[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Where did you hear “square”? No one said that.
raining out im bored.
just shot the lux meter with the gt on MOONLIGHT
it was 1000 lux at 4 meters on moonlight :open_mouth:
probably more if i shot it at 10 meters.
crazy light :stuck_out_tongue:
I am guilty as is Flashem of picturing a “block” as a six sided object with square and/or rectangular sides.
Now that I have the GT light in hand, I can appreciate this prototype design more and wish it can come to reality someday…
Nikolas said, “big peace of aluminium block”… I assumed the word “block” was “square aluminium stock”.
I assume he meant to use the word “stock” instead of “block”. Meaning a solid piece of material. Block could be any shape now that I think about it.
OK… It is then up to Lumintop & Neal’s QC to give final pass to reflector.
TA stated that Team OK was given to V1 reflector & anything ‘better than that’ was a bonus.
But it also seems LT is making every effort to provide the best reflector possible in this price point light. Maybe even better quality than was expected.
The slight inconsistencies we are seeing appear to be in the final finish/coating, not in the machining.
It appears possible that maybe a tiny number slipped through the QC control. But, as stated; that is yet to be confirmed.
As I understand what TA said…. everyone will get ….
……. a reflector ’at least meeting’ the standard the Team OK’d.
To me, NikolaS was simply saying they were using a big CHUNK of aluminum. I did not read it as a reference to shape.
I read it as “block” = “chunk”…… nothing more.
block
bläk/Submit
noun
1.
a large solid piece of hard material, especially rock, stone, or wood, typically with flat surfaces on each side.
“a block of marble”
synonyms: chunk, hunk, lump, wedge, cube, brick, slab, bar, piece
“a block of cheese”
Ok all. Most of us knew what he meant. Lets move on. :person_facepalming:
Picked up a new toy……………indispensable measuring tool today. I’ve been what I call a connoisseur of light for a decade or so now. My sweet spot is 5500K. I’ve just not been able to get into the neutral or warm Whites. There is only 1 incan bulb in my house. Everything else is LED 5000K or 5500K. Now I can precisely measure all of my home, car, searchlight and other lights’ color temps and the REAL CRI, not just the averaged number usually quoted for marketing purposes. I’ve learned quite a bit over the last week while researching my purchase. The typical CRI number we see is the calculated average of 8 colors chosen decades ago by a Body in France, the name escapes me now. It represents how close a light source comes to the spectrum emitted by Tungsten incandescent light. CRI of Tungsten light is 100 on the CRI Scale. Extended CRI adds another 7 colors to the mix and the Sekonic 7000 meter has the capability to measure and display the additional 7 additional colors. The more color samples that are taken, the more accurate your CRI is going to be. But even CRI is a bit outdated and there have been and are processes in-motion to use another standard or two. There’s a lot more to it but i won’t get that deep. Suffice to say that below, the first 2 pics are of readings of the Sun. The first shows the Color temp in Kelvin (Tcp on the meter) of the Sun at 3:15 PM. Don’t pay attention to any of the lux reading as I did not set up for a precise Lux measurement. The next pic shows the CRI RA average calculated on only the first 8 colors in the bar graph but it also shows specific individual CRI readings from all 15 samples. The higher the bar graph and number to the left, the higher the CRI of each of the sample colors and the closer to the Tungsten standard the measured light source is.
The 3rd and 4th pics are of the same type of measurements of the GT on HIGH, not Turbo. The 5th and 6th pics are of the GT on Turbo. Notice how the R9 Red is absent from the GT and is actually a minus number.
Sol at 3:15 PM Dec 12 Text Mode
Sol at 3:15 PM Dec 12 Bar Graph Mode
GT at Top of Ramp Text Mode
GT at Top of Ramp Bar Graph
GT at Turbo Text Mode
GT at Turbo Bar Graph Mode
Now that is one awesome tool. I hope you know you are now obligated to test and upload results for every light you own lol.
Nice BVH, bet you’re having fun with that!
Can’t we buy the new 5700k LED already mounted without sending our old LEDs back to Richard?
Problem is, there is no LED boards in the size the GT takes available
You have to send him yours & he will reflow it , I think.
If you search the net to purchase a “block of aluminum” google will show you nothing other than square, flat, or rectangular stock. Anyhow, I get the point…
Teacher, I would like to be on the same page here. This block or chunk of aluminium is round stock and I would assume it is being turned in a CNC lathe?
I’m curious to how this reflector is being machined. Do you or anyone know of the page this info can be found or if this information was revealed, possibly a separate thread?
Not everyone here realizes how much work and time is involved into producing such a (masterpiece) flashlight like this…!
As far as machining goes, I think we should shine some light on the subject. I think it may help ease the frustration of some of those who were unsatisfied or complaining about there reflectors finish.
:open_mouth: THAT THING LOOKS AWESOME!!
Correct, the GT has a massive 45mm diameter mcpcb. Richard carries them up to about 27mm. Keep in mind that the Convoy L6 with its xhp70 and 9,000 lumen potential (for the 70.2 and fet driver) only uses a 20mm mcpcb.
The reason the GT needs the massive size, even though it’s only putting out 2,500 lumen, is because of the massive reflector. The base of the reflector and centering ring are quite huge by normal flashlight standards.
See the base diameter of the reflector below. Courtesy of MRsDNF (Next to C8, S2+ and P60 reflectors)
Bonus pics.
Next to a Q8.
Currently there is a 32mm maxtoch mcpcb for an xml. These can be converted to 12 volt by some cutting and soldering, but I’m still not sure it would fit.
If anyone happens to find a big 12 volt xhp35 mcpcb for sale, please post about it here.
Thanks
I doubt that.
I assume they get rough casts in reflector shape and then machine it.
Otherwise it would be a huge waste of aluminium, time, energy and tools.
Sure they recycle the machined off aluminium, but recycling those bits with machine oil and surface oxidation into the same quality alloy is costly too.
