I’m at work now for 11 more hours. tomorrow I will measure it. I can not try the thread with C8A and C8T because this is the only Sofirn C8 I have but I can try them with Convoy C8.
You know, I’d like to convince them to offer a non-E switch version…at least, make it available as host only. Also, I’d buy a dual switch design similar to their SP31. À la Convoy L4 with 3 LEDs.
I told them it will be nice to buy separately the tailcap with switch.
The first C8F was non-e-switch, tail clicky only but a triple still. I modified it with a Noctigon and XP-L V6 3D emitters, my brother used it last night helping me take beam shots of the GT out at the lake, hmmmm, didn’t get the Sofirn back either! lol
What did she say? They are usually receptive to new ideas and they welcome suggestions to improve their product, which I think, is the way to go. It’s a step in the right direction.
Nothing yet. I think I told too much in one message and not all info went through.
For me having the e-switch is half the appeal. How much different is a C8+spacer+cute3 setup than this reflector, really?
A LOT! The CUTE-3 doesn’t have as tight a focus, is more floody. I don’t think the lumens out the front will be the same from the optic either.
It has 5,3mm thick integrated shelf which is good because MCPCB to shelf is less thermal contact layers than MCPCB to spacer and then the shelf. And me and maybe some other folks here to better like side E-switch lights. And with E-switch it is easier to switch very high currents.
And Dale is right too. Optically is totally different.
Personally, I’d prefer more reliable, proven design to gimmicky e-switch.
I have question to Dale. Which would give a better throw for the new C8F, the higher binned XP-L HD V6 or XP-L2 V5?
They’re both domed emitters, the XP-L2 will have more lumens so will probably push more light downrange just by sheer power alone. The XP-L is easier to de-dome for throw, although the XP-L2 can be sliced and diced for a similar effect if one is careful. I’d go with the 2nd generation for the power edge.
Just recently bought 25 XP-L2 in 5000K tint from Arrow, waiting on some C8F hosts to get here…
The 4 I put in my Dad’s Q8 this morning wound up making 7728 lumens in a nice tint, he hasn’t noticed yet.
You said you modified the first C8F that your brother took by upgrading the LEDs. Just curious if the higher binned XP-L V6 would pack more punch.
Edit: XP-L2 V6 hard to come by these days and I can’t wait for them to hit the shelves again. I’m thinking of getting the XP-L2 V5, too.
The first one came with an aluminum mcpcb and XP-G3’s, the emitters couldn’t take a high discharge cell on that board. So I modified it.
The new C8F comes with XP-L2’s in a nice tint, makes 3000 lumens out of the box with the supplied cell. Hard to go wrong there.
Yes. You changed the emitters, among other things, of course. Certainly. One can’t go wrong with the new version, but as currently advertised, I think the new C8F comes with XP-L.
Anyone try the Sofirn C8F head on Convoy C8 battery tube yet?
Tomorrow when I get home.
Thread pitch is different on the Convoy I have, won’t lego. Might be that mine is old enough to not work, don’t know.
The first C8F I got had XP-G3’s, one of 3 blew when I used a Samsung 30Q… so yeah I had to change emitters.
Ok. I got home with an unwanted detour with my wife to the hosputal but no big problems thankfully. I tried with the latest Convoy parts mixing.
On the top it is a Convoy head with Sofirn C8F tube and Convoy tailcap working fine. On the bottom there is a Convoy grey vezel on the C8F head with Convoy tube and C8F tailcap.
I cant try the C8F head with cpnvoy parts bevause it is an empty host now but I think it will work fine as the other.
The holes in the reflector are 6,5mm diameter for led centering rings. A bit odd but sofirn add centering rings to the host and they are good for XP size emitters.
