I am thinking you ae right, combined with the faster feedrate that it seems like they are using to speed production that would explain the reduced smoothness over time.
Rather odd issue here. The switches are most likely soldered before they get to Lumintop and done automatically I would assume. So my first guess is a simple error in the production, very unlikely to be widespread.
That said, better safe then sorry, I will be sure to let Lumintop know.
If this was delivered by banggood you would have the same shipping options as you have now. Priority mail would cost extra and be slower then DHL. So you would be better off with DHL.
Now if you needed priority mail for customs reasons, it would cost a fair amount more then registered mail.
Remember this is not a 100g flashlight they are shipping, this is a ~2500g monster. Shipping is VERY different when things are that big.
My gt is stuck at customs 150km from me. Dhl is not sending info what i need for paying taxes(24% vat). Maybe tomorrow they send those, then monday could be delivery day
I just got a reply from Lumintop about the reflector quality.
They assured me that they are trying to keep quality up while making them as fast as possible. They also wanted to be clear that they will never reduce quality to save costs.
I told them to not worry about the speed as much as the quality going forward.
The factory appears to have a real issue with making reflectors this large with consistent quality. These are the largest reflectors they have made by quite a bit. So they are still learning how best to make them.
Just thought I’d add that mine isn’t here yet in the UK. I’d assume you’ll get a wave of people per country getting them at once.
It is amazing how quickly some of these items arrive once they’ve been shipped. I know how long it takes to catch a plane to some of these places and these parcels sure dont hang around!
Well said giorgoskok… :+1:
In addition Banggood had nothing to do with this, so I doubt they would be interested in shipping the lights…. just my thoughts of course.
So far it appears that all the reflectors have been at or above the V1 prototype quality, which was the standard we gave them when we started this. So yes, from what I have seen they have all been within spec.
The ones better then spec, are well, better then spec and a bonus. They were never under any obligation to give us that quality.
Thought I remember seeing that minimum distance for measurement was 40 meters or at least something further than you used because beam convergence has not occurred at the shorter distance?
At least it must take 10 meters to measure CD, in a launcher of this size, it is likely, that it does not reach to collimate the light, also it has to do double click for turbo 2.5 amp.
I too saw greatly reduced lux numbers in my normal 5M tests. I set up and did a 15M test and got 1.2375Mcd. But that figures out to 1.38Miles and then I did the beam shots that showed light hitting the water tower at 1.9 miles.
I have a couple of friends coming over this weekend for an emitter swap party, we’ll probably do a 50M test on all our GT’s after the swap. They ordered D4 emitters at 5700K from Richard, I found some E4 5700K at Arrow in HD trim, have them on the way and will try slicing the dome off and chemical de-dome, see which works better. The Cree datasheet lists the HD D4 at 550 lumens at the 350mA test level, the E4 does 717 lumens at the same level. So I hope to get a clean slice and replicate the HI and see 2400-2500 lumens out the front in mine. A buddy told me that Coleman lantern fuel does very clean de-domes with little tint change, I aim to try that.
We will have 4 GT’s here this Saturday, should prove interesting.
