flashlight, and the tail of the flashlight has been tightened.
● Insert the charging cablle Micro USB port into the flashlight charging port,then insert the charging cable USB port into the power port to recharge.Charging light red indicates charging,green indicates charging has been completed.The flashlight can only turn on side medium mode while charging.
Package included:
1 x MR70 flashlight
1 x ROFIS 26650 5500mAh battery
1 x Charging cable
1 x Micro USB to USB adapter
1 x Holster
1 x Lanyard
1 x USB cover
1 x User manual
2 x O-ring
Maybe get a coupon for an s41s?
i find only for S42S
i got some often asked deals renewed ;)
find the codes and prices here
Brand model = my Link (please use)
HaikeLite NEW SC02 II
nitecore P12GT
Klarus G30
Nitecore MH20GT
nitecore TM16GT
ADEASKA SQ4
keeppower ICR26650 5200 for Convoy L6
