KD (kaidomain): Deals and new products thread
^ +1
Okay
I just a get few left.
I will PM you the details.
Thank you
what is the size of that driver, if it’s 17mm could you send me a PM too
Ban , i think many members would be interested in xhp35 hi e2/e4 due to the GT .
If you could re-stock the xhp35 hi e2 3c it would be great .
Hi giorgoskok
I just get a limit quantity for CREE XHP35 HI D4 3A Neutral White 5000K
http://www.kaidomain.com/p/S027429.Cree-XHP35-HI-D4-3A-Neutral-White-5000K-LED-Emitter
Thank you
Ban
Will you have more of CREE XHP35 HI D4 3A Neutral White 5000K soon?
I guess some light manufactory bough all those emitters
maybe you should limit to 5 emitters per order and more on request?
any chance to get XHP50.2 K2 CW?
https://www.cutter.com.au/proddetail.php?prod=cut3182
Is anyone aware of a discount code that works for KD general orders?
“BLF”
Unfortunately BLF code is only 5% off. There was a 10% off coupon floating around but it’s expired.
The drop-ins for kdlicker C8 and C8.2 are missing, are you removing the product or are they going to be relisted in their own category?
Got my C8.2 Cree XHP35 HI Warm White today. It has a perfect warm tint at CRI80+ in all modes. I measured 51kcd on high.
There’s visible PWM on the lowest mode and the mode spacing between mid and high is too narrow. When switching between modes it does a short strobe unless you keep the tail switch pressed for a while longer, then it cycles the modes without anomalies. Staying on one mode longer than 3 seconds and half pressing makes the light stay on the same mode. Going from high to very low makes the driver emit a quiet whine for a while.
If you memorize the lowest mode and turn the light on, there’s an annoying preflash. This doesn’t happen on other modes, or at least isn’t visible to the eye.
Construction is excellent, but the clear Convoy C8 with an XP-L HI has more throw (62kcd) and a better UI.
51kCd ?
That’s lower than I hoped…
Do you happen to have any way to estimate the output? That intensity seems disappointing for the XHP35. Maybe it’s just down to the particular design of the C8.2, though. Wonder what it gets with the XP-L Hi.
On other lights, it seems like the peak intensity is usually similar between the XHP35 HI and XP-L HI, with the extra 300-400 lumens of the XHP35 resulting in a larger hotspot.
A max driven xhp35 generally gets slightly more throw then a max driven XP-L HI. So seeing as this xhp35 is not driven to the max, I would say it is not that surprising. It should be putting out close to 2000 lumens if I had to guess though.
Sadly nowhere near the advertised 2000 lumens for the C8.2 XHP35 HI
Tested on an unprotected Samsung 30Q
On high
0 sec : 1241 lumens
30 sec: 1174 lumens
1 min: 1150 lumens
2 min: 970 lumens
3 min: 905 lumens
Mid
0 sec: 728 lumens
30 sec: 717 lumens
Low
0 sec: 302 lumens
30 sec: 301 lumens
Low low
30 sec: 13 lumens
Convoy C8 Clear XP-L HI on max:
0 sec: 841 lumens
30 sec: 839 lumens
1 min: 835 lumens
2 min: 831 lumens
3 min: 828 lumens
Thanks for the test I have one on order, but I guess I will cancel it now.
Anyone try this http://kaidomain.com/p/S026504.H2-C-22mm-1_5A-1-or-2-cell-5-Mode-Boost-Driver-Circuit-Board-for-Cree-XHP35-XHP50-12V in Convoy L2 ,how to make it fit 20 mm space or just sanding a bit ?
Thanks. Looks like yet another XHP35 light that falls way short of advertised output. Are there any 1x18650 lights with the XHP35 that actually hit the numbers they claim? Besides Zebralights, which advertise lower numbers to begin with.
