Same for me
ARRIVED…with batteries…
It’s big.
Thanks to all those involved who made this happen.
Have only checked that it was alive after it came, and so far so good.
Did not know that it was on its way.
Only coincidences that I via the BLF blog saw that there were others in Europe who had been notified.
Then I called my local DHL and checked if something was coming to me…and that was it.
Thanks again
Same here. Thanks for allowing me in on this amazing groupbuy.
The 2nd GT that I received has a very slight OP reflector also. But I don’t see it as a big deal… it’s really very slight; certainly not as pronounced as yclongthrows. Do I expect perfection in a budget light? No. As was previously written, it’s a balancing act between perfection (big :money_mouth_face: and production.
I was actually presently surprised that my first GT had such a high quality reflector surface.
Are we sure the OP that people are seeing is actually that and not just milling marks.
I grabbed a couple of lights and had a look at their reflectors and realised that my “silky smooth” Niwalker light actually appears to have ring marks on the reflector when you look at it from the right angle.
Still waiting for mine to land in the UK - well, it might be in the UK but no tracking has made its way to me.
Took this shot with my phone within minutes of taking the GT out of the box, my Dad held it next to his Q8…
This is the light that hit the water tower at 1.9 miles. Don’t see how any of the slightly noticeable non-mirrorlike finish affects the beam.
How do I turn on the switch light? It was off from the beginning. I also did the factory reset. Still not lit.
lol Dale. When the comment was made that your reflector must have been perfect to hit the water tower I chuckled knowing that our lights shipped at the same time and likely looked the same. My gt has the exact same surface as yours. I’m happy with mine. What is really great is it was suggested that the reason the warmer emitter version had less light on target was because it was probably a light with a slight op reflector. Looks to me like the light you swapped the cw emitter in has the same dreaded op ish reflector. Thanks for the pictures once again! It would seem the the throw of the gt is excellent with that reflector
Did you make sure that all of the batteries are fully charged?
I’ve read the manual and it states that the flashlight will eventually turn off at low voltage. Can someone confirm at what voltage does that happen?
Yes, all 8 30Q are fully charged.
Another confirmed arrival in Norway here. The first I knew about it was from the DHL guy standing outside my door with nobody home.
Shipping: DHL
With Batteries
100-something on the original list
Many thanks to the BLF team!
Just waiting for the batteries to charge now.
Are you sure that you did not get an opaque switch cover?
I have some info here.
It’s completely dark black. Must be opaque
Does this work also with unprotected cells? If it shuts off at ~3.5V then it is fine.
If you ramp down then click off, the switch lights will be disabled. Click it on, then click it back off… switch lights should be on.
If in lockout (4 quick clicks) the switch lights are also off.
Tom knows about the switch light on off “feature”. I’ve done it many times on the Q8. When your ramping up from on or anywhere hold the switch from the ramping then quickly click it off. That should change the standby switch light from off to on or vice versa. The software on the GT is different and I played with that setting not my GT, just the Q8. Hope that helps.
Mine arrived in Sydney Australia yesterday, 1 day before the DHL estimate, ~3 weeks after payment.
What an amazing flashlight, it is great to see we can still make such high quality items at decent prices.
I could now use a cradle to mount it in a vehicle, also perhaps a snap-on cover to spread the light as an option; simply some accessory ideas from a happy customer - thanks to all who made it happen.
