Interesting, thanks. Looks like between XP and XM in both size and capabilities. In the latter more than the former. However in most charts you only compare it with 3V XP sized LEDs. Maybe you could add a power vs flux chart which includes XHP50.2?
this LED in cri70 could be powerful but the donut hole :person_facepalming:
There is a new DTP board you can use for 4040 footprint
https://led4power.com/product/l4p-4040-16mm-dtp-direct-thermal-path-copper-mcpcb/
Nice work koef3. Thanks for posting it up. :+1:
Man I totally forgot about these LEDs, I played around with some of the non high CRI versions about a year ago, the main thing that came of it was a very silly light that ran 4 of them in a Shadow JM07. They are very power hungry and the light originally had one of them but direct drive it was pulling too much current so in a fit of late night histeria I decided I could fix that if I just added 3 more of them and ran the 26650 hard enough to sag down to a more reasonably current draw. The result is a pocket flood monster with 16 LED dies in one reflector.
On first graph, the darker blue curve is for the Luxeon MZ corrected to 85°C Tj.
On your second graph, the same darker blue curve is for the XP-L2 V5 40E.
Something seems wrong.
Very interesting…
how is it compared with xhp50 high cri ?
since its maximum lumen is about 2000 lumen, special footprint, low Vf( more loss power if use linear current regulator like amc7135)
i doubt it will beat xhp50 hi-cri
Near 100lm/W @1000 lumens with 4 dies - I think xp-g2 quad can do it better.
Yeah, I forgot to change the LED data in my template.
It’s fixed now.
At these who calls this LED ‘power hungry’: Mind you, the MZ is connected 4P, the XHP35 HI 4S. In highest bin E2 the XHP35 HI needs 3,200 mAmps for 2,850 Lumens, at 49 Watts. For hypothetical 4S config the current can be roughly quadrupled, which then corresponds to 12.8 A. Maybe the Vf would be much lower, approx 3.60 V or so. But you see that the power hunger can be expected, especially in it’s high CRI variant.
Cree is ‘cheating’ also in cool white high CRI (to increase efficiency) because they have much more green in spectrum, unlike the MZ. In spectrum it is very similar to the Nichia 219BT-V1 sw57 without much green in it.
I’m still waiting for 5700 K min. 90 CRI XP-G2 (which doesn’t exist, for sure). So this might be not really comparable to this MZ, especially if very high light quality is desired…
Thanks for testing this interesting led. Good to read that Lumileds consistently delivers great tints.
A sort of Cree equivalent may be the XHP50.2 in 5700K and 90CRI, Kaidomain had a very small batch of those and I bought one that I may use for a build one of these days. I’m sure that the tint will not be great but the beam profile may make up for that.
I got this light from Köf3. Considering the diffusor it still throws rather far.
The tint is special. It’s an almost perfect “snow white” with hardly any discoloration (maybe slightly yellow and blue, certainly no green). It’s perfectly even across all parts of the beam (the diffusor helps here though). I have tried a Nichia 144A 5700K R9050 3-step before and it was much bluer (of course there are indiviual variations, these are just single samples).
One thing to note here is the extremely low Vf. It allows for perfectly flat regulation with linear drivers until the battery is basically empty. This makes it great for building cheap, but good high-cri lights.
The only real competitor to this LED is the Cree XP-L2 with 90CRI. It’s not available in 5700K and 90CRI and has a very yellow/green corona when used with a reflector.
Inspired by this test I wanted to check that 5700K high CRI XHP50.2 so I swapped it into a KDIY KF8 (it had a boring 5000K XHP50.2).
And I’m not disappointed (tint is not horribly green, pretty white but more blue and green than red, and wood tones look not as yellow as with 70 CRI leds of same colour temperature), but I am also not super-impressed (219B 5700K 92CRI has a bit nicer tint, and being a new Cree, it has some ok not too annoying yellowish corona around the hotspot). The OTF output is about 1600 lumen (pretty constant, the KD boost driver regulates quite well).
Looks nice, thanks for the tip.
Is this board also available in 20 mm size? My test setup doesn’t allow the use of these little 16mm boards.
@djozz: could you make some whitewall shots and maybe a little comparison to Nichia 219BT-V1 sw57? This LED sounds interesting but I have always doubt about light quality and beam pattern because it’s a new generation Cree emitter. I tested the XP-G3 5700 K min 90 CRI already and the tint was ugly green with the known discolored corona…
I'll have 16mm and 20mm DTP boards soon. When I was designing first batch of 4040 16mm pcbs, this is actaully LED I had in my mind, Luxeon V is released later,but conveniently has same footprint.
I have few of these LEDs in my parts for almost THREE years!, that is how old is this LED, and still in 2018 it is brightest 3V LED (except very large luminus LEDs who don't fit in most flashlights).
I did some tests with this least ~6months ago, and lumen/voltage curves are very similar. Cross size in reality doesn't look that bad,gap is smaller than XHP-50/70 but bigger than XHP-50.2/70.2.
With medium roughness orange peel reflectors (tried OP C8 reflector) cross/hole is not visible.
In don't think people realize how good this LED is, it's a basically dedomed XHP-50 with 3V drive and lowest Vf of any 3V LED - regulated high mode would be available for a long time with linear drivers with decent overall efficiency ~85%, this would be similar like having 6V LED+7A output boost converter, but at lower cost.
BTW 5000K 70CRI variant is available in T flux bin (full reel), which is about 30% higher that LED tested above, I calculated ~3500+lm at 14-15A is possible (I'm considering to buy 1 reel for some time).
Some triples and quads can have higher lumens/efficiency, but even with mild OP reflector, this LED should have much better throw.
Has anyone stuck triple or quad Carclo optics in front of some of these? I think that’s what I would be most interested in. Neven, are you planning on selling these LEDs on your MCPCBs? I’d be interested in trying out a quad with them.
Quad quad
Now that’s interesting. It would have the surface luminosity of about XHP35 HI E2 with much higher output. And be available in 3/6V.
The quad array is wide, wider than a XP-L Hi, which already looks less nice through these optics than XP-G or even better XP-E. On top of that, the middle part of a TIR is a plain lens, so on top of a donut you may even see a vague cross
Im my suppose leds will flow so much light away tirs enter that light will burn the optics very fast.
I looked on the carclo website and it seems the led has been tested with the common 10mm optics. It doesn’t work well with the tighter optics but on the 10508 it seems to make a good beam with decent efficiency. I guess three or four of these combined under a medium spot optic would make for an extremely efficient high cri flooder. link
