ok, I have some 2mm copperbplate aswell that I could hole drill out and stack, but I guess with 2mm each it would need even more heat than the coins to stick? Or do you think my coins will be ok?
So like I said I filled the top recessed part of the pill and filled the 2 holes all with soldering tin so it's all flush and sanded it smooth! Do you think this was a good or a bad idea? I mean it should give a little more surfice area for the spacer to sit on instead of the thin edges only!
Yea the proper spaces have a slightly smaller diameter on one side like 18mm so it sits inside the lip of the pill. More contact area that way.
that's why I filled it with solder, so now the top of the pill is nice and flat as wide as the pill, nice surfice for spacer to rest on, do you think the solder will cool enough?
I'm slacking better put up some pics soon too, should I just upload random pics or add some story behind it too? It just takes so long to upload pics and then write about it too, that's why I never do lol, but I understand pictures says more lol
I am not sure. I’d leave it with just the spacer and pill sitting on each other. Once tighten you will have pressure making every thing stay in place. Plus the spacer is wide so there is no side movement and the lip help keep it stable.
Build it and see how it works. If the LEDs go blue they are to hot. Either way you won’t get long run times in small light with that much power.
Yea upload pics and write a few words future modders will find the info useful especially about how you made the spacer.
Hah, no I won't get any long run times lol, should be better than 18350's tho hoping to try it tomorrow and then making some pic updates after!
doh....oh ok well guess I'll have to lol No but I'll do that for sure
I might make some new ones to get a better solder connection between the coins later or cut some 2mm plate and stack it bit for now I'll try it out! Each led won't get that much current anyway, so should be safe?
Are you running them in direct drive? Just think how hot a standard s2+ gets with 1 led at 3amps. It’s safe but I wouldn’t give it to just any one to use lol.
I wonder if you can forge the coins?
Forge? you mean in fire like a blacksmith? I used a small iroda butane torch heated up in vise and soldered on top and sandwich them together so excess tin came out! I use the blf a6 driver!
Oh I see! I basically did some forging today then haha, when I melted solder into the pill and smoothed it, you can actually forge some stuff with tin right?
I did it. Just for fun and without pretension to perfection - I did not even sand the surfaces of the coins.
The first pics in the thread. :)
I used 10 euro cent.
But it works very well - now in a S2+ Triple with Osram Oslon Square CQAR.CC 96 CRI (3500 K), Carclo 10509 and 1500 lumens. :)
After 30 sec. the temperature on the head is too high to touch it which means a efficient heat dissipation. This idea is not bad and an alternative if no lathe or spacer available.
sweet! looks similar to my spacer I'll put up some pics! However mine is not that even lol! I didn't even think about adding a smaller coin to fit into the pill, I just filled the recessed top part of the pill with solder and sanded it smooth!
10 cent euro coins: nordic gold mix, 89% copper, 5% alu, 5% zink, 1% tin
Soldered together with torch, cleaned with acetone first!
Drilled hole and sanded smooth
Drilling pills:
Filling top recessed part of pill with solder!
Sanded pill
Filled again!
Pill Sanded smooth!
Spacer sanded smooth!
Finished!
Stacking 3 coins and sanded to 5,5mm works best for me nice and tight lol!
Going to update with light finished soon!
This was very fun but time consuming lol! I might make some new spacers and sand in between them before soldering first!
Or I might cut out 20mm spacers from 2mm copper plate that I have with a hole saw and stack them together!
For now I'll try this! Stay tuned! Yeah yeah pics are late blah blah blah haha! Had some pc issues lol!
you beat me to it haha!
So the fact that I didn't sand between the coins is now bugging me should I redo them sanded between before soldering?
You can’t even buy that much copper for that price of the coin lol.
It looks fine to me.
Yea you where some what forging the coins you could probably melt them down and pour them into a mould that is already the right size. But that’s just overkill.
you guys rock, these are really nice spacers!
good craftsmanship
