I disagree with firedome comment. It is the best
Does anyone have a picture of an aluminum one stripped down ?
Someone has to have done it by now .
I agree.
and titanium tail cap
Why?
Only adds unnecessary costs i.m.o, and you get black, copper colour, black, silver gray… :confounded:
Mascuratum de-anodized a 18350 battery tube somewhere.
Not the best move by Hank IMO.
If he can make a profit out of the TI versions, that’s a good business move, there is a market for TI bling even with flashlights were it’s not ideal to say the least, back in CPF those TI flashlight commanded several hundreds of $ price from MCgizmo, Tain, or thousands from data and sold like hot cakes despite the same endless discussions about the inferiority of TI for flashlight application.
I myself have a TI fetish , not to the point of buying a TI flashlight (wich would go against engineering logic) but a lot of people do.
It doesn’t make the alu version disappear so everyone wins.
I guess my question is why wouldn’t ever manufacturer on the planet offer lights in the raw even before anodized since it’s cheaper .I’m guessing there’s a bigger market for it than they think .
I ordered a D4 titanium with 18350 tube and 4000K XPL HI. I ordered the “F” model (blue gold).
Definitely less practical than aluminum, but I liked that the 18650 tube has knurling on it.
Overpriced.
Some of us are trying to apply logic and reason, to a light that is purely an emotional buy.
there is no practical reason for a light that can get so hot it burns your hand, but people flock to buy multiple D4 lights
there is no practical reason for a light that is capable of thousands of lumens, but cannot maintain more than 500 for any amount of time, but people flock to buy multiple D4 lights
there is no practical reason for a light with a ramping interface that has no discrete, repeatable, lumen levels… but… D4 buyers flock like lemmings to the sea
there is no practical reason for a light that can drain an 18650 in 10 minutes, but that has not stopped the D4 from being purchased in higher numbers than any other light on BLF
the benefit of a Titanium body is that it insulates the hand from excess heat, except that using the switch to turn it off will lead to some heat shock from touching the copper head
then there is the PWM above 150 lumens, but who cares, regulation is overrated
Buy the D4 not because it makes sense, buy it because everybody knows it is the Hot Ticket
heheheh, sure, all on point (except ramping, which is actually great IMO)
I found it funny at first when I arrived at BLF that some lights were this high priced, until I ended up following enough external links to actual luxury or faux-luxury flashlights to realize what happens in the “outside”. Plus people show no lack of love for brands like convoy that are very good quality and very fairly priced. I’m ok with a titanium 10 minute hot rod at this price, it’s just not for me. I do have 2 regular emisar flashlights and am waiting on the third thou
Ok to add costs I want a light made from Gold head and silver tube and tail cap
Why?
Because I have here 5 unused ounces of it and its super cool to have blingbling and patina
And I will make sure I never loose this flashlight
Maybe they tossed out a high price to see where it stood.
Seems most here think it’s over priced, maybe they will lower it to a point it sells better.
waiting’ for king Richard to announce they are in stock!
Copper can also store more heat so it will get and stay hotter than anodized aluminum.
It is a common misconception that higher thermal capacity is bad because the item will need more time to cool down.
Higher thermal capacity mean that the item will take longer both to heat up and to cool down. If TC is increased and other variables unchanged, a light with higher TC will always have strictly lower average temperature.
A flashlight uses 3 cooling mechanisms:
- radiation to air
- conduction to user hand
- wind (with fallback to convection when wind is unavailable)
I have no idea how important is each of them. Would love to know.
Efficiency of each of them depends strongly on surface temperature.
But when temperature is software-limited, a limit on temperature becomes a limit on power.
The limit is not the same for different materials because:
- they have different emissivity
- they have different conductivity and thus surface temperatures are less even
Emissivity of oxidized copper is about the same as anodized alu. Polished Cu is worse, polished Ti even more so. I failed to find numbers for oxidized Ti.
In a pure copper light surface temps would be more even than in alu one.
In Cu-Ti the head will be much hotter than the rest.
With properly tuned heat regulation, peak head temperature would be the same as in alu light. Sustained output would be lower. But it’s possible that Hank didn’t re-tweak the thermal algorithm to fit the new host better.
BTW one interesting development would be to increase cooling by upping surface temperature significantly above what user can touch painlessly….in areas that user can’t touch. Like bottoms of deep fins. I guess it wouldn’t make a big difference, but maybe I’m wrong.
- radiation
to air- conduction to user hand
Convection (to air) is most significant for a flashlight in normal use. Radiation and conduction to hand are negligible in comparison.
Wind and convection are same thing….wind just allows for more convection than static air.
For the durability of titanium, especially the threads it’s worth a bit of a draw back in heat. Its going to be in my hand anyway, my hands will absorb heat slower that titanium can move it.
Just like my hands absorb heat slower than aluminium can move it.
But aluminium is softer than titanium, and will wear faster i imagine.
Why?
Because I have here 5 unused ounces of it and its super cool to have blingbling and patinaAnd I will make sure I never loose this flashlight
Do you think Swarovski-crystal encrusted platinum would retain heat in this light?
So copper conducts heat better but overall for a flashlight it’s worse? I’m having a hard time following XD
In addition to thermal conductivity issues, titanium has the clear disadvantage of undermining the tailcap lockout feature—an important one on this light.
If I’m not mistaken, there should be tailcap lockout. Current is interrupted at the tailcap PCB, and current does not travel via tailcap itself.
Do any of you guys realize what titanium and machining titanium costs? This is cheap for the size of the piece plus electronics, wages, and other costs.
As for appeal, why do people buy expensive cars, jewelry, sports memorabilia, etc…
