Sure it can be anything within the limit. I just wanted to put sone numbers in. I have seen ThruNite TN40S can illuminate 750 metres pretty good and is average-good flooder as well.
Haha, I am really sorry about confusing you. English is not my native language. Let me try to explain again.
I would like to have a flashlight that is not a like laser, only illuminates the far distance but also one that has a very nice beam profile so the light smootly lights up the near objects and as well as the distance. Hopefully this helps. Cheers.
I don’t have one yet, but from what I have seen they appear to offer great throw and flood, and couldn’t be much better in terms of build quality, support, and reputation.
Zoomie is a light with an action called zooming - you adjust the beam width from wide and moderately bright to narrow and very intense.
They tend to be superb throwers (no spill to distract your eye, good throw-to-size) and superb flooders (very smooth beam) in the same package, but not without drawbacks:
the common zoomies are very inefficient in the throw mode - the beam is bright but narrower than that of a reflector light
unlike with reflector, you can have flood or throw, but never both at the same time. If you look far, you won’t see what’s under your feet.
often they have worse cooling than similarly sized reflector lights
typically you’re limited to using a single LED, so they won’t get close to the output of mega-flooders. No multi-led zoomie I’m aware of is good enough.
There are less common types that are better or worse in one way or another, I won’t elaborate on them now because I don’t see one that would work well for you.
Well, I don’t see a stock zoomie that would match the description, so if you want that route, you’re limited to modded lights. I’d suggest UniqueFire UF-1508 T75 with (dedomed?) XHP70.2.
Wow. Thank you very much Agro for getting into this hassle and giving me a perfect explanation of what it is. I really appreciate your time and effort on writing it.
BLF Q8 would seem like a good starting point. Whether it will fit your needs is for you to determine, but in any case it is a very good light you’ll be happy to have.
Since you don’t have any lights, it is very unlikely that you’ll find the perfect one right away…
Like 175k lux and 5000lm. I’m all about performance.
I own the TN40svn which does 500k lux and 9000lms which I feels very throwy. I think 35 lux to 1 lumen is a great combination. Something with just a little more throw than the Acebeam K60 would be perfect.
