The most common “pure” copper used for machining is TeCu, barely loses any proprieties with 93% conductivity of actual pure copper and it is well over aluminum alloys like T6061-T6 that are only 40%
These go hand in hand though.
Silver is the best both thermal and electrical.
Copper is second, i think aluminium is third. (correct me if i’m wrong).
Benefits of Aluminium is light weight and easy machining, and the fact that you can give it a strong(er) ceramic layer by anodizing.
Funny as I’ve never thought about this before (edit: probably forgot about it). I have been told in high school that the electrons in metals are the primary carriers of thermal heat for conduction, and the electrons are covalent electrons. And covalent electrons should obviously result in good electrical conductivity.
They never told me that, or maybe i wasn’t paying attention.
Makes sense.
I did know heat through metals behave somewhat similar to electricity.
A good example is a thermostat with a rather thin copper wire to the much larger ‘sensor’, like you find in gas heaters.
Heat/temperature is basically kinetic energy (= energy) of the masses, i.e. protons, neutrons and electrons. The protons and neutrons are stuck in their places, whereas electrons they can go wherever they feel like going. So although electrons have very small mass compared to protons and neutrons, it is their extreme mobility that makes metals good thermal/electrical conductors.
I was talking about electrical conductivity, in that case is applicable.
In any case the amount of theories are astonishing for a 2cm piece of material.
This is a super tiny body in 18350 that because of the titanium electrical resistance should not even output as much power as the
aluminum versions, thus the heat produced by the LEDs will be less, all theoretical.
Not sure exactly as how much the very low electrical conductivity of titanium alloy will impact current as the walls are not that thin to start with so the resistance cannot that high, still.
My guess is that it’s not going to matter that much. So yes in theory, no in practice. There will be an increase in electrical resistance, but this will be so small in absolute resistance term due to quatitative reason (size of the battery tube) that ΔV will remain small/negligible. That’s my guess.
A very interesting post, real life test on the D4Ti 18650 vs D4 Aluminum both NIchia 219C
It is not monumentally worse compared to full aluminum as theorized by some, starts with 8% less theoretical output comparing the 226 number to 209, but as the runtime goes on keeps a higher output for longer than aluminum.
Now that smoother stepdown that keeps the output much higher for longer time could also be due to randomness in the MCU temperature sensor, just a pessimistic speculation, rather than a optimistic one (which would be, copper does that)
That initial lower output can be due to actually more than one reason, optic now matching 100%, higher electrical resistance of the titanium, LED manufacturing tolerance, MOSFET manufacturing tolerance, etc.
From my younger days when we use to overclock cpu’s, the heatsinks were most important and a lot of RD was done by heatsink manufactors to achieve the best cooling. They were made using a cooper core to absorb the heat and a aluminum exterior to get rid of the heat. It was always my understanding that cooper absorbed the heat the best but aluminum shed’s the heat quicker, the best properties of both metals.
Got my EMISAR D4 Ti from Hank at intl-outdoor.com yesterday.
It is a very nice light, like all the other D4 models.
Mine version is the RAW (A) model:
Nichia 219C 90 CRI 5000k
Optic 10623 floody
18350 tube.
D4 Ti
Weight w/batt : 170.9 g
Weight wo/batt : 126.7 g
Head (alone) : 70.7 g
18650 tube : 46.1 g
18500 tube : N/A
18350 tube : 24.2 g
Tail cap : 9.8 g
D4 Alu
Weight w/batt : 110 g
Weight wo/batt : 66 g
Head (alone) : 30.6 g
18650 tube : 28.5 g
18500 tube : 20.9 g
18350 tube : 14.4 g
Tail cap : 7.1 g
shame its so expensive, u land at around 112$ no matter what emitter more or less unless u want the nichia which doesnt cost extra, the other emitters are +18$ and color choices +15$ just too much…
Hi JamesB
It feels just like what you say, like “sand” in the threads.
That said, threads go butter-smooth into the head - nothing there.
In the “tail-cap” I think the “problem” is. You cant see anything
but you can feel it when you put it on - all way till you tighten it down.
I lubed the threads on the tail-cap, cleaned it all off again.
Did the same thing over again a few times so I could say that
it was “all clean”. It got better, but still a little “sand”-feeling.
This goes both for the 18650 and the 18350 tube wich tells me that the “problem” is the tail-cap.
I will leave it as is for now and hope it will wear out to the better.
