I’d guess that the focus would be a bit off, the optic should be a bit closer to the board. A bit of filing of the legs to extend the narrow bit should solve that but it does complicate the mod.
Apart from that, the attractiveness of such a board is a bit dependent on those nice offerings from Clemence, I hope that he is able to keep getting those nice leds.
That said, a triple E21A board sounds pretty cool to me.
Just tried 2 of them , with 2 Oslon black flat leds (LUW HWQP) .
The reflow was really easy , pads line up exactly and you can remove excess solder easily .
I made a simple setup in a Eagle Eye X6 , with a fet driver using a PSMN3R0-30YLDX fet (not really low resistance fet) . Soldering the wires on the mcpcb is tricky , thank god i have a soldering station with variable temp .
Unfortunately the light it emmits turns blue in turbo (when in direct drive) , so i guess as djozz mentioned the thermal pad of the Oslon isn’t big enough , and the black flat can’t handle the heat on a non dtp board .
I will run some more test tomorrow and report back.
I haven't tested black flat yet, but conclusion is that LEDs with very small die and small heat pad area really need copper DTP. Efficiency of LEDs drops at higher current because of two things: temperature of die, and current itself(why, still not fully explained by physicists) . For most big LEDs second cause is dominant at high currents because lumen stops increasing even if die temperature isn't even close to 150C, which is maximum allowed by most manufacturers. Maybe best example is Luxeon V with industry lowest thermal resistance per mm2 of die (0.8C/W,4mm2), it tops at around 9A, but if you calculate die temperature at 9A (LED on CuDTP, room temp. 20C), it is only 20C+ 9A*3.55V*0.8C/W=45.5C , not even warm in LED world. So second cause is dominant. This means even if you put such LED on non-dtp board which would cause for ex. 10C higher die temperature, that's still only 55C, difference in light output would be hard to detect.
On the other side it seems temperature effect on black flat is considerable, simply because power density for tiny 1mm2 die is very high. Temperature of die with copper DTP at room temperature,5A is 20C+5A*3.9V*4.3C/W=104C , this is quite high, if you take fact that typ. flashlight would have 40-50C temp., then die temp of oslon is very close to max. 150C. That's why every additional deg C caused by non-dtp board would have visible impact. Problem with black flat is small heat pad (3.5mm2, but it's questionable how good is heat distributed over that 3.5mm2 inside package), if black flat is in XM-L sized package, difference between DTP vs mosX would be much smaller.
As I said earlier, I designed mosX Osram/luxeonIR boards for infrared LEDs, where power density (~ max 2A) is much lower than with black flat, I expect no visible difference DTP vs. mosX in that case.
EDIT: When soldering wires to mosX boards, best method is to put some solder on iron tip and try to put some solder on one of the big pads. At first nothing will happen, but as board heats up, solder will melt over pad when board reaches high temperature. So it's important to hold tip on pad steady for some time. After board is hot, sodlering wires on all pads is easier. Board must be on piece of thick paper or some other thermal insulator.
Have been looking at these drivers a bit lately. Very interesting, with a lot of features I like.
Couple questions I haven’t seen yet………
When the double tap high (100%) is turned on, will it still be a part of the normal modes?
Ex= if 4 mode is set, normal mode changes go 2-10-30, then back to 2, with max only on double tap?
Does anybody know if the quad Luveon V will fit under the Astrolux S41 optics?
Thanks Djozz, I will have to check on the Carlco quad.
I have their triples, but not a quad to check if I could make it fit. If I recall correctly the S41 optic is only 22mm, where the Carlco is 24.
May be possible to shave it down a bit, 2mm is not much. Pics on MTN looks like I MIGHT be able to just get away with it.
Double tap is just shortcut, so if you have 4 modes and 2x tap to high enabled, modes will work 1-2-3-4 just as usual, 2x tap mode jumps to mode 4 from any other mode.
About S41 optics, if it's different than carclo then it would not fit. I have several more mosX boards on my wish list, I could add S41 to that list too, and make them in next batch, but I need detailed drawing of such board.
Unrelated to this, I have soldered Luxeon V LEDs on mosX 4040,3xV,4xV with soldered LED wires ready to use, I just need to list them on my page.
I just placed an order for some quad MCPCBs with Luxeon Vs but I didn’t see any tick box anywhere for reflow service, neither did I see any place to add message on placing order. Is reflowing the LEDs onto the MCPCB included? If not, do you offer reflow service? What would it cost? I’d like my the LEDs reflowed if possible.
I'll put listing with soldered LEDs as soon as I find time, until then you can order LEDs and mosX separately,and leave note about soldering LEDs, no extra fee for soldering.
It’s the order placed to Sweden at about 23:30. I can PM you order number if needed.
A question about the MOSFET option for future orders if I may. The MOSFET that you put on if option is selected, is it specific for your drivers? I’m wondering if I could use it for mine own drivers as a full on boost mode and get similar results as with the SIR800DP.
MOSFET is just that, mosfet, you can use it with any driver that use mosfet, DD or linear. It has 2,4mOhm resistance, one of the lowest in LFPAK33 package,and should be good in most cases.
Even with DD drivers, having mosfet on LED board is beneficial because:
-it saves space on driver board (more space for other things),
-Even on "DD" mosfet has finite resistance, if mosfet is on driver PCB at 10+Amps it would generate enough heat to make internal uC temperature reading wrong/problematic - with mosfet on LED pcb there is nothing left on driver pcb that could generate larger amount of heat, so temperature sensing with internal uC sensor is much more predictable.
25A without problem. Power dissipation in that case is 3-3.5Watts, this is no problem on any mcpcb. On the other side 3+ Watts on driver's FR4 pcb would cause melting if there is no additional thermal path (silicone cubes etc.). Internal uC temp. sensing would be pretty much useless for thermal regulation/stepdown.
