lostheplot
(lostheplot)
January 5, 2018, 9:54am
65
A little more progress today
mounted a alloy hyd cylinder in the lathe
did a little knurling and madea square thread
trimmed it off in the hacksaw
cleaned it up in the lathe and bored it out to suit battery holder ,pictured with what will be the head
MRsDNF
(MRsDNF)
January 5, 2018, 8:07pm
66
What pitch is your square thread?
I guess you wont be out in the shed today because of the heat.
lostheplot
(lostheplot)
January 7, 2018, 8:02am
68
a little progress today made a retaining ring for switch it will be held with a few screws from the rear
so I will now have to rewire the battery holder
next time we will start on the head.
Were you planning on using an e-switch? The tail switch is now the main switch or lock-out function?
lostheplot
(lostheplot)
January 7, 2018, 10:16am
70
tail clicky only,was going to be in the head but would have made the light longer
lostheplot
(lostheplot)
January 31, 2018, 4:36am
73
Internal thread completed
Took a little to make it fit ,but happy now.
MRsDNF
(MRsDNF)
January 31, 2018, 8:14am
74
So that knurled part is 80mm in diameter?
lostheplot
(lostheplot)
February 14, 2018, 10:47am
75
had a few minutes ,thought I would add fins
they start at 3mm deep and finish at 10mm depth
3mm spacing , should keep it cool for the first 5 minutes,
try and do a bit more tomorrow
knurled handle 70 mm dia.head 85
Are those threads square or trapezoid? How did you cut them?
lostheplot
(lostheplot)
February 16, 2018, 8:32am
78
yes square thread pp ground my own tool slow and steady
next bit is a little boring
ended up with this
spun it around just want to shape the head a little,not sure how yet,
next week,.
and yes mrs dnf all pics are from the s5 as it is easy to upload with the app,
kiriba-ru
(kiriba-ru)
February 16, 2018, 8:52am
79
lostheplot
Do you have a mill?
lostheplot
(lostheplot)
February 16, 2018, 9:34am
80
I have this Chinese mill drill
MRsDNF
(MRsDNF)
February 17, 2018, 1:20am
81
The threads look real good LTP.
lostheplot
(lostheplot)
February 17, 2018, 2:13am
82
I was happy enough for my first attempt
V threads are better.
lostheplot
(lostheplot)
February 22, 2018, 2:47am
83
Realized I needed a bezel
skimmed bit of flat
turned it to suit
trimmed the back of the head a little
its a sizable thing
now to get time to finish and source some orings
ARsee
(ARsee)
February 22, 2018, 5:26am
84
Nice re-purpose of a cylinder shaft LTP. :+1:
