Coyotehawk will add your name to his sign up list. You’ll see your name when he does the next update. It will be sometime mid January when you are emailed with the details of where to go and how to order.
You can also buy 8 of the Samsung 35E batteries for $40 at the same time as you buy the light. No sign up necessary for those. There are plenty of batteries in stock.
Although i don’t have much experience with dedoming XHP35 leds ( ive done only one), i find that nitro paint thinner works very good, at least in my case.
It removed the dome completely without any leftovers what so ever. Someone, cant recall tho who was (Kawi or TA) said that cleaning the remaining phosphor on the side of the die will also help for better looking beam.
GOOF-OFF works good if it’s available! Just try and cut right above the wires and then soak it in the goof-off. I have had success using this and letting it sit over night. Just make sure you use a small glass container. It will eat plastic material
Just got my tracking number. So should be here this week.
As I’m part of the team I was supposed to get the GT a bit earlier but for some reasons it was delayed.
I can’t say if my shipment is part of a larger shipment to the EU or if it’s a separate shipment just for me.
Seems like false alarm for Europe, cose only thijsco19, and Martin got tracking numbers and they are team members…
Anyway it will be soon no hurries, and nice video btw :+1:
