Diode and res mod on 105c
32 posts / 0 new
lotec25
Last seen: 1 year 9 months ago
Hello. I just picked up a Convoy M1 and stuck a XHP 70 in it. Light works great but I wanted to do the diode and res mod. I have read some threads on here but my board looks different can someone tell me where the diode and res go? Also how many 7135’s can I stick on the 8 that are on the board now. Thanks for all the help you can provide. Driver board attached.
Also is anyone making a gasket for the XHP70 and the M1?
Edited by: lotec25 on 12/31/2017 - 21:40
Wildcat
Last seen: 3 hours 12 min ago
Xhp70? Convoy M1? Stock linear driver? Bad joke…
Chatika vas Paus
Last seen: 6 min 33 sec ago
The reflector has a 9mm hole for LED? If so, here is gasket
For zener mod, you must remove the diode (next to + LED) and insert a resistor in its place. (Marked in blue)
The zener diode (not the one removed) you have to solder as I pointed out in the picture. (Marked in green)
Wildcat
The linear driver is good for this because you know the maximum current that goes into the LED. I plan to do it for 2 cells but with mt-g2
lotec25
Wildcat
Thank you sir for the help, I thought those were the places I just wanted to make sure.
Jaded
Jaded's picture
Last seen: 8 months 3 weeks ago
Suggestions as to where we can buy the zener diode at a reasonable price are welcome. More pictures of the diode would be nice.
Chatika vas Paus
You need a 4v3 zener diode and a 200ohm resistor in the 0805 package. Of course, you can look for something cheaper. These links are just an example.
In one picture, the zener diode has a strap. This strap should be like in the picture I pointed with an arrow
edit.
I’m not 100% sure but the zener diode can also be soldered on these empty pads
lotec25
From Digikey this is what I ordered
RES SMD 200 OHM 1% 1/8W 0805 Part# 541-200CCT-ND
DIODE ZENER 4.3V 500MW SOD123 Part # MMSZ5229B-FDICT-ND
lotec25
edit.
How many 7135’s can I stick on the 8 that are on the board now?
Also I looked on Digikey for the 7135’s but I am unable to find them I had to order them off FastTech. AMC7135 350mA SOT-89 and AMC7135 380mA SOT-89
Chatika vas Paus
For xhp70 (not xhp70.2) and 2.8A it is around 17.4W. A bit warm. I would leave 8 amc and see how much the body heats up. If you decide, for example, after 15 minutes, the temperature is OK, then add amc. Remember that the LED feels different temperature than you. As for me, 10x amc would probably be too much. This is 3.5A and over 22W. But almost 3000Lm!
lotec25
It gets warm running Full power. Even with it on low it gets warmish, but not to the point it unholdable. so I guess i’ll leave it at 8. thanks for the info man.
I love the fact the light get’s so hot, I seen a youtube video on this. that is why I picked this as my first light to mod. Just seeing how bright it was amazed me. Also just so it’s on the page. I used 2 Demonfire IMR 18350 High Drain 3.7V 1200mAh
TailCap spring mod
Jaded
Jaded's picture
Thanks for all the suggestions and links. Would you upload close up pictures of your work? I’d like to see the zener diode and resistor soldered to the board.
lotec25
Will do as soon as I get the parts. should be here later this week.
Lexel
Lexel's picture
Last seen: 4 min 8 sec ago
AMC7135s will throttle current when getting too hot
just keep in Mind at 2S even the stock ones generate double heat than normal
lotec25
Leviatan wrote:
edit.
Leviatan, How can I tell if I can put the zener diode on those pins?
Lexel
Lexel's picture
lotec25 wrote:
Leviatan wrote:
edit. I’m not 100% sure but the zener diode can also be soldered on these empty pads
if one pin has 0 Ohm to ground and the other to the 200 ohms resistor
lotec25
Thanks sir
Jaded
Jaded's picture
So can we use the empty pads of the stock Convoy driver like the one in the picture? Does the stock driver have the 0 Ohm pin and another for 200 Ohms?
lotec25
Jaded wrote:
So can we use the empty pad of the stock Convoy driver like the one in the picture? Does the stock driver have the 0 Ohm pin and another for 200 Ohms?
I just got the parts, so I’ll be checking it soon to see if it can be soldered on the second set of solder pads.
Jaded
Jaded's picture
Thanks. Take your time and enjoy your mod project. Looking good so far.
lotec25
OK, so here is the mod done. The Diode was a bit big but it’s just connected to ground, I wonder if there is a better Diode for this. I also upgraded the power and ground wires to 18AWG.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 4 weeks 1 day ago
Awesome…bad ass!!!!
Nice solder job Wink
Need some shots of that bad boy in action!
Don’t always trust those “*fire” batteries…chinesium ratings and all that…I like the purple efest ones…they usually do pretty well and are good batteries
Now you gotta learn to solder the button on the flattop batteries (pretty easy if you scuff the contact and use plenty of flux)
lotec25
Full power
Powered Off
celling bounce
WarHawk-AVG
Told ya flashlights are addictive Wink
Great job on your very first mod!
lotec25
I actually just ordered 2 of the purple EFEST batts. I picked up the fire ones cause people said they we’re good batteries.
WarHawk-AVG
cool cool…caveat emptor and all that
Jaded
Jaded's picture
Thanks for the pics. Nice mod. How long can you hold the light when running full power?
lotec25
Very True.
I have let the light run for a few min’s and it’s fine at full power. it does start to get warmish. I’ll have to tun it on and just let it run see at what point I can’t hold it anymore.
lotec25
How is that for a Solder ball?
lotec25
lotec25 wrote:
From Digikey this is what I ordered RES SMD 200 OHM 1% 1/8W 0805 Part# “541-200CCT-ND” DIODE ZENER 4.3V 500MW SOD123 Part # “MMSZ5229B-FDICT-ND”
After doing some research I think a better option would be going for a DSOD-323F package DDZ4V3BSF-7DICT-ND the size measures 2.50mm x 1.25mm. The cap this is going on is an 0805 so that is 2.00mm x 1.25mm. and just for reference the MMSZ5229B-FDICT-ND that is the SOD-123 is 3.65mm x 1.55mm I have not ordered the “DDZ4V3BSF-7DICT-ND” yet but I plan on it, to double check the size. So if someone is going to do this mod I would order a couple of the “DDZ4V3BSF-7DICT-ND” they are only 0.17 cents
SOD-323F
SOD-123
Jaded
Jaded's picture
Good find. Would you post a picture of your work after trying the smaller 323F?
lotec25
Of course I will.
