Gnope. If you’re gonna use 2, you’ll need button-tops. You “can” use small Nd magnets to bridge them, but drop the light and they theoretically can shift and short the positive to the (negative) tube.
Plus, they’re great for up to 3A or so, which is fine for smaller lights, but will limit current to the L6.
Should work fine in lower modes, but…
Or you can try a solder blob to act as a bump, but be careful.
klrman
(klrman)
January 16, 2018, 2:33am
4539
Lightbringer:
Gnope. If you’re gonna use 2, you’ll need button-tops. You “can” use small Nd magnets to bridge them, but drop the light and they theoretically can shift and short the positive to the (negative) tube. Plus, they’re great for up to 3A or so, which is fine for smaller lights, but will limit current to the L6. Should work fine in lower modes, but…
Thanks, I think I may as well just get some good 26650's then.
Yeah, best bet, albeit not the cheapest.
You can still use 18650s, even without sleeves, but they’ll have a tendency to rattle around when the light’s shaken. Otherwise, a thin sleeve (even cardboard from a cereal box ) can be wrapped around the cells a coupla times to keep them centered and somewhat cushioned.
DB_Custom
(Dale)
January 16, 2018, 5:09am
4541
Simon usually includes a clear flower looking rubbery ring, 2 of them (or 4) that are for putting around an 18650 so they won’t rattle in the 26650 tube. They’re usually inside the tail cap or in the package the light came in.
Oh yeah, forgot about them. Got ’em with my L2s, so makes sense that they’d be included with the L6, too.
JasonWW
(JasonWW)
January 16, 2018, 6:05am
4543
I don’t think those spacers come with the L6. Maybe the L2 or smaller lights only.
’K, so we’re back to cereal-box cardboard…
DoNkEyConN
(DoNkEyConN)
January 16, 2018, 7:07am
4545
+1
I did not receive them with my L6
mortuus
(mortuus)
January 16, 2018, 9:08am
4546
Didnt get spacers eithers in mine, but i dont get it why would anyone run this light with 18650? i dont see the point in putting those in a big light that throws almost 4000lumens, longer runtimes is better and the batteries sit tight and no need worry about some cheap spacer…
JasonWW
(JasonWW)
January 16, 2018, 9:47am
4547
mortuus:
It’s mainly because protected 26650 cost double the price of protected 18650.
Protected 26650 are also very hard to find right now.
klrman
(klrman)
January 21, 2018, 7:17am
4548
Is the L2 extension tube in Simons link below the same tube as the L6? I need two of these tubes and they
really look the same as the L6 but I want to make 100% sure before I order them.
https://www.aliexpress.com/store/product/battery-tube-for-Convoy-L2-block-style-tube-26650-battery-tube/330416_32592967403.html?spm=2114.12010615.0.0.5a768a39fn7SHX
DoNkEyConN
(DoNkEyConN)
January 21, 2018, 10:01am
4549
klrman:
Page Not Found - Aliexpress.com
That looks like an L6 tube, if I’m correct the L2 Tube is made of 2 parts as the L2 can run off 1 or 2, 26650 cells.
In saying that it would still work for both the L2 and L6.
DoNkEyConN
(DoNkEyConN)
January 21, 2018, 10:02am
4550
Can anyone tell me if i can reflow an XHP70.2 LED onto a stock L6 MCPCB (XHP70)?
KawiBoy1428
(KawiBoy1428)
January 21, 2018, 10:18am
4551
klrman:
Same…Block or Ring style 2x26650 tubes will work between the L2/L6 even the 2pc L2 tubes. all interchange/lego.
KawiBoy1428
(KawiBoy1428)
January 21, 2018, 10:23am
4552
Yep. XHP70 and XHP70.2 are the same.
DoNkEyConN
(DoNkEyConN)
January 21, 2018, 11:02am
4553
Excellent. thankyou KawiBoy
I have a question about where to buy silicone sidecaps?
DoNkEyConN
(DoNkEyConN)
January 21, 2018, 11:25am
4556
contact simon on Convoys aliexpress store.
https://convoy.aliexpress.com/store/330416?spm=2114.12010615.0.0.6679a900rqxbiN
send him a message and he may be able to send you some just for the cost of shipping.
