Nice testing, Jensen!
(I do not think that in a flashlight, with a 1.5mm copper boards and even a shelf under it, the sitiuation would be much different from this, perhaps overal less heatsinking but not spatially different.)
Interesting test. I always set thermal control to 60C ,according this result 2-2.5A will be best current for that settings.
Now we know when to stop increasing current. 135C is the safe max BLF limit and 150C is the absolute peak max. Beyond 150C the output will drop sharply and start to smoke anytime. Laser guided temperature meter should be affordable to most people while TI camera is the best. Don’t try to touch the LED using thermocouple probe or you’ll risk burning the phosphors layer.
- Clemence
Update171226: OP updated with VR16SP4 CCT mixing test results (scroll to the lowest pictures)
- Clemence
New test of E21A quadtrix. My second reflow attempt this time. Change to the test setup included an addition of a lux meter, though not a great one and not mounted well, but it did provide some insight into peak output.
Below is an image compiled by Clemence showing all of the IR images taken in the test, as well as some plots of the data taken. Emitter setup was 2S2P. Please note with the Lux data that I did not turn off the room lighting, so it started out at non-zero. The setup also means that the number could be changed quite a bit just by moving around the room, so they are very approximate.
On this test I went beyond the 150C phosphor temp based on lux meter readings. Peak output occurred at 5.5A!
Phosphor temps were imaged up to 5A, at 5.5A I unfortunately messed up and didn’t save an image, but phosphor temps were bouncing around the 200C mark. At 6A I did not take an image as I saw the temps at 210 and rising and the lux meter was starting to drop fast, so the test was immediately shut down.
This was the result of that 6A run, slightly browned edges right where the two hot spots are between the emitters. If i hadn’t shut it down quickly I predict it would have ended up like the emitters Clemence shows in the 1st post. This also proves the photon absorption, and I am fairly confident the Rev.2 boards with larger gaps between emitters will be capable of even higher output.
After this I tested a hypothesis from an observation of my last test. I re-ran the emitter at 4A for about 5 minutes, and then ran the full sweep from 0.5A to 4A again, with only about 30s per step, just to check Lux. Lux was basically unchanged, I could move my arm and change the number more. Visually the browning is now gone too. Not sure what causes this phenomena, but Clemence has seen the original images with their attached timestamp data and can verify.
It will be interesting to see if more people push these LEDs and also observe this strange healing effect of the phosphors. Will also be interesting to see how the new gapped MCPCB layout changes performance and the hot spots.
Thanks Jensen, you’ve been extremely helpful in VirEnce board development and testing
As we discussed earlier last (my) night, there are many factors regarding this wolverine LED. It’s so interesting that the output didn’t change that much (you said the change was too small to be meaningful). I got the same finding but because I cleaned them for the second test, I assumed that was the IPA. I’ll ask Nichia today for surer answer or insights.
Another important thing is: E21A is VERY sensitive to solder quality. My results were on par with your first test (too much solder). I used leadfree solder with worse wetting hence the
Thicker solder joints. Like I reported two days ago, I got so much better result and way easier reflow using cheap 60/40 solder. Your 63/37 is the way to go. For extreme drive current, E21A must be reflowed with 63/37 or better. Lower reflow temp also keeps the solder mask white.
- Clemence
Found this mother next to the board.
FYI: the boards have arrived. Will check it tomorrow in the custom office.
- Clemence
Testing with 2S2P so… 6 volts’ish in?
Correct Matt
Please check the pictures in below link. I added some configurations diagram there
https://www.virence.com/blank-rwrlr/vr16sp4
- Clemence
If I am looking at the pics correctly, for a 3V setup one needs 2+ and 2- wires?
Unfortunately yes. No space left on this tiny board to create jumper pads without compromising optic’s base or safe side margin.
I’ll make add on secondary jumper board for use on top of it in the near future.
- Clemence
Cool pics! Is that some species of paper wasp?
I think so Looks like its a digger wasp (Sceliphrinae). She didn’t care about anything but her egg safety. Filled two of the M3 screw threads on my testing block.
- Clemence.
Specification:
Changes are highlighted in bold
VR16S1
- MCPCB thickness: 1,65mm ±0,1mm
- Dielectric thickness: 10µm ±3µm
- Dielectric thermal conductivity: 7,5W/MK
- Copper trace: 70µm
- Solder mask thickness: 15µm ±5µm
- Anode - cathode gap: adjustable from 0,5mm down to 0,2mm (was 0,5mm to 0,3mm) by scraping off the masking
- Brighter reflective white solder mask
- Tougher solder mask (untested): prevent yellowing in sustained leadfree 260C environment.
- Copper pads plating: OSP (was ENIG) to get every last bit of thermal performance
- Flat section for V-scoring 15mm maximum (was fully round): mass production consequence
VR16SP4
- Copper trace: 35µm (was 70µm) for better reflow process
- Anode - cathode gap: 0,2mm (was 0,3mm)
- Final quadtrix footprint: slightly adjustable from 4,4 x 4,4mm to 4,6mm x 4,6mm (was 4,2 x 4,2mm to 4,4 x 4,4mm).
- Clemence
Clemence, how hard would be to install vr16s1 with 144 in KF8 ? Seems like perfect host for that combination, except mcpcb size is 20 instead of 16…
You can always run a 16mm PCB in a 20mm spot with no problems. The light should have a centering ring for the reflector and emitter that will ensure the MCPCB is held in the correct spot.
However, jf there is no clamping pressure from the reflector to hold the MCPCB to the host, and instead the host relied on screws to hold the MCPCB down, it is likely you can just use washers on the existing screws to clamp the MCPCB.
Unable to checkout by PayPal?
Order No. 10131
Could be your ends. Looks like anyone could do it without problem. Try to clear your cookies and cache first.
- Clemence
again
EDIT:
It may be a problem with my VISA card.
Great news!
The VR16SP4 alpha board test was a success! Although the test could not be completed due to inadequate power supply, the result was already very near it’s peak.
Reflow preparations:
Magnifier application and phone stand is invaluable when working with E21A
Dropping the solder paste. I’m done trying leadfree with E21A. Pb63Sn37 is the best.
Carefully even out the drops to match the pads and then placing the LED, try not to smear the applied paste too much. In this picture I dropped the LED too far away from the target.
Fine tip angled tweezer works best for me. Next to the ceramic tweezer is the press to open tweezer. You’ll need to decrease the tension if you want to use PTO tweezer, E21A’s sides are very soft/fragile.
Ready to go to my “deluxe” gas kitchen stove reflow oven… The final positions will be adjusted later, I tap each LED tried not to move them sideways to make sure the flux wet all pads evenly.
Done, cleaned thouroughly with IPA and toothbrush. Ready for the test
PSU, DMM, Lux meter, Digital thermometer + probe, Test block, big heat pipe fanned cooler, and notepad. Where’s Wally?
I found the heat sink in the last minute, it wasn’t screwed, just sat on top the block using my trusty Moly-graphite bearing grease. It was too late to drill and tap mounting threads, perhaps later.
THE RESULT
New record breaking!! 11,2A at whooping 35,6 watt for such tiny LEDs
The test ended prematurely because my PSU can only supply up to 48 watts. But the curve is already near it’s peak (I predict it should be around 12A). Single E21A can be driven up to 3,1A using my VR16S1 proto board. We assumed 4xE21A in 4P should be able to up to 12A, correct? But when they cramped together in gapless VR16SP4 proto board in earlier test, max current was only 4,8A. Stopped prematurely by the photon cross talks (burnt phosphor’s layer). Now without the photons heating the phosphor layers, the new board can unleash each E21A to their maximum.
Start test block temp was 27,3C, test ended with block temp at 35.3C. I held them at 11,2A for more than 5 minutes while texting and sending pictures to Jensen567. The lux, temperature, and voltage reading stayed the same! Here’s the after test picture, no visible damage, like new. The chipped phosphors caused by the ceramic tweezer when I positioned them in the oven.
Just an Idea to extract more lumens:
If we pot it with something like this 10mm spherical glass lens using optical silicone, more photons can be extracted while making the LEDs cooler.
Looks familiar?
Going for a deep sleep now.
