I wanted to badly. The only place in the U.S I could find any and get them here quick was Mtn electronics at a it over 8 bucks a cell... I passed on that.
Terry, thanks for doing this. Would you be able to check whether there’s any step-down in the maximum output, and if so, whether the step-down is based on time or temperature? (for both the 70.2 and 35 HI models) Thanks!
Lol I can get them and should have planned ahead...
The 35 high version will be coming soon. I would like to have some for the side by side testing. Not sure if I can get them here that fast. And 8 bucks a cell is out...
So the cells were fairly drained due to previous turbo output measurements, and that’s when you got the max output of 16297 lumen? So you got this figure without charging the cells in between? So in that case the light is not FET driven (that’s what I thought initially)?
Texas Avenger pretty much means FET drive to me. But then again, I’m certainly not too familiar with driver designs. Battery configuration is 2S2P, so with three 6V emitters (70.2) in parallel you can have a FET drive. We’ll see. Thanks for asking!
I keep a running total of the lights ordered that remembered to post here.
With it being a factory direct order the PayPal payment print out should keep everything else organized.
Please be sure that all orders you made a notation in PayPal for the version you want, emitter tint, color, also charger and batteries.
If you added the charger after your original order it should not be a problem just be sure to make the payment for the charger and note that you already ordered your light before the news of the charger.
Shipment type will most likely be a bit different depending on where you may live. If I get a more exact answer I will post it right away.
We still have until the 31st for the group buy to run. And basically everyone is getting a custom light at least to the point of the color and emitter tint. But all of these colors will not be available in mass produced retail sales lights. All of the color choices are for this only.
Originally we were only going to run until the 15th but enough members had asked for a bit more time so he extended it to the 31st.
