Just want to throw in my hopes for Nichia, and also a smooth finish. I will obviously be very happy with whatever the team thinks is best in the end though. I do not think the bead blast or the taper looks bad. In fact like others I enjoy both designs Was originally just expecting a different look with the way it is described on page 1. Really love the original look like it was fresh off the lathe. Looking forward to this the most out of the last few BLF projects I have participated in! Think this is going to be an amazing edc light. Hope everyone had a great time during the holidays as well.
FWIW, I upgraded the thermal regulation behavior. I still need to do some extensive testing on it, but hopefully it will behave. Specifically, it adjusts the output in about 640 very small steps until it thinks it is no longer too hot or too cold… and the adjustment speed now changes depending on how far it needs to go. Additionally, the adjustments are based on the projected future temperature, which works like a car trying to “steer into” the curves.
Hopefully this will allow it to react quickly but also avoid oscillations after it has reached a maintainable level. I won’t know for sure until I test it though, and that takes a while.
This sounds like you are developing a PID loop. I think, if I am reading right, you have the P & I, essentially leaving D as zero.
“Facts don’t care about your feelings.”
~Ben Shapiro
Actually, accounting for the future is more like D action. Trying harder when it doesn’t work is integral action. We should do a bit of system identification on the driver and set a properly tuned PID controller and I bet things would work beautifully.
What I have now is more of a “PD” sort of system, with a small “I” component used mostly to reduce the effects of noise in the measurements. I tried making the “I” stronger but the results weren’t very good.
Specifically, it measures 4X per second, averages the past few values, and builds a temperature history using the averaged values. From this, it projects trends forward a few seconds to guess where it’ll be in the future. This is the “D” term. It keeps a few seconds worth of projected values, and takes the average, which is where the “I” term comes in. If the average projected value is above the ceiling, it sends an overheating signal to the UI code with the over-threshold magnitude (the “P” term) as a parameter. If the projected value is below the floor, it sends an underheating signal to the UI code (with the under-threshold magnitude as a parameter). Signals are rate-limited to avoid warning too often.
From there, the UI code decides what to do with it. In Anduril, it sets a new target ramp level based on the current level plus or minus the reported magnitude, with some bounds checking to keep things from going too high or too low. Then, on each clock tick, if the current level is different from the target level, it adjusts by the smallest step possible. Time between adjustments depends on how far it needs to go, so it could be anywhere from 0.016 s to 2.0 s per step. This interval is recalculated at each step so it decelerates as it approaches its destination.
In my testing, I’ve found it’s a bit tricky to hit the right balance between adjusting too fast (overshooting, oscillating) and adjusting too slow (overheating enough to hurt someone or cause damage). So most of what I’ve been doing is trying to make it reliably hit the Goldilocks area between.
Quite right.
~Ben Shapiro
I quite like the tapered battery tube, but i find it doesn’t match the not tapered rear end of the battery tube.
I think both ends should be tapered, but we’ll have to find out what tapering angles will look best, and if it should end with a straight section or not.
I’d be happy to photoshop different possibilities, but haven’t found a suitable picture to torture yet.
I guess the tail cap could have a smaller diameter too.
Olight: M3XS-UT, S Mini CU, R50 CU, R50 Pro LE, M2R, I3T Cu, S30R III, Marauder X6, X7R, X9R - BLF: Q8, A6, GT, GT mini - Emisar: D1s, D4Ti - Reylight: Tripple Dawn, Ti Lan
Apologies, I’m sorry.
Bob_McBob is #1038 and #1142,
Bob_McBob has requested three Flashlights “3”
Moparguy is #1278, #1279, #1280 and #1281,
Moparguy only asked for two flashlights, (request two flashlights) “2”. see: Post # 3547
Moparguy wrote:
Please sign me up for 2 ea. FW3A flashlights.
Dadpool is #385 and #1331, Dadpool only asked for a flashlight, (ask for a flashlight) “1”. see:
Dadpool wrote:
Post #710 Please add me to the list for 1 light. Thanks!
Dadpool wrote:
Post #3893 Thought I’d signed up already, but just in case I’m signing up now!
Also voted in both polls. This looks like it’s going to be a great light.
I think I’m out on this one, please remove me from the interest list.
Jambo is #310, #723, #724;
Request to delete one, (Remove one), #724
Request two flashlights, (only wants two flashlights), #310 and 723.
Jambo wrote:
# Post I must apologise profusely, I asked for two of these in post number 1574, I completely forgot I’d already asked for one a few months earlier in post number 889.
Could I be a pain and just have two instead of three please? Again, I apologise. Got a bit overexcited possibly!
So pipinferaxa, I officially declare that I am out of this one, as I previously said that I would if a further month went by with no news.
Please remove me from the interest list (2 torches).
Please add me to the list. Thanks!!
Robert
Duke™
~Ben Shapiro
Is there going to be a team account takeover of the top post like the GT thread? There probably should be based on The Millers hiatus.
~Ben Shapiro
Maybe, but the GT team is swamped right now. The GT group buy is closing so there is tons of stuff going on.
Who knows, maybe The Miller will take over this FW3A GB again.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Quite right.
~Ben Shapiro
Please add me for a second
Please add me to the list for one. Thanks.
John
I think I need to be on the list for one…
Please add me for a second unit
First unit: slot 235
Sorry for my bad English (gogole transtorla)
2Q19
interested please add me
Put me down for one…..
You are doing a great job.
Please add me on the list for 3 units.
Thanks
Please ad me for 1 light
Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK75Vn FiatLux, TK76, CL05, CL09 - Lumintop: Tool Ti, IYP365Ti - Astrolux: MF01 Lexel driver - FourSevens: Maelstrom MMU-X3
One please
cloggy
I’m in
Add me to the list please
Add me for a second until please and thanks guys
Put me down for one please
I’m in for one.
Updated list : …
Primary Interest List, (main): See Post # 4, Page 1 .
List with errors
Order numbers: Repeated
253 – 254 –
253 – 254 –
253 – BrianK
254 – BrianK
253 – GreenShrike
254 – GreenShrike
351 – 352 – 353 – 354 – 355 – 356 –
351 – Tixx
352 – zifzif
353 – rizky_p
354 – dentillozie
355 – osb40000
356 – Silent_Star
351 – drillbit
352 – DarthTader
353 – james y
354 – niktak11
355 – litenutz
356 – manbearpig
357 – rizky_p ………. ¿2nd ? … Post # 650 y – Post # 664
omitted requests:
362 – Gj – Post # 670 y – Post # 750
391 – shilent – Post # 714
I can not modify The Miller’s list
Add No. repeated after # 764 on Miller’s list
Interest list
253 – BrianK
254 – GreenShrike
351 – Tixx
352 – zifzif
353 – rizky_p
354 – dentillozie
355 – osb40000
356 – Silent_Star
761 – SmokinH762 – adnj763 – adnj2nd——— ——— ———
-18 Off : # Post . DB Custom , See # Post .
760 – SmokinH
761 – adnj
762 – adnj2nd
763 – BrianK
764 – GreenShrike
765 – drillbit
766 – DarthTader
767 – james y
768 – niktak11
769 – litenutz
770 – manbearpig
771 – Gj
772 – shilent
Google translator
Continuous
I follow the list
pepinfaxera: Interest List:
773 – # Post . krazypoloc
. . . . . # Post . ZozzV6 … Please remove me from the list.
774 – # Post . tui2004
775 – # Post . garrybunk
776 – # Post . bunnicula
777 – # Post . Bam35
778 – # Post . aggillator
779 – # Post . joeangi
780 – # Post . rizaoztop
781 – # Post . Yammie
782 – # Post . unknown00101
783 – # Post . paul6ppca
784 – # Post . FBsLights
785 – # Post . ZempOh
786 – # Post . ZempOh
787 – # Post . pirate joe 22
788 – # Post . pirate joe 22
789 – # Post . goatfarmer
790 – # Post . zzhawk
791 – # Post . redsuns
792 – # Post . pSw
793 – # Post . Qwibbles
794 – # Post . nfetterly
795 – # Post . xray291
796 – # Post . copperheaded
797 – # Post . erikbuch
798 – # Post . object_in_space
799 – # Post . bvincent
800 – # Post . bvincent
801 – # Post . zcbtjwj
802 – # Post . zcbtjwj
803 – # Post . starcrazed
804 – # Post . starcrazed
805 – # Post . dhiltonp
806 – # Post . Touchofred
807 – # Post . kbmeister
808 – # Post . andrewprime
. . . . – # Post . ferongr . Please remove me from the list,
See post # 725 , Number 397 of The Miller “Interest list”
809 – # Post . nqcken
810 – # Post . kahvitahra
811 – # Post . SkittleStoat
. . . – # Post . SkittleStoat … Take me off the interest list, please.
. . . . . . . . . . . . I thought we were signing up for this. .
812 – # Post . legofaith
813 – # Post . WhitedragonBC
681 – # Post … gregfortune Please put me down for two.
814 – # Post . gregfortune
815 – # Post . F.i.l.a.s
816 – # Post . Johnsonbrook
817 – # Post . drjamesfox
818 – # Post . Throw me in to darkness … REMOVED
819 – # Post . nick91900
820 – # Post . rahdi
821 – # Post . mustig
822 – # Post . Kingjohn
823 – # Post . Kingjohn
824 – # Post . The Burgh
825 – # Post . Itsme
826 – # Post . Slayer2003
827 – # Post . Slayer2003
828 – # Post . Jbraman
829 – # Post . Boaz
830 – # Post . jimmy yang
831 – # Post . gds95
832 – # Post . Jbraman
833 – # Post . Bruno28
834 – # 1821 # Post deleted . FlashPilot …. Please add me for 1.
. . . . . . . . FlashPilot … I can not find it . . . User banned?
EDIT: … Edited: Publication recovered,
834 – # Post . FlashPilot . FlashPilot … Please add me for 1.
835 – # Post . Rokypop
836 – # Post . crz6662
837 – # Post . Snoballz
838 – # Post . SG3
839 – # Post . floydo
840 – # Post . uqs1000
841 – # Post . balinzwerg
842 – # Post . JohnCalvin
843 – # Post . SKV89
844 – # Post . Majoroverkill
845 – # Post . doubleone44
846 – # Post . Bruno28
847 – # Post . legopacific
XXX – # Post . Ozythemandias …
Apologies, I’m sorry.848 – # Post . Uname
849 – # Post . Uname
850 – # Post . bossf350
851 – # Post . bossf350
. . . – # Post . Ormbett … nº 303 Interest list de The Miller, See post # 499
. . . . . . . . . . Ormbett wrote: . I am in for 1 –
852 – # Post . russthetoolman
853 – # Post . Umpi2000
854 – # Post . balinzwerg
855 – # Post . Pavlo
856 – # Post . fantomR
. . . – # Post . peabody … Give me one of each!
. . . . . . . . . . . There is the nº 158 Post # 205 y 488 Post # 887 Interest list de The Miller,
857 – # Post . Xebrecito
858 – # Post . askj
859 – # Post . Yanlee13
860 – # Post . hippotomato
861 – # Post . gravelmonkey
862 – # Post . ohhhtravis
863 – # Post . two fifty
864 – # Post . FlashIight
865 – # Post . sarten350
866 – # Post . velarpinch
867 – # Post . goshdogit
868 – # Post . lennshow66
869 – # Post . raccoon city
870 – # Post . t3rminal
871 – # Post . t3rminal
872 – # Post . Roger Wilco …
… … . # Post . SkittleStoat … Take me off the interest list, please. I thought we were signing up for this.
873 – # Post . thecrc
874 – # Post . thecrc
875 – # Post . thecrc
876 – # Post . Satan@103TFS
877 – # Post . nineteen43
878 – # Post . nfetterly
879 – # Post . nfetterly
880 – # Post . Benidin
881 – # Post . morning_wood
882 – # Post . bald1
883 – # Post . Dwantink
884 – # Post . Kinniver
885 – # Post . Garth
886 – # Post . Garth
887 – # Post . Dyang
888 – # Post . Dyang
889 – # Post . ChrYoko
890 – # Post . offroadatnite
891 – # Post . offroadatnite
892 – # Post . jtq
893 – # Post . 18000bph
894 – # Post . Mudpie86
895 – # Post . velocraig
896 – # Post . vasa_visost
897 – # Post . vasa_visost
898 – # Post . Minocc
899 – # Post . Minocc
900 – # Post . Luminosity
901 – # Post . Luminosity
902 – # Post . delete
903 – # Post . WakingToWinter
904 – # Post . Lips
905 – # Post . 10fold
906 – # Post . sportlampa
907 – # Post . Batch1
908 – # Post . morning_wood
909 – # Post . churchilllafemme
910 – # Post . stanmore
911 – # Post . g_sintornillos
912 – # Post . surasakkongtha
913 – # Post . KW
914 – # Post . Spiderlight
915 – # Post . fonLED
916 – # Post . fonLED
917 – # Post . fonLED
918 – # Post . MichielSanders
919 – # Post . cloggy
920 – # Post . mattar12
921 – # Post . uncle_muscle98
922 – # Post . uncle_muscle98
923 – # Post . Joey Adams
924 – # Post . Tdh66
925 – # Post . henry
926 – # Post . gi.lumens
927 – # Post . Thewrights11
928 – # Post . Thewrights11
929 – # Post . hksmatrix
930 – # Post . hksmatrix
931 – # Post . darrylo 3nd
932 – # Post . darrylo 4nd
-931 – # Post . darrylo 3nd … “Delete, Remove”
-932 – # Post . darrylo 4nd … “Delete, Remove”
931 – # Post . uncle_muscle98
932 – # Post . lightlight22
933 – # Post . lightlight22
934 – # Post . lightlight22
935 – # Post . IndyArcher
936 – # Post . IndyArcher
937 – # Post . torqu3e
938 – # Post . robbobus
939 – # Post . robbobus
940 – # Post . BeardedRaleigh
941 – # Post . BeardedRaleigh
942 – # Post . Jiffy
943 – # Post . turpulator
944 – # Post . Oldtinpan
945 – # Post . Oldtinpan
946 – # Post . wonwuster
947 – # Post . RT—
948 – # Post . Glov
949 – # Post . bobkido
950 – # Post . ferthur
951 – # Post . Scallywag
952 – # Post . SpAwN
953 – # Post . XD9
954 – # Post . mts49
955 – # Post . Dikkedikk
956 – # Post . Dikkedikk
957 – # Post . SoulCraves
958 – # Post . nqcken
959 – # Post . boTy
960 – # Post . KW
961 – # Post . cellguy
962 – # Post . jycheang
963 – # Post . Dewalt101
964 – # Post . Kalihi
965 – # Post . AlexGT
966 – # Post . Wyre
967 – # Post . StevenK
968 – # Post . The Jinx
969 – # Post . FlashMax
970 – # Post . Sarge930
971 – # Post . Sarge930
972 – # Post . ryukin2000
973 – # Post . GiveALux
974 – # Post . whipskirtayeyay
975 – # Post . whipskirtayeyay
976 – # Post . Teamliberty
977 – # Post . contigo
978 – # Post . Valerianis
979 – # Post . Xikex
980 – # Post . Xikex
981 – # Post . liteyear
982 – # Post . ryukin2000
983 – # Post . M78
984 – # Post . mikeymikey
985 – # Post . d_t_a
986 – # Post . caddylover
987 – # Post . PJ
988 – # Post . freethink
989 – # Post . jycheang
990 – # Post . sovereignknight
991 – # Post . sovereignknight
992 – # Post . uqs1000
993 – # Post . dbmeed
994 – # Post . kontour
995 – # Post . Tender
996 – # Post . thebaum
997 – # Post . Calaveras
998 – # Post . Rusty
999 – # Post . Rusty
1000 – # Post . Persechini
1001 – # Post . themaindude
1002 – # Post . themaindude
1003 – # Post . barrybluejeans
1004 – # Post . Just a Guy
1005 – # Post . BT100
1006 – # Post . varbos
1007 – # Post . wellerus
1008 – # Post . ridasrich
1009 – # Post . OKCOREY
1010 – # Post . Strangel0ve
1011 – # Post . Speadge
1012 – # Post . Speadge
1013 – # Post . sanches
1014 – # Post . Tsunamii
1015 – # Post . andrewmac
1016 – # Post . Maverick1947
1017 – # Post . minusic
1018 – # Post . san san
1019 – # Post . san san
1020 – # Post . brianch
1021 – # Post . SKV89
1022 – # Post . southcovekayak
1023 – # Post . OohNai
1024 – # Post . bmengineer
1025 – # Post . jaynick
1026 – # Post . dchoe
1027 – # Post . Parallax
1028 – # Post . Parallax
1029 – # Post . abarehands
1030 – # Post . abarehands
1031 – # Post . iosala
1032 – # Post . write2dgray
1033 – # Post . 808Hi
1034 – # Post . BrianCharles
1035 – # Post . Mike Fitz
1036 – # Post . full-beam
1037 – # Post . spaceminions
1038 – # Post . 808Hi
1039 – # Post . 808Hi
1040 – # Post . Bob_McBob
– - – - – # Post . RapidLux . 2nd . Post deleted
1041 – # Post . Shadowfax
1042 – # Post . Ocelot
1043 – # Post . Ocelot
1044 – # Post . 808Hi
1045 – # Post . Paul321
1046 – # Post . Paul321
1047 – # Post . opbigdave
1048 – # Post . loneoceans
1049 – # Post . toddcshoe
1050 – # Post . mmalive
1051 – # Post . mmalive
1052 – # Post . grahamgraham
1053 – # Post . JLightz
1054 – # Post . JLightz
1055 – # Post . jmike
1056 – # Post . renhoek
1057 – # Post . Mattfox27
1058 – # Post . BT100
1059 – # Post . bucky
1060 – # Post . jkbam
1061 – # Post . higbvuyb
1062 – # Post . adrn77
1063 – # Post . marcoaml78
1064 – # Post . Light Years
1065 – # Post . Nguyen
1066 – # Post . pavol77
1067 – # Post . adrn77
1068 – # Post . crazyglockman
1069 – # Post . Mstevens113
1070 – # Post . RapidLux
1071 – # Post . DeusLight
1072 – # Post . RoloFresh
1073 – # Post . bexamous
1074 – # Post . voltron88
1075 – # Post . BingoThink
1076 – # Post . crankynetadmin
1077 – # Post . eas
1078 – # Post . patchythepirate
1079 – # Post . 94Z28
1080 – # Post . liteyear
1081 – # Post . Pfeffernuss
1082 – # Post . Lol
1083 – # Post . a_idoux
1084 – # Post . a_idoux
1085 – # Post . MG
1086 – # Post . bibin
1087 – # Post . Zero-K
1088 – # Post . brtactical
1089 – # Post . NotSoBrightGuy
1090 – # Post . miswas
1091 – # Post . guerrilla154
1092 – # Post . pirate joe 22
1093 – # Post . pirate joe 22
1094 – # Post . Tom Tom
1195 – # Post . Tom Tom
1096 – # Post . Dwantink
1097 – # Post . kahvitahra1097 – # Post . aim120
1098 – # Post . jcooper
1099 – # Post . Alumenator
1100 – # Post . Alumenator
1101 – # Post . BazzH
1102 – # Post . nick779
1103 – # Post . Curdog
1104 – # Post . chadvone
1105 – # Post . chadvone
1106 – # Post . Darbonius
1107 – # Post . bobkido
1108 – # Post . Robowski
1109 – # Post . Seeker1
1110 – # Post . FlashIight
1111 – # Post . Sonullo
1112 – # Post . CM2010
1113 – # Post . raccoon city
1114 – # Post . TUNE4IT
1115 – # Post . slmjim
1116 – # Post . CJ Avlis
1117 – # Post . cypherz
1118 – # Post . cypherz
1119 – # Post . trevize
1120 – # Post . LG
1121 – # Post . LG
1122 – # Post . ggf31416
1123 – # Post . spaceminions
1124 – # Post . Bob_McBob
1125 – # Post . Bob_McBob
1126 – # Post . Xoroxronis
1127 – # Post . MascaratumB
1128 – # Post . opbigdave
1129 – # Post . The Burgh
1130 – # Post . Lim_Wee_Huat
1131 – # Post . azj
1132 – # Post . Jvrthp321
1133 – # Post . franktv
1134 – # Post . franktv
1135 – # Post . nev
1136 – # Post . cabfrank
1137 – # Post . alifpb98
1138 – # Post . alejandrov
1139 – # Post . WalkIntoTheLight
1140 – # Post . Seeker1
1141 – # Post . Rylee900
1142 – # Post . Rylee900
1143 – # Post . kommessy
1144 – # Post . kommessy
1145 – # Post . ChibiM
1146 – # Post . Tomogchi
1147 – # Post . shirnask
1148 – # Post . G0OSE
1149 – # Post . Parallax
1150 – # Post . Parallax
1151 – # Post . lmcmann
1152 – # Post . lmcmann
1153 – # Post . Shame-Ranger
1154 – # Post . rockhound42
1155 – # Post . Zulumoose
1156 – # Post . GreenLights
1157 – # Post . Thekernels
1158 – # Post . BT100
1159 – # Post . jwhitmore
1160 – # Post . jwhitmore
1161 – # Post . qandeel
1162 – # Post . djozz
1163 – # Post . Megapanda66
1164 – # Post . Megapanda66
1165 – # Post . hoabegrubn
1166 – # Post . WelshDan
1167 – # Post . MaksVasilev
1168 – # Post . wishiwereaskibum
1169 – # Post . bucky
1170 – # Post . orinjuse
1171 – # Post . toddcshoe
1172 – # Post . Geuzzz
1173 – # Post . CM2010
-1173 Off : # Post . CM2010 , See # Post .
1173 – # Post . Yourrid
1174 – # Post . Yourrid
1175 – # Post . Grappler
1176 – # Post . bquinlan
1177 – # Post . bquinlan
1178 – # Post . noboneshotdog
1179 – # Post . Kaz
1180 – # Post . RaVeN
1181 – # Post . junglejim13660
1182 – # Post . trigger619
1183 – # Post . trigger619
1184 – # Post . d_t_a
1185 – # Post . Diomedes
1186 – # Post . candor
1187 – # Post . JordanZHP
1188 – # Post . JordanZHP
1189 – # Post . Kingjohn
1190 – # Post . Hojobones
1191 – # Post . Athlon2350
1192 – # Post . Athlon2350
1193 – # Post . Athlon2350
1194 – # Post . whatthewillus
1195 – # Post . Jesjes
1196 – # Post . Yohan110
1197 – # Post . TheAuditor
1198 – # Post . K1NGP1NT
1199 – # Post . sleasys14
1200 – # Post . StevenK
1201 – # Post . agent80
1202 – # Post . Sivy
1203 – # Post . pennzy
1204 – # Post . Torre246
1205 – # Post . Torre246
1206 – # Post . hron61
1207 – # Post . zzzbgd
1208 – # Post . Marshymarsh26
1209 – # Post . FilipeBanana
1210 – # Post . orbit308
1211 – # Post . flashycali
1212 – # Post . flashycali
1213 – # Post . Aulic458155
1214 – # Post . Paradoxical Antagonist
1215 – # Post . mundele
1216 – # Post . GiveALux
1217 – # Post . GiveALux
1218 – # Post . erik
XXXX – # Post . toxiccoccyx
1219 – # Post . teacher
1220 – # Post . teacher
1221 – # Post . slowtechstef
1222 – # Post . rbmcmjr
1223 – # Post . gavrook
1224 – # Post . royalomaha
1225 – # Post . BlueSwordM
1226 – # Post . Ijon
1227 – # Post . scout24
1228 – # Post . richnpc
1229 – # Post . GoMeR
1230 – # Post . GoMeR
1231 – # Post . byarnell05
1232 – # Post . byarnell05
1233 – # Post . bansuri
1234 – # Post . mniezen
1235 – # Post . mniezen
1236 – # Post . FBsLights
1237 – # Post . preface
1238 – # Post . whopist
1239 – # Post . jaynick
1240 – # Post . jaynick
1241 – # Post . jaynick
1242 – # Post . tjl014
1243 – # Post . tjl014
1244 – # Post . Cutchya
1245 – # Post . I LIKE FLASHLIGHTS
1246 – # Post . DoubleU
1247 – # Post . ActiveAl
1248 – # Post . severide
1249 – # Post . Tarvos
1250 – # Post . Tarvos
1251 – # Post . kmwc72 CN
1252 – # Post . kmwc72 CN
1253 – # Post . ActiveAl
1254 – # Post . Lion42
1255 – # Post . Lion42
1256 – # Post . andyxxx
1257 – # Post . andyxxx
1258 – # Post . flashycali
1259 – # Post . Aussie78
1260 – # Post . dmsoule
1261 – # Post . dmsoule
1262– -# Post . manithree Delete1263 – # Post . tvizk
1264 – # Post . raqin
1265 – # Post . retsyx
1266 – # Post . Bervilat
1267 – # Post . kubed_zero
1268 – # Post . kubed_zero
1269 – # Post . korylprince
1270 – # Post . Ratus
1271 – # Post . Edindevon
1272 – # Post . GalaxyWide
1273 – # Post . Medicijnman
1274 – # Post . Nash_Vegas
1275 – # Post . Moomoomao
1276 – # Post . Moomoomao
1277 – # Post . Brinkmann
1278 – # Post . Brinkmann
1279 – # Post . bonfire
1280 – # Post . Moparguy
1281 – # Post . Moparguy
1282 – # Post . .-’_
1283 – # Post . Nooner
1284 – # Post . Atom00
1285 – # Post . javipiloto
1286 – # Post . Lfatman
1287 – # Post . DarkParagon
1288 – # Post . Crazy999
1289 – # Post . LanternGuy
1290 – # Post . samnavy
1291 – # Post . Random Dan
1292 – # Post . finnegans
1293 – # Post . TheSoulless78
1294 – # Post . wiley07
1295 – # Post . jinjin19
1296 – # Post . QwertzHz
1297 – # Post . Cyzan
1298 – # Post . Cyzan
1299 – # Post . cujo255
1300 – # Post . geetee03
1301 – # Post . apurva
1302 – # Post . apurva
1303 – # Post . Marubae
1304 – # Post . HONDARIDER
1305 – # Post . HONDARIDER
1306 – # Post . yokomus
1307 – # Post . Chatika vas Paus
1308 – # Post . Chatika vas Paus
1309 – # Post . Snoballz
1310 – # Post . spaceminions
1311 – # Post . Mr.Scott
1312 – # Post . lohtse
1313 – # Post . lohtse
1314 – # Post . brettr1
1315 – # Post . gkushev
1316 – # Post . gkushev
1317 – # Post . wiley07
1318 – # Post . wiley07
1319 – # Post . Yoav.Klein
1320 – # Post . Bd7
1321 – # Post . alejo
1322 – # Post . hiker89
1323 – # Post . hiker89
1324 – # Post . hiker89
1325 – # Post . NordicMist
1326 – # Post . wheelgunwordslinger
1327 – # Post . Dsvist12
1328 – # Post . Dsvist12
1329 – # Post . Doobyscoo
1330 – # Post . mrgreengenes42
1331 – # Post . misterpearguy
1332 – # Post . MobileEMP
1333 – # Post . MobileEMP
1334 – # Post . MobileEMP
1335 – # Post . rennet
1336 – # Post . lew123
1337 – # Post . zeroflow
1338 – # Post . duhduhduhdiabeetus
1339 – # Post . Nortson
XXXX – # Post . Nortson
1340 – # Post . Hallamski
1341 – # Post . michaeltmohr
1342 – # Post . Glas4d
1343 – # Post . Glas4d
1344 – # Post . Coscar
-1344 – See # Post Coscar, delete
1344 – # Post . gemmell
1345 – # Post . gemmell
1346 – # Post . a_idiot
1347 – # Post . jaharkes
1348 – # Post . madness
1349 – # Post . arisdes
1350 – # Post . Zeratull
1351 – # Post . severide
1352 – # Post . TheShadowGuy
XXXX – # Post . TheShadowGuy
1353 – # Post . Cursecut3r
1354 – # Post . Hesh24
XXXX – # Post . Hesh24
1355 – # Post . Tony Cape
1356 – # Post . sbslider
1357 – # Post . LightUpTheDark
1358 – # Post . Jagger
1359 – # Post . soldsoulrockroll
1360 – # Post . ReallyInToCheese
1361 – # Post . noobsanpu
1362 – # Post . BurningPlayd0h
1363 – # Post . headburger
1364 – # Post . Phaze13
1365 – # Post . Iselldrugsforgolf
1366 – # Post . Typevii
1367 – # Post . tkd15
1368 – # Post . xikteny
1369 – # Post . bushmaster
1370 – # Post . kevinw0lf
1371 – # Post . scottie888
1372 – # Post . Gondwanaland
1373 – # Post . cannesahs
1374 – # Post . Polyesterboy
1375 – # Post . the0dore3524
1376 – # Post . Stereodude
1377 – # Post . CitizenK
1378 – # Post . bento_blf
1379 – # Post . klrman
1380 – # Post . yokomus
1381 – # Post . KJ4BXT
1382 – # Post . KJ4BXT
1383 – # Post . ale9g
1384 – # Post . Penguin
1385 – # Post . Penguin
1386 – # Post . waxing twilight
1387 – # Post . Roc32
1388 – # Post . Roc32
1389 – # Post . iamlucky13
1390 – # Post . Mops1
1391 – # Post . Mops1
1392 – # Post . wheremydonky
1393 – # Post . wheremydonky
1394 – # Post . wheremydonky
1395 – # Post . psumo
1396 – # Post . adirus
1397 – # Post . geetee03
1398 – # Post . zotee123
1399 – # Post . anycolourfloyd
1400 – # Post . CabalGrim
1401 – # Post . Lick
1402 – # Post . ttylamg
1403 – # Post . Cereal_killer
1404 – # Post . Jay
1405 – # Post . mb200k
1406 – # Post . stolikat
1407 – # Post . TonyG
1408 – # Post . asciiphil
1409 – # Post . Fady
1410 – # Post . Fady
1411 – # Post . Fady
1412 – # Post . lucydog
1413 – # Post . lightknot
1414 – # Post . lightknot
1415 – # Post . xertian
1416 – # Post . xertian
1417 – # Post . Enlightened1
1418 – # Post . Enlightened1
1419 – # Post . elnino
1420 – # Post . gottawearshades
1421 – # Post . 3061fps
1422 – # Post . andrewmac
1423 – # Post . andrewmac
1424 – # Post . firstcipher
1425 – # Post . skinny_tie
1426 – # Post . Nooner
1427 – # Post . Cereal_killer
1428 – # Post . Cereal_killer
1429 – # Post . bushmaster
1430 – # Post . kollers
1431 – # Post . Geese
1432 – # Post . caplang
1433 – # Post . vadimax
1434 – # Post . MonkeyLight
1435 – # Post . MonkeyLight
1436 – # Post . MonkeyLight
1437 – # Post . MonkeyLight
1438 – # Post . justaguy
1439 – # Post . justaguy
1440 – # Post . HeavyD3
1441 – # Post . HeavyD3
1442 – # Post . knuckles
1443 – # Post . Mops1
1444 – # Post . thejinn
1445 – # Post . fusion_m8
1446 – # Post . justanotherguy
1447 – # Post . Geese
1448 – # Post . JohnnyUtah
1449 – # Post . loki993
1450 – # Post . e1000
1451 – # Post . jamio
1452 – # Post . hodor
1453 – # Post . Ilmatic
1454 – # Post . Ilmatic
1455 – # Post . atasuke_
1456 – # Post . AcIDsNaZz
1457 – # Post . Desert Lumens
1458 – # Post . bulbeee
1459 – # Post . Melven
1460 – # Post . neBstress
1461 – # Post . autoxer
1462 – # Post . RichardBrown
1463 – # Post . Valerianis
1464 – # Post . takumi86
1465 – # Post . Gravedigger1
1466 – # Post . MascaratumB
1467 – # Post . RandyC
1468 – # Post . RandyC
1469 – # Post . coban
1470 – # Post . coban
1471 – # Post . eas
1472 – # Post . Delta_V
1478 – # Post . nsk1979
1479 – # Post . derivepower
1480 – # Post . lexvegas
1481 – # Post . Tejasandre
1482 – # Post . Tejasandre
1483 – # Post . velocraig
1484 – # Post . Tech25
1485 – # Post . donnakebab
1486 – # Post . donnakebab
1487 – # Post . ansb29
1488 – # Post . ansb29
1489 – # Post . ansb29
1490 – # Post . caplang
1491 – # Post . hanoilighting208
1492 – # Post . huey18
1493– # Post .lew1231494 – # Post . Eggun
1495 – # Post . D4rka2nx
1496 – # Post . Marnav1
1497 – # Post . superbob47
1498 – # Post . scottyhazzard
1499 – # Post . pfn
1500 – # Post . MikeMacD
1501 – # Post . MikeMacD
1502 – # Post . Sillen
1503 – # Post . Hexlord
New requests: Not updated in Post #4 page 1.
1504 – # Post . scalyman.
1505 – # Post . LGW
1506 – # Post . gottobegeek
1507 – # Post . sergey—neo
1508 – # Post . Nichia
1509 – # Post . Juls Boo
1510 – # Post . Jaded
1511 – # Post . idleprocess
1512 – # Post . idleprocess
1513 – # Post . sergey—neo
1514 – # Post . zapviii
1515 – # Post . gottawearshades
1516 – # Post odriewniffe
1517 – # Post . adam7027
1518 – # Post . adam7027
1519 – # Post . adam7027
1520 – # Post . WhitedragonBC
1521 – # Post . gtv4
1522 – # Post . theRealSammyG
1523 – # Post . theRealSammyG
1524 – # Post . Fiiish
1525 – # Post . lachesis
1526 – # Post . lachesis
1527 – # Post . Unloco
1528 – # Post . Unloco
1260 – # Post .
manithree: Delete.
1529 – # Post . mgracia85
1530 – # Post . jimmymke
1531 – # Post . McLight
1532 – # Post . gman7228
1533 – # Post . BadWolf
1534 – # Post . interval
1535 – # Post . Aleister
1536 – # Post . TheOnlyDocc
1537 – # Post . alchemi
1538 – # Post . bmansc
1539 – # Post . Sherbona
1540 – # Post . Sherbona
1541 – # Post . Cookster
1542 – # Post . Azza
1543 – # Post . DontWorryScro
1544 – # Post . stolikat
1545 – # Post . 10fold
1546 – # Post . 10fold
1547 – # Post . Tally-ho
1548 – # Post . Tally-ho
1549 – # Post . joechina
. . . . . . # Post . wishiwereaskibum
wishiwereaskibum wrote: I’m in for one if not too late!.
wishiwereaskibum is at numbers #665, #675 and #1165. : How many flashlights do you want in total? … x … units?
1550 – # Post . gehrmo
1551 – # Post . folg
1552 – # Post . MikeMacD
1553 – # Post . JaredM
1554 – # Post . JaredM
1555 – # Post . BrianButlerCPA
1556 – # Post . Marcello
1557 – # Post . Bogdan
1558 – # Post . Bogdan
1559 – # Post . Rsqweezy
1560 – # Post . whateatsrabbits
1561 – # Post . Rxich
1562 – # Post . LAB
1563 – # Post . Shadow.X1
1564 – # Post . NITEbiker
1565 – # Post . NITEbiker
1566 – # Post . SilentObserver
1567 – # Post . autoxer
1568 – # Post . srkfl
1569 – # Post . Archangel72
1570 – # Post . Archangel72
1571 – # Post . Light
1572 – # Post . DarkerInSol
1573 – # Post . DarkerInSol
1574 – # Post . DarkerInSol
1575 – # Post . nick779
1576 – # Post . Cpeng
1577 – # Post . Animisk
1578 – # Post . Animisk
1579 – # Post . PhantomPhoton
1580 – # Post . OrangePeel
1581 – # Post . OrangePeel
1582 – # Post . lightlight22
1583 – # Post . lightlight22
1584 – # Post . lightlight22
1585 – # Post . noetik
1586 – # Post . noetik
1586– See # Post . noetik : Delete 15861586 – # Post . Finnno
1587 – # Post . nastynate
1588 – # Post . apt323
1589 – # Post . lfowner
1590 – # Post . lfowner
1591 – # Post . Jonandreadolan
1592 – # Post . lightlight22
1593 – # Post . MokrySedeS
1594 – # Post . MokrySedeS
1595 – # Post . Ziggie
1596 – # Post . offline
1597 – # Post . Dogue
1598 – # Post . Dogue
1599 – # Post . thisnameisvalid
1600 – # Post . lmcmann
1601 – # Post . lmcmann
1602 – # Post . timbo114
1603 – # Post . timbo114
1604 – # Post . hcanning
1605 – # Post . Sirawatka
1606 – # Post . southcovekayak
1607 – # Post . aswang
1608 – # Post . Bigoaktree
1609 – # Post . oceanfreak
1092– # Post . Tom Tom Delete #10921093– # Post . Tom Tom Delete #10931610 – # Post . tango
1611 – # Post . tvizk
1612 – # Post . P33
1613 – # Post . odriewniffe
1614 – # Post . elpaulo
1615 – # Post . elpaulo
1616 – # Post . EnlightenMe
1617 – # Post . Buzzy243
1618 – # Post . Buzzy243
1619 – # Post . Geoduck
1620 – # Post . Tumbleweed48
1621 – # Post . Deadsailor21
1622 – # Post . Deadsailor21
1623 – # Post . Greener
1624 – # Post . Greener
1625 – # Post . tundraotto
1626 – # Post . Rdubya18
1627 – # Post . x-ray
1628 – # Post . ispeedy
1629 – # Post . ispeedy
1630 – # Post . bts
1631 – # Post . lightboks
1632 – # Post . willc68
1633 – # Post . jaynick
1633See # Post : . jaynick = #1023, #1237, #1238 and #12391633 – # Post . Dario
1634 – # Post . Lagittaja
1635 – # Post . antoninuspius
1636 –
1637 –
1638 –
1639 –
1640 –
1641 –
1642 –
1643 –
1644 –
1645 –
1646 –
1647 –
1648 –
1649 –
1650 –
Updated list … Last request: … “See # Post … antoninuspius # Post
NOTE: If I overlooked a post, PLEASE IM me and i’ll edit for correction.
Correcting: …
# Post lew123 – lew123 is #1337and #1493.
lew123 only requests a flashlight, # Post and # Post .
599–Post #1293 . -ChinookerDelete Post #599 . –
Chinooker.
1260 – # Post . manithree
1260– # Post Delete manithree.
#724Request two flashlights, (only wants two flashlights), #310 and 723.
Page 1 Post # 4,
1092 : Post #2769, Tom Tom
1093 : Post #2769, Tom Tom
1092: Post #4950Tom TomDelete1093: Post #4950Tom TomDelete.
Page 1 Post # 4,
1357 : Post #3926, Hesh24
1358 : Post #3926, Hesh24
1358: See # Post , . Hesh24, Delete 1358 ..
TLF list total 397
http://www.taschenlampen-forum.de/threads/fw3a-tlf-sonderedition-in-klei...
New.- .
-88 – cuxhavener : Delete, Remove.
-22 – hjelpestikker : Delete, Remove.
-23 – hjelpestikker : Delete, Remove.
-154 – hjelpestikker : Delete, Remove.
-155 – hjelpestikker : Delete, Remove.
-171 – Ratzepeter : Delete, Remove.
380 – Unheard
381 – Jodok
382 – fishfendi
383 – fishfendi
384 – Luckaffe00
385 – Yakuzoko
386 – Yakuzoko
387 – Yakuzoko
388 – Yakuzoko
389 – Yakuzoko
390 – Yakuzoko
391 – luceo ergo sum
392 – luceo ergo sum
393 – Xey
394 – wawe
395 – ikaruz500
396 – ikaruz500
397 – Snakepit
398 – Leo
399 – Leo
400 – King of Light
401 – King of Light
402 – King of Light
403 – Optikus
404 –
405 –
List = 403, … Remove = 6, … Total TLF requests: 397.
TLF = 397
BLF = 1635
TLF + BLF = 2.032
(google translator) , (https://www.deepl.com/translator)
Im in for one Thanks
I’m in for two please
Please add me to the list for 2 lights.
Please put me down for two. Thanks.
