This is somewhat accurate regarding hosts but you have too many lumped into the same basket.
Convoy and Jaxman get their hosts from the same factory. That’s why they both have such nice hosts. :sunglasses:
Thorfire uses a different factory and I don’t know about Sofirn.
Mateminco makes all the hosts for Astrolux but Manker broke away quite a while ago and use a different factory. The rest I’m not sure of.
As far as your mode tastes buddy we are on two different worlds but you have a right to your opinion. Personally, I hate lights that start on medium…but that’s just me.
Probably the same or a similar driver / configuration as with the M2: Page Not Found - Aliexpress.com
Low > Med > High would be nice. No strobe.
I think Nichia 219c as the only option in warm / neutral is fine. Would be nice to have one brand which consistently has Nichia options. Wouldn’t mind if they dropped all Cree emitters except in throwers. The 219c seems good enough to make high CRI the default for most floody EDC lights.
Agreed
1. I prefer low, med, high. No moonlight. Some people want moonlight. Maybe you can make moonlight an option that can be changed by soldering a star on the driver.
2. I prefer XM size for more flood.
3. No PWM, please.
4. Is it easy to unscrew the bezel, so I can change the LED?
Best to start with MEDIUM.
Because medium is most usable.
I concur, as long as that medium is close to a 100 lumen value (for NiMH).
- Is it easy to unscrew the bezel, so I can change the LED?
Looks like it’s an integrated head design now. It will be a bit more difficult than the pill version.
AND THERE IS ANOTHER IMPORTANT THING TO DISCUSS. THAT IS:
1, high- middle- very low or high- middle?
2,use 5050 LED or 3535 LED? I think the reflector is small, if we use a XML SIZE —-flood well; if use xpg2 /nichia 219 size—-have a well spot…
3,and the high CRI and normal LED are also need to be considered….
I vote for
- verylow-low -> middle -> high
- high CRI 4000K-5000K
hi, thanks for your advice.
but,I think xpl hi is not a good choice. for:
1) xpl hi gives little flux than other LED with s lens, like xml, xpg. for example, the xpl hi in 3A, gives only 900 lms, less than the xml2 1100lms.
2) xpl hi leds’ advantage is based on its small core and big power. but if you want get it advantage, we need a bigger reflector. while E3 has a limited OD, the reflector only has a 16mm diameter reflecting surface. We should design products based on all datas, not our idea…… that is my opinion.
3)maybe xpl hd is propper, but I think in many situations, xpl hd is only a concept to talk, not too much advantage.
hi, I want make things simple.
I want moon light-middle-high.
As over-Discharge protection, AA/Ni MH we set a 0.9V stopping work protection,while Li Ion, how to do? so a good way to resolve it is adding protect board on 14500 battery.
hi , the fat SS bezel is because its structure, and there is also a O ring before the glass, so ……no way to make it more thin……
With a Ni MH battery, now the out put can upto 900+ mA. This value will be influenced by the quality of battery.
As LED, yes I also agree to 3535 led, XPG2, 219C, and LG 3535 are also Ok.
I only make a trial selling of new E3,
not old version.
All is according to the discription of the item page.
I prefer to make simple function lights. I am making simple and steady tools from begin……………I dont know what is BLF A6 either…and I also feel hard to make too complexd UI,
I think it is no doubt that: they copied us.
Jaxman E3 issued in Feb,2015. Only because of we are not famous brand, and we insisting quality not quantity, so we are not known as much as the cheaper flashlights brand.
One word, if they provide a selling record early than Mar 2015,I will apologize here.
Dont forget, Manker had copy us Z1 flashlight and titled it as a COMETA flashlights , and had been selling in BLF. It is just happend years ago….
https://budgetlightforum.com/t/-/39949
hi, really, only a few factories engaging metal machining in China, and most flashlight factory dont machine metal part themselves. This is according to economical principles.
We keep at least 2 metal machining factories. And as business partners, we are keeping very good relationship with our supplier. Our supplier never sell host to others without our permission. That is a base of corperation between any such kind of partners. If a metal machine factory do business by selling their custmer’s design, I think they will make good business at all.
As others brand related, I dont want to say too more. For ourselves,we never use the same design with other flashlights brand. We are just to be us,Jaxman.
Rgs
“Jaxman”, thanks for all the answers and explanations given
I guess this will be a top quality light!
May I ask you: what will be the diameter of the driver? 15mm, 17mm?
Also, do you intend to have the light glued?
Thank you very much, again, for your work
I have to agree with others on the moon/low/med/high. Small led footprint. And interested in driver size too.
I like the idea of a driver customizable by soldering/unsoldering stars. Quick enough to change, but no need to memorize mode group change instructions, and no accidental mode group changes. Also much easier and beginner friendly than reflashing, or even swapping a driver.
Subbed! Jaxman you have impressed me again! I want one! Lets see…. I currently own 1 Jaxman Z1 and two Jaxman E2L. It’s time for the E3!
Interesting to know the timelime of this design. I might just give the new E3 a go
The Jaxman E2L is one of my favorite lights. I consider it as a high quality light. I also own a Jaxman U1 and a M8.
Now I’m very curious about the new E3!
I’d like to see this one with a high-cri emitter. Moon-mode would be nice to have, indeed.
Pardon me but I’m still confused — is the E3 now for sale something different than what is being discussed here?
