I can tell you thia for sure. Somehow it had been left in mode 6 when I got it. I'm getto ng ready to turn it on and chek out the ramping and instead I got this massive amout of light that lit up my entire garage (that is my shop). Almost like daylight.
It is extremely bright. I am past ready for the sun to go down lol.
I wanted to badly. The only place in the U.S I could find any and get them here quick was Mtn electronics at a it over 8 bucks a cell... I passed on that.
Terry, thanks for doing this. Would you be able to check whether there’s any step-down in the maximum output, and if so, whether the step-down is based on time or temperature? (for both the 70.2 and 35 HI models) Thanks!
Lol I can get them and should have planned ahead...
The 35 high version will be coming soon. I would like to have some for the side by side testing. Not sure if I can get them here that fast. And 8 bucks a cell is out...
So the cells were fairly drained due to previous turbo output measurements, and that’s when you got the max output of 16297 lumen? So you got this figure without charging the cells in between? So in that case the light is not FET driven (that’s what I thought initially)?
Texas Avenger pretty much means FET drive to me. But then again, I’m certainly not too familiar with driver designs. Battery configuration is 2S2P, so with three 6V emitters (70.2) in parallel you can have a FET drive. We’ll see. Thanks for asking!
