Package included:
1 x Folomov Tour B5M XHP50.2 2500LM USB Rechargeable LED Flashlight
1 x USB charging cable
1 x Flashlight holster
1 x Lanyard
1 x O-ring
1 x Clip
Package included:
1 x Folomov Tour B4M XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
Package included:
1 x Folomov Tour B4 XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
Package included:
1x WUBEN TO10R Magnetic Tail USB Rechargeable LED Flashlight
1x Built-in 16340 Battery
1x USB Charging Cable
1x Lanyard
1x Mannual
1x O ring
● Uses a 26650 5500mAh high-rate discharge lithium battery,the main light and side light dual light source design.
● The main light utilizes XHP70.2 P2 CW LED,output up to 3500Lumens.
● Side light utilizes XP-G2 R5 NW LED,maximum output to 200Lumens
● One-touch control all function,it is easy to operate.
● Body with Micro-USB charging,which supports up to 2A charge.
● Can be used as a mobile power supply,use the USB adapter provide power to other devices,the maxmum output to 2.2A;with a dischargercapacity reminder.
● Users constant current circuit, with high battery effciency,stable output,no flashes.
● Anti-reverse design to prevent incorrect battery installation causes the circuit damage.
● Battery power detection,charging instruction,low battery reminder function.
● With locking function prevent accidental illumination.
● One-pieces shell,the structure is stable and reliable.
● Made of aero grade aluminum alloy,premium Type III hard-anodized anti-abrasive finish.
● With flashlight self-location function.
Charging:
● Before charging,ensure that the battery is correctly loaded into the flashlight, and the tail of the flashlight has been tightened.
● Insert the charging cablle Micro USB port into the flashlight charging port,then insert the charging cable USB port into the power port to recharge.Charging light red indicates charging,green indicates charging has been completed.The flashlight can only turn on side medium mode while charging.
Package included:
1 x MR70 flashlight
1 x ROFIS 26650 5500mAh battery
1 x Charging cable
1 x Micro USB to USB adapter
1 x Holster
1 x Lanyard
1 x USB cover
1 x User manual
2 x O-ring
Features:
• Utilizes 7x XP-G2 LED
• Driven by a unprotected 26650 to emit up to 2500lumens brightness
• Four easily accessible brightness levels and memory function for fast boost
• Extensive runtime up to 200 hours
• Electric reverse polarity protection
• Anti-rolling design
• Toughened ultra-clear mineral glass with anti-reflective coating
• Constructed from T6061 hard aluminum alloy
• Waterproof in accordance with IPX-8 (two meters submersible)
• Tail stand
Package included:
1 x DQG Tiny 26650 3th 7x XP-G2 EDC LED Flashlight
1 x o-rings
Package include:
1x ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger
1x USB Cable
1x EU Plug(depending on what kind of package your choose)
The Astrolux S41S is on promo sale right now @ $32.95 (and it appears the same price whether the G2, G3 or Nichia versions), and appears to be usable with the generic “4BLF” 9% discount code, making it only $29.98.
If you have an Astrolux S1 18650 tube, you could also just buy the S41S head ($21.95 promo, can still apply 4BLF discount code) and attach to that to an existing S1 tube (that’s how I use mine now, the color of the head is stainless, but the body is the ordinary aluminum one [so it’s quirky mismatched colors but works; and swap the S41S shorty 18350 body tube to my S1 head…]; but it’s now lighter to carry around than full stainless body)
I got it about 2 months ago with a discount code, and its price was quite higher then ($33.96 IIRC for the Nichia).
