I’d vote for these modes as well, and for the over discharge protection (I only have/use unprotected 14500 batteries :person_facepalming: )
For the LED, I would say Nichia or XP-G2
Nice design! Here are my suggestions to your questions:
1, high- middle- very low or high- middle?
Always start on the lower mode. Don't forget a good low moonlight (moon - low - med - high)
starting on high or med is TERRIBLE, never do that, please
2,use 5050 LED or 3535 LED? I think the reflector is small, if we use a XML SIZE —-flood well; if use xpg2 /nichia 219 size—-have a well spot…
3535, so you can use the same reflector for xp-l, xp-g2/3 and nichia 219C
3,and the high CRI and normal LED are also need to be considered….
219C 90 CRI is always good, and there are few flashlights for AA/14500 that have this option (usualy high cri versions use older 219B). I personaly love the 90+CRI 219C 5000k
For regular lower CRI led, could also have the option of cool white and neutral white (6500k and 5000k)
That is a nice new version of the E3, nice with the SS bezel, still a bit fat (I like smaller AA-flashlights like the Lumintop Tool-AA or the Acebeam M10), but nicer already.
I hope that the design will not be copied.
What is the light output on a NiMh battery?
I vote for verylow-low-middle-high
3535 led for sure
high CRI Nichia219C is nice, but also low CRI in nice tint (Nichia or Cree or Samsung/LG)
I agree with all of what Persechini said (copied below) and djozz too. Those would be exactly my suggestions.
I would add as a few others have that I don’t like that it doesn’t have over-discharge protection. I understand it’s not easy as you want it to also work with Alkaline and NiMH cells but I think you need to seriously consider resolving that issue. As others have mentioned most people here have unprotected 14500 cells. Simply having the driver set to blink a few times and shut off if the voltage is 1.6V - 2.9V would cover most scenarios. Not perfect but much better than not having any form of LVP.
I think the host all come from a few factories.
ThorFire, Convoy, Sofirn, Jaxman, etcetera… get their hosts from the same factory / factories, i think.
I assume Mateminco makes all hosts for Utorch, Manker, Astrolux (but maybe not anymore), etc…
About the modes:
Best to start with MEDIUM.
Because medium is most usable.
This is somewhat accurate regarding hosts but you have too many lumped into the same basket.
Convoy and Jaxman get their hosts from the same factory. That’s why they both have such nice hosts. :sunglasses:
Thorfire uses a different factory and I don’t know about Sofirn.
Mateminco makes all the hosts for Astrolux but Manker broke away quite a while ago and use a different factory. The rest I’m not sure of.
As far as your mode tastes buddy we are on two different worlds but you have a right to your opinion. Personally, I hate lights that start on medium…but that’s just me.
I think Nichia 219c as the only option in warm / neutral is fine. Would be nice to have one brand which consistently has Nichia options. Wouldn’t mind if they dropped all Cree emitters except in throwers. The 219c seems good enough to make high CRI the default for most floody EDC lights.
