I have done two spacers with coins and it all went well, but then I thankfully found kiriba-ru and his selection!
While making coin spacers is a ton of fun (“I did it on my own”) - you would also have to account for sanding time, soldering, drilling the whole thing and then cleaning. All in all, it is fun to do and a great workout but an actual copper spacer for a few dollars is probably the more economic solution.
Coins however also allow to alter the size of the coin and make different spacers easily - you could combine 16, 20, 15, 20 (and so on) and it looks like more like a heatsink rather than a spacer.
yeah finished them just now , lots of sanding, soldering, cleaning and drilling but fun! However I never sanded them down for soldering, only the contact surfice to pillband led board! Should I sand the solder surfice aswell? And redo them? I mean the coins sit perfectly on top of eachother but dont know? Maybe the solder filled the gaps lol?
I did this a while back with some old pennies. I sanded them all flat first, it was a pain in the ass but I was actually able to turn the stack on the lathe afterward.
Yeah I filled the top of the pill with solder and sanded it smooth aswell to get a bigger surfice for the spacer to sit on and aid cooling aswelI! Hope solder works well for heat dissapation? The coins were a bit uneven but I think it will be fine, migh just aswell try it! I soldered the recessed top of the pill and holes shut!
The Euro coins that look like copper (1 cent, 2 cents and 5 cents) are not copper but an alloy with a lot of iron (they stick to magnets).
I wouldn’t advise anyone to use them as heat sinks.
But i would suggest to get some 20 × 20 mm copper shims.
You can find them cheap on Ebay and AliExpress and they’re available in 1 mm and 1.5 mm thickness.
Yeah I thought so too, but found a page about euro coins and they use a nordic gold named mix! Seems good to me don't know! How would I know if the cooling is good or not other than it gets hot? Measure temp somehow?
Yeah, wanted it done now, since my leds came in today, so decided to make my own, and it's hard to find these spacers in europe and kaidomain don't sell any and they're expensive too, more fun to make your own rather than buying imo! Question is how good will it cool?
I checked temp with an infrared thermometer, coins vs copper spacer (from kiruba). there was almost no difference with a FET driven S2+ (XML2 U4). Could also not feel a difference while the light was in my hand (subjective).
I have not done the test with a triple or quad setup yet, but can do it once I build them.
I already made the spacers, why would I need the copper shims,to make a spacer?
I got some 2mm copper sheet aswell at home but need to buy a 20mm hole saw! Maybe stacking 2mm copper plates would be best? I'm gonna try the coins tho will see how it works!
I soldered my mcpcb straight onto the coin spacer, therefore didn’t need any copper shims. If you sand everything down you wouldn’t need them, I guess?
I'm gonna use thermal paste between spacer and mcpcb, but couldn't get the spacer to stick to the pill itself, so have to use thermal paste there too! I see most people run the spacer loose anyways with thermal paste!
If you have sanded enough between pill/spacer and between spacer/MCPCB you’d only need a bit of thermal paste and you are good to go.
It took me 2 attempts when I soldered the spacer to the pill, forgot the flux initially. Then I soldered the MCPCB onto the spacer and forgot the LED was still on there or thought it would stay. it detached and fell into the carpet. lol
Anyway, it is all soldered together and it rocks. No thermal paste at all, which is perfect.
