Hmm. Actually now that I think about it this is a great idea. It would also allow for some degree of user adjustment for different sized hands or just personal preference.
Interested depending on price. Currently using a shoulder strap with split rings. Works pretty well.
Tbc, i like your design
It’s simple and effective, clever to use the tripod mount, just slide it on and you can easily reach and operate the switch!
what is the diameter of the bar? Would it be possible to add grips, something like these?
Oh NO! I’ve got FUD!
If the plate was bored and threaded, the rod could likewise be threaded and then the bolt and/or tool wouldn’t be needed, simply screw the rod into the plate from whichever side you mount it. Right? 2 pieces total with the one screw affixing it to the light.
You could do that Dale. I like hardware better personally as it would be stronger. Like you said before, once the handle is installed it will most likely stay there. Once it’s together it’s one screw to put it on and take it off no matter what.
Right, once on it’s integral and so needed it’s invisible… part of the light.
I made a bronze component to put on mine yesterday, threaded a manganese bronze rod and when I tested it I had a 6” long 1” bar sticking out the side like the handle on a 1” drive impact wrench. That was cool! Cut it down of course, to a finned 22x22 heat sink looking finger rest.
Edit: YES, I played the kid and “hosed down” everything in sight with GigaLumens. Had to, didn’t I?
Haha. That’s awesome. I’ve been toying with the idea of engraving BFL9000 on mine as a BFG9000 DOOM parody. That would be the perfect setup for it.
I have to admit, after a few seconds of “hosing” and even making the sounds, I caught myself and was embarrassed, even though no one else was around. I supposed I’m beyond help, flashaholic through and through. Woke up this morning and modded a light before making coffee. Sick, I guess.
(Ain’t gonna lie, holding that out-the-side handle and hosing proton’s around the shop was fun, don’t y’all say you wouldn’t have…. ) This thing is intense inside a corrugated metal building.
Hey I just saw the perfect handle for the GT, something similar to the design of the lemax super 70 handle but instead of the screws it has on the bottom, put a 1/4 screw base, we could even make it in some rigid plastic or polymer to save money and weight! What do you all think?
I like it Alex, looks comfy and should be comparatively cheap to produce. Order em up!
It looks much better than the home made jobbies. :+1:
On post #1, the first two pictures,
The gt looks like it’s got a few scratches near the handle area , did the handle cause this?
No scratches. The anodizing is harder than the bare aluminum used in the proto. A co worker was a little rough with it but the marks wiped clean.
Cheap to produce? If you have an order for 10,000 maybe. Get a quote from a mold maker and for a small batch from an injection molding shop and get back to me. The mold alone would cost thousands.
You need to make it in China.
I think he was joking.
I’d rather have one of your machined units anyway!
Back on topic… I should be able to work Proto V2 into my schedule by the weekend. This will at least be the final version of the brackets. As for the handle rod I’m still set on 3/4” aluminum bar stock. For those that want bike grips y’all can slice off my grip easily and do a couple wraps of tape to make the bike grip fit. Though they might fit without tape as well, my bmx days remind me those grips took some elbow grease to get on the 7/8” bars.
Exactly…
3/4” bar stock with nice knurling on it is ideal in my opinion. Can be done with tubing as far as that goes, but I do like things to be rock solid so a bar… hard to beat. I’d probably be prone to reduce the end of the bar and cut threads onto it so it would screw into the bracket, do away with that screw, but that’s probably just me.
