Diode and res mod on 105c
AMC7135s will throttle current when getting too hot
just keep in Mind at 2S even the stock ones generate double heat than normal
Leviatan, How can I tell if I can put the zener diode on those pins?
if one pin has 0 Ohm to ground and the other to the 200 ohms resistor
Thanks sir
So can we use the empty pads of the stock Convoy driver like the one in the picture? Does the stock driver have the 0 Ohm pin and another for 200 Ohms?
I just got the parts, so I’ll be checking it soon to see if it can be soldered on the second set of solder pads.
Thanks. Take your time and enjoy your mod project. Looking good so far.
OK, so here is the mod done. The Diode was a bit big but it’s just connected to ground, I wonder if there is a better Diode for this. I also upgraded the power and ground wires to 18AWG.
Awesome…bad ass!!!
Nice solder job :wink:
Need some shots of that bad boy in action!
Don’t always trust those “*fire” batteries…chinesium ratings and all that…I like the purple efest ones…they usually do pretty well and are good batteries
Now you gotta learn to solder the button on the flattop batteries (pretty easy if you scuff the contact and use plenty of flux)
Full power
Powered Off
celling bounce
Told ya flashlights are addictive :wink:
Great job on your very first mod!
I actually just ordered 2 of the purple EFEST batts. I picked up the fire ones cause people said they we’re good batteries.
cool cool…caveat emptor and all that
Thanks for the pics. Nice mod. How long can you hold the light when running full power?
Very True.
I have let the light run for a few min’s and it’s fine at full power. it does start to get warmish. I’ll have to tun it on and just let it run see at what point I can’t hold it anymore.
How is that for a Solder ball?
After doing some research I think a better option would be going for a DSOD-323F package DDZ4V3BSF-7DICT-ND the size measures 2.50mm x 1.25mm. The cap this is going on is an 0805 so that is 2.00mm x 1.25mm. and just for reference the MMSZ5229B-FDICT-ND that is the SOD-123 is 3.65mm x 1.55mm I have not ordered the “DDZ4V3BSF-7DICT-ND” yet but I plan on it, to double check the size. So if someone is going to do this mod I would order a couple of the “DDZ4V3BSF-7DICT-ND” they are only 0.17 cents
SOD-323F
SOD-123
Good find. Would you post a picture of your work after trying the smaller 323F?
Of course I will.
Question…. Should I be using the QLITE 6V+ Zener Mod driver? Or should I be looking at the FET boards for this one also? Not 100% on how the FET boards work.
thanks
