Blazer296
(Blazer296)
December 27, 2017, 5:07pm
47
Intrested for 1.
UI question.
Will this have the ramp stopping short of max, with double tap for turbo?
If so, roughly what would the % be when built for 8A xhp70.2?
Thinking I may have to get one of these along w/a couple more of the TA drivers.
Lexel
(Lexel)
December 27, 2017, 5:09pm
48
Blazer296:
Intrested for 1.
UI question.
The ramping can be short of 100% or be programmed to 100% as the Q8 as you wish
the code for GT is 201/255 for max ramping table
steel_1024
(steel_1024)
January 2, 2018, 12:41pm
50
If no mod the battery carrier, Keep 2S2P.
Can be used in 6V for XHP50 or XHP70?
giorgoskok
(giorgoskok)
January 2, 2018, 12:45pm
51
You need to use a simple fet driver , the Mf-01 driver lexel builds can be used .
Lexel
(Lexel)
January 2, 2018, 1:14pm
52
2S/2P carrier and 6V LED can be used with normal parts up to 5A with lowered buck frequency
with upgraded parts about 8A
of course this might be well enough for a XHP50.2, but rather poor for a XHP70.2
Those are the currents to stay safe well within specification of the parts, of course it is possible to get out more but then no guarantee to operate without any issues over a long time,
if you want it just lower the sense resistors as usual for buck/boost drivers
Skuffe
(Skuffe)
January 9, 2018, 2:34pm
53
Im definitely interested in a driver for the MF02, i have on on the way.
Lexel
(Lexel)
January 9, 2018, 8:02pm
54
The first boards have arrived
Lexel
(Lexel)
January 12, 2018, 12:00am
55
been busy yesterday and today
12 MF02 2.5A drivers
2 MF02 6A
1 TN42 and
1 TN40 12V 8A
I think this should show the carrier modification pretty well
Lexel
(Lexel)
January 13, 2018, 6:26pm
56
added Haikelite MT07S XHP35/XHP70 driver
Lexel
(Lexel)
January 14, 2018, 10:35am
57
I made a 30mm layout that could be extended in my board program to the nessesary size or grinding down the 42mm TN42
The Curoi should be 38.5mm, if the edge clearance is small the TN42 could fit
Lexel
(Lexel)
January 14, 2018, 10:42am
58
I PMed everyone that was replying in this topic if I missed you please PM me
Lexel
(Lexel)
January 14, 2018, 11:49pm
59
you are on the spreadsheet in line 70
Lexel
(Lexel)
January 15, 2018, 3:34am
60
So I did further testing of the drivers
With 2.5A Output I get on my bench test LED XHP70.2 12.31V
This means 31.02W output
to get this output the driver draws 2.075A at 16.14V
33.49W
so we ge an efficiency of 92.6% for turbo
MRsDNF
(MRsDNF)
January 15, 2018, 5:21am
61
Sounds pretty good to me Lexel.
Newlumen
(Newlumen)
January 16, 2018, 1:08am
62
Hey blf, we are going to mod the astrolux mf-02 to the best… of course xhp35 hi. Which parts do i need to order ?? Do i need a new sink pad? Thanks
Lexel
(Lexel)
January 16, 2018, 6:23am
63
You can use old Sinkpad it is pretty good
Just the LED seems not to be pretty good flux bin looks from my measurements like a D2 flux bin
You need just the driver, maybe also interested in my 2x2 LED board that supports up to 4 different LED colors
338LM
(338LM)
January 21, 2018, 5:51pm
64
I have MF02 coming, would like to do this mod. I also have electrical school baground and soldering irons etc home.
Still bit unsure what will I need? Is this bolt-on mod requiring only battery serial modification for 12V supply with new driver?
Lexel
(Lexel)
January 22, 2018, 1:28pm
66
338LM:
Battery carrier needs mod as shown so from 7.4 to 14.8V
Then it is just replacing old with new driver
