I think that version has not been reported yet. It does fit under the quad Carclo, but the S41 optic is a bit different.
Thanks Djozz, I will have to check on the Carlco quad.
I have their triples, but not a quad to check if I could make it fit. If I recall correctly the S41 optic is only 22mm, where the Carlco is 24.
May be possible to shave it down a bit, 2mm is not much. Pics on MTN looks like I MIGHT be able to just get away with it.
Double tap is just shortcut, so if you have 4 modes and 2x tap to high enabled, modes will work 1-2-3-4 just as usual, 2x tap mode jumps to mode 4 from any other mode.
About S41 optics, if it's different than carclo then it would not fit. I have several more mosX boards on my wish list, I could add S41 to that list too, and make them in next batch, but I need detailed drawing of such board.
Unrelated to this, I have soldered Luxeon V LEDs on mosX 4040,3xV,4xV with soldered LED wires ready to use, I just need to list them on my page.
Coupon codes for larger orders:
L4P-3of50 3€ for every order over 50€
L4P-10of100 10€ for every order over 100€
L4P-25of200 25€ for every order over 200€
L4P-45of300 45€ for every order over 300€
@ led4power
Any idea when you will have the Luxeon V on 16mm DTP mcpcb back in stock?
~3weeks.
I just placed an order for some quad MCPCBs with Luxeon Vs but I didn’t see any tick box anywhere for reflow service, neither did I see any place to add message on placing order. Is reflowing the LEDs onto the MCPCB included? If not, do you offer reflow service? What would it cost? I’d like my the LEDs reflowed if possible.
I'll put listing with soldered LEDs as soon as I find time, until then you can order LEDs and mosX separately,and leave note about soldering LEDs, no extra fee for soldering.
It’s the order placed to Sweden at about 23:30. I can PM you order number if needed.
A question about the MOSFET option for future orders if I may. The MOSFET that you put on if option is selected, is it specific for your drivers? I’m wondering if I could use it for mine own drivers as a full on boost mode and get similar results as with the SIR800DP.
OK,I see it.
MOSFET is just that, mosfet, you can use it with any driver that use mosfet, DD or linear. It has 2,4mOhm resistance, one of the lowest in LFPAK33 package,and should be good in most cases.
Even with DD drivers, having mosfet on LED board is beneficial because:
-it saves space on driver board (more space for other things),
-Even on "DD" mosfet has finite resistance, if mosfet is on driver PCB at 10+Amps it would generate enough heat to make internal uC temperature reading wrong/problematic - with mosfet on LED pcb there is nothing left on driver pcb that could generate larger amount of heat, so temperature sensing with internal uC sensor is much more predictable.
What’s the current limit of this mosfet? Is it good for 25 Amps with single cell DD?
25A without problem. Power dissipation in that case is 3-3.5Watts, this is no problem on any mcpcb. On the other side 3+ Watts on driver's FR4 pcb would cause melting if there is no additional thermal path (silicone cubes etc.). Internal uC temp. sensing would be pretty much useless for thermal regulation/stepdown.
Thanks for the info!
To find out resistance of spring that I have for sale HERE
I used rigol DP811 in CC mode at 1,2 and 3 A and measure voltage drop with 4-wire method.
Djozz did similar test for few springs quite long ago: https://budgetlightforum.com/t/-/29825
I measured resistance for 3 other springs to check consistency: convoy steel spring, fasttech bronze spring, Intl-outdoor beryllium short spring.
Results are:
Convoy steel spring:
1A 43,5mV :R=43,5mOhm
2A 86,4mV : R=43,2mOhm
3A 133mV : R=44,3mOhm
Avg. resistance: ~43.7mOhm
Fasttech bronze spring:
1A 22,5mV :R=22,5mOhm
2A 44,8mV : R=22,4mOhm
3A 67,2mV : R=22,4mOhm
Avg. resistance: ~22.4mOhm
Intl-outdoor beryllium short spring:
1A 7,4mV :R=7,4mOhm
2A 14,63mV : R=7,32mOhm
3A 22,5mV : R=7,5mOhm
Avg. resistance: ~7.4mOhm
Phosphor bronze spring 12x9x1mm
1A 13,4mV :R=13,4mOhm
2A 26,82mV : R=13,4mOhm
3A 40,5mV : R=13,5mOhm
Avg. resistance: ~13.4mOhm
It's obvious that measurements are very consistent and independent of current.
At higher currents resistance of steel spring starts to increase due to temperature rise caused by power dissipation.
Intl.outdoor spring has smallest resistance, but it's also the shortest,and not very "springy".
Conclusion is that 12x9x1mm bronze spring is good for currents up to 6-7Amps without need for bypass, which should be perfect for medium (by today's standards) lights, or for SRK-like mulitcell lights.
Spring is big enough to add bypass of course, good thing compared to bypassed steel springs is in case of bypass failure spring has still very decent conductivity and probably won't melt,unlike steel springs.
^ :sunglasses:
Thanks for the testing led4power. :+1:
Very nice, thanks for testing!
I have to say, you’re doing an amazing job offering specialty products which precisely cater to the unique needs of modders on the flashlight forums! You fit in perfectly with some of the other guys like Clemence and Lexel (and maybe the Sandwhich Shoppe 10-15 years ago). Everybody has their own niche where they offer their unique products. You seem to be especially motivated though to offer stuff that has never existed before and is very practical. And all of that for such nice prices from a guy who knows what he is talking about.
Finally first LD-B4HV test (Luxeon M 6V version as test LED on 20mm 4040 mosX, 6A LD-B4HV):
6A high mode, top side of mosfet is still cold:
Two 6V Luxeon Ms in series as simulation for 12V (4S) LEDs like XHP-35:
6A high mode, 16.4V input, around 100Watts input/output power:
I will try XHP50.2 in Convoy C8 host with LD-B4HV and 2x18350 Aspire cells soon.
Have I missed something or is this your new 2S/3S driver? Side switch capable?
Yes, this is 1S-4S variant of LD-B4 (1S only). Side switch will be available later, it's supports clicky switch for now.
