Joson has problems to connect to BLF, so if you need to ask him something, have contact through Gearbest message service
That’s what I did (on Ali) before ordering.
This guy is awesome and gives always a pleasant answer
Yes, I ordered yesterday a 4000K Nichia 219C without strobe-sos.
Waiting… waiting… Xmas will not help shipping
Postman gave me the parcel today : E2L Light Gray 219C-4000K without strobe/SOS
Great product, great beam, just what i wanted :+1: .
But when I tried to mesure stepdown/runtime in High mode, 10mn after ON : the light began flash/strobe like for “low battery” indicator, but battery was full, the flashlight was very hot… is it a thermal protection ?
Is it normal not to be able using the E2L on Hight more than 10mn ?
A tube style 18650 flashlight like the S2+ can sustain about 600-800 lumen (or 2000mA) without functionally damage, I even runtime-tested a S2+ at 3A/800lumen and it got 90 degreesC eventually but did not fail, but it would burn your hand. A E2L has some slight finning near the led so it should be able to handle a tiny bit more output but still the limit is probably still close to that of the S2+. The E2L if I’m right comes with a 6x7135 driver, so 2100mA, that should by just be sustainable, but I can imagine that Jaxman has build in a thermal stepdown that kicks in at lower temperature than 90 degC to prevent burning your hands.
I have an XP-G2 E2L that runs just fine for over 10 min. You might need to check out your battery. Light should run for 90ish min on high with a 3500mAh NCR18650GA. It will get very hot running sustained for that long though. Nichia 219’s do get hotter than the XP-G2.
:person_facepalming: I wrote “full” battery, but in reality it’s a new one (never used, never charged… still waiting my charger) I expectd new battery were full… :innocent: (n00b error)
For the same Amperage or for the same amount of lumens ?
I think it’s because the Nichia has a lower VF than Cree, so it draws more amps causing the LED to get a bit hotter. It seems if you want a higher CRI like the Nichia offerings, you’ll have to give up some lumens and get a little more heat.
The lower the kelvin LED, the lesser the lumens. To make a NW and WW led like the Nichia, requires darker or additional phosphor. Because of this thicker blanket/darker phosphor covering the blue LED it lowers the lumens vs a CW LED with less/lighter colored phosphor.
You mean “blink” for low voltage protection ?
No, on the Convoy with 3-5 driver, what I understand is that at startup in Low mode, after a few seconds, light blinks once (and at this moment you can begin group switch procedure) Maybe I’m wrong…
I don’t know what the E2L’s LVP protection warning pattern is. My batteries have a protection circuit on board and shuts off power before the light’s built in warning has a chance to activate.
Ok, but I’m not speaking about the LVP blinking
On the Convoy, light blinks one time just seconds after Low mode is selected, and at this very moment you can switch from group 1 to group 2.
Example on video : - YouTube
It was also possible on the Jaxman X1 (but I don’t know how) and I’m asking if it’s the same thing on the E2L… or not
I’m having a problem trying to replace the stock driver of my E2L. The TIR lens does not move at all, it’s stuck firmly to whatever underneath it. I’m afraid I’m gonna break its legs before I can remove it. Any suggestion?
