I'd like to be added to the list. Thanks.
Nice :sunglasses: add me to the list for one please.
Thank you.
Ah, see, I wouldn’t have thought of the 3 Nichia’s, nice call! Would love to see that even if I have to weld em in there my own self.
Might be totally off for this thread, but is there a way to run triple channel to the 3 tints so there could be some selected mixing? You know, dial it in? That’d be cool…
Not without some big changes to the hardware and firmware. It’d need a new driver, a new MCPCB, and a bunch of new code. It’d either sacrifice low-mode efficiency (and moon) by being a triple-FET design, or would sacrifice the high modes by being a 3x2x7135 design, or would need a bigger MCU and probably bigger driver to handle 6 channels instead of 3.
ad me to the very late list please
Please add me to the list for one. Thanks!
Please add me to the list for two (2). Thanks!
one for me pls!
Yeah, but I hope it’s not bead blasted. Shiny looks so much better IMO…
1st version looks like a high end light, 2nd version looks cheap.
Sorry, forget I asked…
On the shiny vs bead blasted, after having made a few lights from scratch and in the beginning going for a polished look, I am now learning to make a final pass that leaves “tooling marks” for some grip. The polished lights feel oily in hand and are a bit tough to hold onto, or can be. Just a thought…
Edit: for clarification… when I was first learning to use the lathe my challenge was to get a smooth near polished cut, running the feed by hand. When the gearing is used to feed at a constant feed rate there are micro lines showing the advancement of the cutting tool (most of the time) Now I am learning to replicate that by making a faster final pass to get those lines, instead of laboriously cutting slow for a smoother finish.
add me to the list please. I like shiny but…
Sounds like one of the major signs of starting to gain mastery — after learning the rules and how to do things right, moving on to learn when and how to break the rules for added effect.
Just a couple days ago I had reason to break the rules in a song I’m making. I ended up using a chord of four notes a half-step apart… like C, C#, D, and D# all at the same time. Normally this would never happen because it sounds shrill and dissonant and one would be hard-pressed to find a chord which sounds worse… but it can, on occasion, be useful.
I have always had this thing about polished. Since I was a kid, it was kind of an obsession. Once, when about 10, I got ahold of a piece of 2000 grit wet/dry sandpaper and wondered what my fingernails would look like if I polished off the fine ridges and such. So on one hand I used the paper and got the fingernails mirror finished, essentially. Then it was embarrassing dealing with the questions about why I “painted” my fingernails! lol Haven’t done that again, but still, I like polishing things for the bling effect. But, after making a few lights with “bling” I discovered it made them difficult to hold. So, compromise was needed.
Finding how to make it look qood while working can sometimes be quite a chore. How many lights do we have with fins on the head, adjacent the reflector, but not so much where the heat is going, below the emitter? Aesthetics can be a bear, function can be ugly, I applaud all the manufacturer’s that figure out so many ways to make so many models…
Count me in for 1!
If I can give my input I’d prefer the completely flat battery tube (so no slants) and a non-shiny finish.
Has anyone managed to get an update on the progress with this? There is a large and growing base of support now, it would help if we had a regular status report to confirm that we are heading somewhere and not just treading water.
This is being actively worked upon. Updates are posted more frequently on the discussion thread on the German forum:
http://www.taschenlampen-forum.de/threads/fw3a-tlf-sonderedition-in-kleinserie-diskussionsthread-update-prototyp-v1.56306/page-9
I use Google translate to follow it:
https://translate.google.co.uk/translate?sl=auto&tl=en&js=y&prev=\_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.taschenlampen-forum.de%2Fthreads%2Ffw3a-tlf-sonderedition-in-kleinserie-diskussionsthread-update-prototyp-v1.56306%2Fpage-9&edit-text=&act=url
A prototype was sent out a month ago to the team working on this and they’re fine tuning various things like the button and the driver. As for the design, Fritz15 said he’s not 100% satisfied with it so current shape will no doubt be balanced out.
Please add me to the list……
Put me down for 1.
1 unit for me thank you
1 for me please.
