It is at No. 588 and 589 on the Interest list of The Miller .
Please darrylo, … Total 4 units?
Yes, I wish to have 2 of these flashlights
One for me please, add me to the list.
I now require 2 please.
Updated list : … Post moved to Page 130 , FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3870 by pepinfaxera
Short list, Last requests .
FWIW, I upgraded the thermal regulation behavior. I still need to do some extensive testing on it, but hopefully it will behave. Specifically, it adjusts the output in about 640 very small steps until it thinks it is no longer too hot or too cold… and the adjustment speed now changes depending on how far it needs to go. Additionally, the adjustments are based on the projected future temperature, which works like a car trying to “steer into” the curves.
Hopefully this will allow it to react quickly but also avoid oscillations after it has reached a maintainable level. I won’t know for sure until I test it though, and that takes a while.
This is why we CAN have nice things. You rock. Really though, I wouldn’t even know where to start with this stuff. This is awesome.
I would like to be added to the list one more time. Total of 2 please. Thank you.
I will take one please.
Rob … Post # 355
It is at No. 246 on the Interest list of The Miller .
I now require 2 please. … Post # 2155
Total 3 units?
Ok, I have finally decided: Please put me down for one!
Thanks!
EDIT: It’d be cool if there was an option to pay a bit more to select Nichias? I’d pay another $10 for that
Please add me to the list for one.
Cheers
In for two
Thanks!EDIT: It’d be cool if there was an option to pay a bit more to select Nichias? I’d pay another $10 for that
Now your talking. I would gladly pay an extra $10 for the nichia. If this ends up with a green tint mine is just going to be a paperweight.
Sure wouldn’t want to overload our resident Genius but how neat would it be if this light used 3 carefully selected tints to emit a near perfect output? With the proper optic to blend them, of course… is this doable with the XPL HI emitter? (optic is, of course, meant the mixing of tints for a high CRI 5000K output)
Hello everyone, IF the list is still open, i’m in for one. Thanks
Interested too !
Please add me to the list.
I have built lights like this… I really like how they turn out…
+1 from me
Nichia option is also a good idea.
… blend… XPL HI emitter
Which XPL HI and optic do you think could accomplish this? It’s hard to even find 3 different XP-L HI leds as choices from vendors or manufacturers. I would totally consider this but not even sure it could be sourced easily to mod.
I like how my tint-mixed quads turned out. I haven’t gotten a triple to look quite right though.
It should be doable with XP-L HI and a frostic optic, but it’d probably be easier with three high-CRI Nichia 219c emitters instead, since they’re less tinted to begin with. Perhaps 4000K, 4500K, and 5000K. Together they should look pretty good, but I haven’t tried it.
I’m not sure if 10511 is frosted enough to make the tint-mixed result look good. It might be necessary to use 10508 or 10509, but that’d make it a lot floodier. 10511 might be okay if we don’t mind having a few different colors of mild artifacts.
Please add me to the list for 1 light
