Test/review of LiitoKala INR26650-50A 5000mAh (Black)
271 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 36 sec ago
DSC_1560
Official specifications:
  • Nominal Capacity: 5000mah(4900-5000mah)
  • Nominal Voltage: 3.7V
  • Weight: 95g±1g
  • Rechargeable Battery: Yes
  • Rechargeable Times: Up to 500 times
  • internal resistance:
  • Limited Charge Voltage: 4.2v
  • Working Voltage: 2.75-4.2V
  • Size: 65.5mm x 26.5mm (Diameter)
  • Place of Origin: China HongKong
LiitoKala%20INR26650-50A%205000mAh%20(Black)-info
LiitoKala has updated the wrapper for their battery, is the battery inside still the same?
DSC_1559
DSC_1561 DSC_1562
DSC_1563
DSC_1564
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Capacity
Performance looks good up to 15A-20A
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Temp-15.0
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Temp-20.0
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Temp-30.0
The cell got very hot at 30A, this is too much for continuous discharge.
LiitoKala%20INR26650-50A%205000mAh%20(Black)-CapacityTimeHours
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Energy
LiitoKala%20INR26650-50A%205000mAh%20(Black)-PowerLoadTime
LiitoKala%20INR26650-50A%205000mAh%20(Black)-TripCurrent
LiitoKala%20INR26650-50A%205000mAh%20(Black)-Charge
Conclusion
The performance is slightly below the old version, but it is still a very good performance.
Notes and links
Old LiitoKala INR26650-50A 5000mAh (Cyan)
Compare to 18650 and other batteries
djozz
djozz's picture
Last seen: 7 hours 24 min ago
Thanks for the test! That sounds fine Smile
I’m glad that I bought a few. In my Opus all 4 tested between 5400 and 5500 mAh (so at 500mA discharge), but the Opus measures high.
Mitko
Mitko's picture
Last seen: 5 months 6 days ago
10x for that review m8, GJ!
robk
Last seen: 1 day 8 hours ago
When I got my first black sample I charged it to 4.2, did a discharge to 2.8, and then charged it to 4.2 on the Xtar VC2. I got 5500 mAh. Go figure.
Barkuti
Barkuti's picture
Last seen: 19 hours 25 min ago
Smells like trimmed corners.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Sharing localized AliExpress links is bad: when a user clicks or taps on a localized link their system automatically sets that locale, most often forcing the user to tap or click on the locale drop down or global site link to return to their localized site of choice or to the global site. Your carelessness is thus detrimental. I understand AliExpress should fix their site behaviour, but while this happens please be mindful and only share global website (english) links. Turning a localized link into a global link is super easy, just change the locale letters in the url for wwwExample:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
adam7027
Last seen: 12 hours 20 min ago
Approximately 1.5 months before I could order them from the liitokala official store at AliExpress. Now, they do not ship into many European countries (including mine). Does somebody know, what happened?
XinTD
Last seen: 9 months 3 weeks ago
It usually has something to do with airfreight regulations. Happened with Gearbest as well.
HKJ
HKJ's picture
It is a constant battle between the shops and shipping companies and regulations. It can include a lot of “silly” factors, like not specifying that the parcel contains batteries or putting batteries in cheap flashlights. I believe that all the Chinese shops has this battle where they try to ship batteries and due to changing regulation/polices it gets rejected.
One of the more silly is shipping with “Post Sweden” to Denmark or Sweden. “Post Sweden” is part of “Post Nordic”* that deliver post in both Sweden and Denmark, but they will not ship LiIon batteries to Sweden, only to Denmark (The shipping route is through Sweden) at the current time.
*That company is a political problem (The companies is government owned), “Post Sweden” bought (More or less) “Post Denmark”, transferred a lot of money from “Post Denmark” (There is no reason to own buildings) to Sweden and now “Post Denmark” is out of money (Big time).
fneuf
fneuf's picture
Last seen: 8 months 1 week ago
I'm searching cells for the Convoy L6, and would like something with similar performance than this LiitoKoala INR, but ideally protected. I know INR chemistry is safer than ICR by nature, but I would get the double security combo, as I'm planning to offer this light. Which cells would be a good choice?
Rise and Shine my precious...
DoNkEyConN
DoNkEyConN's picture
Last seen: 2 weeks 4 days ago
I’m pretty sure that high drain + protected is not possible, unfortunately, it’s one or the other. Others will be able to go into more detail but I’m quite sure the protection boards prevent cells from being ‘high drain’ cells.
if you do want some good protected cells tho keeppower make good ones.
https://www.banggood.com/1pc-Keeppower-ICR26650-5200mAh-3_7v-Protected-R...
Barkuti
Barkuti's picture
fneuf, cell model numbers are not chemistry recipes and neither normalized ratings. The actual chemistry of most modern quality cells I believe is likely either Lithium Nickel Cobalt Aluminum Oxide (“NCA”, LiNiCoAlO2) or Lithium Nickel Manganese Cobalt Oxide (“NMC”, LiNixMnyCozO2). Source: Lithium-ion battery @ Wikipedia, the free encyclopedia
Protected batteries usually are not high drain types mostly because protective circuitry with enough MOSFETs to handle all of the current simply doesn't fits in the limited available space of a tiny board.
Protection boards add in series resistance to cells, this lowers energy output (voltage and capacity). A typical DW01A plus dual 8205A MOSFET protection board probably adds ≈15mΩ of burden resistance. They also consume power to feed the protection circuitry, something which eventually ends up discharging the cells and self-tripping the over-discharge protection.
Li-ion technology wasn't mean for careless and uninformed end users. Proper user education is always the best approach.
Cheers
fneuf
fneuf's picture
Thanks for this thorough and well wrote piece of information. You are right.
That said I never planned to offer it without educating the "gifted". But I sure also would like to minimize any risks. It's kind of doubling the security measures, too much is never too much. I'm trying to find the hazardless setup to fuel this L6 light. If I rephrase, my need would be "What is the safest way to store 6 to 8.4v in a 2x26650 space?". And at that point, without any magical AAAs to 26650 adapters appearing somewhere (with also really strong hopes that sag would not kill them), the safest energy option seem to be KP 5200 protected cells.
stephenk
stephenk's picture
Last seen: 35 min 36 sec ago
There are quite a few 15A “high drain” protected batteries around now, based on 30Q and VTC6. It just requires more MOSFETs in the protection circuit.
adam7027
Now they are shipped again with NL post.
Barkuti
Barkuti's picture
Lowest price I've ever seen for these (blue wraps): https://www.aliexpress.com/item/Liitokala-2PCS-26650-rechargeable-battery-26650A-lithium-battery-3-7V-5100mA-26650-50A-blue-Suitable-for/1000004139007.html
Only a few hours left, but sellers re-launch their sales quite often.
There's, however, wide variance in measured cell capacity even among users of the same charger:
Facepalm and LoL! Big Smile with the Opus.
No comments…
There must be something wrong with that machine, I believe.
High numbers again…
Looks normal, though user may improve his information technology equipment usage skills.
 Consistent with the above Opus' figures.
Interesting, indeed. Do you believe product quality is consistent but not so with regards to user and charger teams?
Cheers Party
Enderman
Enderman's picture
Last seen: 6 days 19 hours ago
Well, were the batteries all discharged to the exact same amount?
DoNkEyConN
Barkuti wrote:
Lowest price I’ve ever seen for these (blue wraps): https://www.aliexpress.com/item/Liitokala-2PCS-26650-rechargeable-battery-26650A-lithium-battery-3-7V-5100mA-26650-50A-blue-Suitable-for/1000004139007.html
There’s, however, wide variance in measured cell capacity even among users of the same charger:
No comments…
High numbers again…
 Consistent with the above Opus’ figures.
Cheers Party
Are they the same 2 cells in every test?
Barkuti
Barkuti's picture
Those are cell buyer's submitted pictures. 1st, 2nd, last and each remaining pairs from different  users.
Albeit there's quite a discrepancy among the Lii-500 units.
Cheers Smile
P.S.: please don't quote like that. Facepalm
Satan@103TFS
Last seen: 1 day 1 hour ago
[quote=Barkuti]
7.7 usd for 2 is quite good…..64 usd shipping cost to TH Facepalm
Box
Last seen: 7 months 1 week ago
A bit cheaper for me.
$56 shipping to Australia
Wildcat
And free shipping to Russia Silly
Irbis-UA
Last seen: 1 year 12 months ago
К вам завозят сразу контейнер и распродают уже внутри страны. По многим позициям такая схема работает. Хуле, рынок бездонный фактически.
Barkuti
Barkuti's picture
Out of curiosity took a peek at the aforementioned link's feedback: https://www.aliexpress.com/item/Liitokala-2PCS-26650-rechargeable-battery-26650A-lithium-battery-3-7V-5100mA-26650-50A-blue-Suitable-for/1000004139007.html AliExpress' store number 133859.
User measurement inconsistencies all over the place, at times in a wild way. Honestly, one would not expect this from a reputable cell manufacturer (Power Long Battery), so something fishy is going on  behind the curtains. This could be because of rogue merchant dealing with and selling factory rejects, or who knows what other trickery.
Cheers Party
Irbis-UA
Barkuti wrote:
Out of curiosity took a peek at the aforementioned link’s feedback: https://www.aliexpress.com/item/Liitokala-2PCS-26650-rechargeable-battery-26650A-lithium-battery-3-7V-5100mA-26650-50A-blue-Suitable-for/1000004139007.html AliExpress’ store number 133859.
Cheers Party
Hi! This is fake battery?
Andrew_Debbie
Last seen: 13 hours 19 min ago
Liitokala can’t make fakes of their own brand of batteries. By definition a Liitokala branded battery sold by Liitokala isn’t a fake.
The real official fake Liitokala store is https://liitokala.aliexpress.com/store/133859
Edit: I don’t know what is real and what is fake.
teacher
teacher's picture
Last seen: 1 year 1 month ago
The real official Liitokala store is https://liitokala.aliexpress.com/store/133859
Interesting…. this one says it is the ‘Official Liitikala Store’. . Wink
https://m.aliexpress.com/store/activities/seller/storeHomeFromAms.htm?st...
Andrew_Debbie
The one I posted is linked directly from Littokala’s website.
I ordered 4 of the new blue 5100mAh 26650s about a week ago. When they get here, I will check-test the capacity and internal resistance with my chargers.
HKJ hasn’t tested the 2018 blue cells yet…..
Barkuti
Barkuti's picture
Irbis-UA wrote:
… Hi! This is fake battery?
No fakeness to be proved there. Their cells have been tested by Henrik here and there, delivering consistent capacity above 5Ah in any case even at 1C rate as per official PLB specs (a Lii-500 discharges at 250/500mA, which at most is 0.1C). God knows what they're doing those AE merchants besides deceiving and dissapointing customers.
Of course I do not mean to say all AliExpress sellers do the same, but the way AE works seems to be fertile ground for crooked sellers. In my opinion the whole LiitoKala battery rewrapping division smells like a nice fart. Big Smile
Cheers Smile
teacher
teacher's picture
Thanks, that is good info to know!! Thumbs Up
Sillen
Sillen's picture
Last seen: 6 hours 54 min ago
Need to do a ‘group buy’ to Australia, share the DHL/FedEx freight Smile
two¢¢
Seems there are many bogus stores using ‘Liitokala’ on Ali.
Be certain to visit the genuine LiitoKala Official Flagship Store
AliExpress store #133859
Claimed to be 2018 Liitokala 26650 5100mA 50A flat-top blue wrap.
Shipping used to be $57.54 to United States.
For now, shipping is $4.95 to United States.
I just ordered six here for $21.45 plus $4.95 shipping = $26.40
So, that’s about $4.40 apiece.
If you order just four, they are about $4.81 apiece here.
Pig in a poke, I do not know how good these are.
