JasonWW
(JasonWW)
January 7, 2018, 11:23pm
134
No, the OTR turbo is brighter. The difference between 500 lumen and 900 lumen is not so great, but it is noticable.
I have CW in both models and both are identical in tint. Not very cool in my opinion. Both have a hint of paleness. It kind of reminds me of a cree 2x color rather than a 1x. I’m gonna try a sst40 in it to see if I can’t get rid of the yellow. I’ve heard the OTR NW is also warmer than people expect. You can also play with the tint a little by changing the glass lens.
The OTR M3 and clone M3 have clear lenses. If you add an AR coated lens it makes it even more NW.
OTR M3’s are $5 more than these clones right now & they respond to inquiries with more than a single word.
They even apologized for taking 2 days to put together an english translation of the M1 UI when I asked for it.
JasonWW
(JasonWW)
January 7, 2018, 11:50pm
136
Jimmy_Chimichanga:
I see it for $7 more, but only in CW and with no battery from Gearbest. With battery it’s $31.
Are you seeing an $18 M3 somewhere else?
I ordered a couple.
Now the long wait begins….
MRsDNF
(MRsDNF)
January 8, 2018, 4:16am
138
JasonWW
(JasonWW)
January 8, 2018, 4:30am
139
That’s the jaxmnve clone. Jimmy_Chimichanga said the On The Road M3 was on sale for $18. That is what I was asking about.
MRsDNF
(MRsDNF)
January 8, 2018, 4:33am
140
Sorry. Old timers kicking in. :person_facepalming:
beam0
(beam0)
January 8, 2018, 9:20am
141
Thanks for your answers XXX-Man!
So for sure you cannot enter ramping with a double click directly from off?
Thought this meant it did but guess not
beam0
(beam0)
January 8, 2018, 9:19am
142
MascaratumB, Thanks for your answers.
In an earlier post you wrote:
What exactly did you mean by that?
In freeme’s vid it appears when ramping reaches max or min it doesn’t blink or pause, it just immediately reverses direction. So no pause when reaches min. and no blinking when it reaches max.
MascaratumB:
when it starts ramping in one direction (up or down), even if you stop it, next time you hit the button it will ramp up or down, and it will only ramp in the opposite direction after reaching the top or bottom limit!
By this do you mean if you stop and then restart the ramping it will continue in the same direction as before you stopped? I only have one light with ramping and that’s what it does, so that seems normal to me. Do other ramping UI’s do something different?
beam0
(beam0)
January 8, 2018, 9:03am
143
Jimmy_Chimichanga:
Please tell us where?
I can get the OTR M3 full kit for about $9 more, but only in CW right now.
beam0
(beam0)
January 8, 2018, 9:18am
144
JasonWW:
Ya 1x or 2x would be too cold for me and 5c (3800-4000k) probably too warm.
This is one reason this JAXMNVE M3 appeals to me, it has NW 3C which should be around 5000k
JasonWW
(JasonWW)
January 8, 2018, 9:37am
145
beam0:
It does not register a double click from off. It sees it as 2 seperate clicks.
beam0
(beam0)
January 8, 2018, 9:25am
146
XXX-Man:
beam0:
When it enters ramping does it start on high or low?
2. on low
So when starting in ramping it begins with LOW by default, but if a specific level was memorized it starts on that memorized level, correct?
JasonWW
(JasonWW)
January 8, 2018, 9:27am
147
You are correct in your assumption.
In Narsil you can easily reverse direction if you want. With this jaxmnve you just have to let it do what it wants.
beam0
(beam0)
January 8, 2018, 9:30am
148
So double click from off does nothing, from what I can tell.
Would’ve been real nice if they made it enter ramping with a double click from off - for quick access to your desired (memorized) level.
JasonWW
(JasonWW)
January 8, 2018, 9:31am
149
You can? Where?
I only see it for $18 more.
JasonWW
(JasonWW)
January 8, 2018, 9:36am
151
beam0:
You misunderstand.
A double click from off turns it on at the last used level then advances it to the next level.
Once you leave the ramping mode, the memory is lost. It memories every level. If you turn it off in strobe, it comes on in strobe. If you turn it off while it’s ramping, it turns on and continues ramping.
JasonWW
(JasonWW)
January 8, 2018, 9:38am
152
Beam0, aren’t these questions moot since there appears to be a new UI and you can’t buy the old ones any more?
beam0
(beam0)
January 8, 2018, 10:46am
153
No, the new UI only changed the 3-mode group from MED-HIGH-STROBE to LOW-MED-HIGH, ramping should still be the same.
New UI:
